This suspension is driving me crazy. *Video*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Silence9, Dec 20, 2014.
  1. Dec 20, 2014 at 10:58 AM
    Silence9
    Silence9 [OP] Solve et Coagula
    Alberta, Canada
    Hey guys. This only seems to happen in winter months, but when I am turning my wheel while stopped, or driving slowly over bumps and potholes, I get this horrible squeaking that is loud and embarassing. What would it be?
    Dry Steering: View My Video
    Drive Through: View My Video
  2. Dec 20, 2014 at 12:02 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    I cannot tell you where that is coming from, but I can tell you that turning the wheels while stopped causes a lot of wear on the steering components as does turning the wheels to the max and hitting the stops. If you have done that much perhaps you wore something out. ;)
  3. Dec 20, 2014 at 12:04 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    A warranty repair, I'd assume. I'd let it be the dealers problem, that would drive me nuts.
  4. Dec 20, 2014 at 12:46 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I can't watch your videos on my phone, but i also was having a horrible squeaking/creaking noise. It was brought to my attention by another member that it was the hood.
    Try this and see if the noise goes away. Stand on the door sill and get the truck to rock back and forth. If you can reproduce the sound open the hood and repeat the rocking. If the noise goes away, it's the hood supports or rubber seals.
    I sprayed white lithium on the plastic hood supports where they make contact with the truck. It took a few days, but i don't hear the noise anymore.
  5. Dec 20, 2014 at 1:36 PM
    Silence9
    Alberta, Canada
    I never turn the wheel to the max, but I noticed turning the wheel while stopped or going slow made the similar noise that's why I took a video of it. What's the warranty on our Toyotas? It's a 2013 but already have 60,000 km
  6. Dec 20, 2014 at 1:37 PM
    Silence9
    Alberta, Canada
    I will phone the dealership. I hate having them work on it, Ive done everything myself thus far. A co worker said ball joints?
  7. Dec 20, 2014 at 1:39 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    3 year / 60 000km bumper to bumper
  8. Dec 20, 2014 at 1:57 PM
    OZ-T
    Peter North
    British Columbia
    Thanks for your input poverty gen
  9. Dec 20, 2014 at 1:58 PM
    T4RFTMFW
  10. Dec 20, 2014 at 2:09 PM
    Silence9
    Alberta, Canada
    :( You know what they say about warranty.
  11. Dec 20, 2014 at 2:24 PM
    Wheelspinner
    Wheelspinner Coco Customs
    Northern NJ
    '13 4x4x4cyl
    Since it happens on slow bumps and turning the wheel not moving it almost sounds like one of your balljoints or tierod ends are dry or worn. Unfortunately on these trucks the aren't greasable so that mean it will need to be replaced if that is the case.
  12. Dec 20, 2014 at 2:26 PM
    Silence9
    Alberta, Canada
    That sounds about right. I looked everywhere for grease nipples before because I figured they were dry, none in sight. That sucks.. They shouldn't be going already, on a good note I think it's only the driver side...
  13. Dec 20, 2014 at 2:40 PM
    Blacktaco2042
    Blacktaco2042 Well-Known Member
    wisconsin
    supercharger/trd cat back 3inch lift 265/75/16 duratracs bumper guard led bar
    upper balljoints. i had to do them on my buddys truck.
  14. Dec 20, 2014 at 2:47 PM
    Silence9
    Alberta, Canada
    Thanks. Is it hard to do yourself and or expensive?
  15. Dec 22, 2014 at 11:08 AM
    Silence9
    Alberta, Canada
    It does it up to about 40-50km/hr too. :/
  16. Dec 22, 2014 at 4:57 PM
    moondeath
    Pa, Gardners
  17. Dec 22, 2014 at 9:49 PM
    Silence9
    Alberta, Canada
    I will definitely try it, it wouldn't explain the similar squeak it does when I turn the wheels though. I'll try thanks.
  18. Dec 23, 2014 at 10:50 AM
    moondeath
    Pa, Gardners
    Yeah, it's just something worth checking. When I first heard mine I assumed it was suspension related because it's sounds identical to it. I actually couldn't believe the hood would make that much noise.
  19. Dec 23, 2014 at 11:05 AM
    NCtaco914
    NCtaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    17' DCSB TRD O/R
    Have you check your upper shock mount bushings? Mine were ever so slightly worn and they would squeak similar to what you were saying. Can you duplicate the squeak if you rock the truck side to side?
  20. Dec 23, 2014 at 11:44 AM
    welterbf123
    welterbf123 Well-Known Member
    Columbus, OH
    2017 TRD Off Road
    12voltsolutions.com plug-n-play remote start system. OVTuned OEM Bed lights Underhood and footwell lights Garmin dash-cam Weathertech side vents, bug shield, mud flaps and floor mats Extang Encore tonnau cover OME BP51 Suspension Front & Back / Dakar Leaf Springs Light Racing UCA's XD Holeshot 17" x 9" Wheels Nitto Trail Grapplers 265/70/R17 TRD Pro Grille Raptor Lights iJDMToy 30" LED Hidden Bar Light Toyota Bed Step
    A-Arm bushings most likely.
