This Truck Does Not feel the Same After the Fuel Pump Recall Fix
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BajaBornTaco, Nov 4, 2020.
  1. Nov 4, 2020 at 8:00 PM
    BajaBornTaco
    BajaBornTaco [OP] Well-Known Member
    Sold: '19 TRD OR - It will always be in my heart.
    It's actually more responsive in the mid range. Low-end pick up is about the same.
    I was not expecting anything to feel different after the fix, low-pressure pump is just for idling, I thought. And everything felt normal on the drive home from the dealership. That is until I got to a long, steep hill that I always drive on. The usual struggle was just not there. I found myself passing slower traffic, which on that hill, on the Tacoma was unheard of :rofl:
    I wonder if they tweak with the software somehow (??). I've always liked this truck, but now, I guess I like it more.
  2. Nov 4, 2020 at 8:02 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Probably had the battery disconnected and is going thru a relearn proceedure.
    gargamel05, Jester243, CG256 and 16 others like this.
  3. Nov 4, 2020 at 11:07 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Check your hood, they may have updated the ECU calibration to a more recent one. Hard to know since your vehicle info is not filled out.
    Skydvrr, Chew and Junkhead like this.
  4. Nov 4, 2020 at 11:08 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Probably set your tires to the correct pressure.
  5. Nov 5, 2020 at 3:35 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Not that complicated... your truck wasn’t getting proper fuel to the engine ...new pump corrected the problem .
    Astr0Aar0n, Tacospike and Grossomotto like this.
  6. Nov 5, 2020 at 3:43 AM
    electricdgm
    electricdgm Well-Known Member
    Doug
    Florida
    2019 Cement TRD XSP Sport 4x4
    I will let you know I get my fuel pump replaced next Friday the 13th. Oh that may be a bad thing Lol!
  7. Nov 5, 2020 at 5:36 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    :headbang:
    That’s good luck bro
  8. Nov 5, 2020 at 5:50 AM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    Not really possible as you'd be running lean and have a bunch of warnings about low pressure in the rail. Fuel trims would also be getting pegged out. As others said, its probably new ecu calibration, maybe they reset your transmission adaptive (not really part of the procedure) so most likely the new/shiny placebo effect.
    CG256 and Junkhead like this.
  9. Nov 5, 2020 at 5:52 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    this
  10. Nov 5, 2020 at 6:52 AM
    RuckusTRDPro
    RuckusTRDPro Well-Known Member
    Jeffrey
    2019 Tacoma TRD Pro-Voodoo Blue
    Mine felt the same also. I checked to see if they updated ecu code but looked the same ‍♂️
  11. Nov 5, 2020 at 7:01 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I have mine scheduled for the 17th.
    Is there anything else I should have them look at while it's in?
  12. Nov 5, 2020 at 8:32 AM
    BajaBornTaco
    They'll accidentally install a turbo on your truck. Spooky
    Skydvrr likes this.
  13. Nov 5, 2020 at 8:38 AM
    BajaBornTaco
    Yea, this could be it. So, that means that I've been driving it like a granny and at the moment is reset to Olympic athlete mode.:benchpress:
    shakerhood[QUOTED] likes this.
  14. Nov 5, 2020 at 8:41 AM
    BajaBornTaco
    I can't think of anything else. Unless of course, there's anything that's not working properly.
    Fargo Taco[QUOTED] likes this.
  15. Nov 5, 2020 at 8:41 AM
    Astr0Aar0n
    Astr0Aar0n Well-Known Member
    Portland, OR
    19' Tacoma TRD OR V6 4x4 DCSB cavalry blue
    Quite a few things at this point..
    I noticed the same after my recall. Truck seems to be doing better in its acceleration, not by a large amount by any means, but noticable still.
  16. Nov 5, 2020 at 9:00 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    My wife's 2018 Camry XLE V6 (basically the same engine) was subject to the same recall. The way she drives, if it made a difference she'd have noticed, and she hasn't. I think it's your imagination.
  17. Nov 5, 2020 at 9:04 AM
    BajaBornTaco
    That makes 3 people's imaginations so far in this thread. See Astr0Aar0n & RuckusTRDPro posts
    Astr0Aar0n likes this.
  18. Nov 5, 2020 at 9:05 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I also vote new calibration
  19. Nov 5, 2020 at 10:36 AM
    Fargo Taco
    Fargo
    2019 TRD Pro
    Knock on wood everything has been good so far but I will have them investigate TSB 0071-19 for the coasting from 30-10 vibration.
