This truck is a pain.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taconator_, Oct 2, 2021.
  1. Oct 2, 2021 at 11:02 PM
    Taconator_
    Taconator_ [OP] IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I’ve seen a few posts saying you can’t flat tow a Tacoma, if I call AAA and they bring a regular tow truck, would that be fine? Since one end would be up so technically not a “flat-tow.” Or should I request a flatbed? It’s a 4x4. I’ve never had it towed so I’m not exactly sure how to go about it. It’s exactly 6.6 miles to the dealership. I think it would be ok, just want to double check before the dealership finds something else to blame.
    • Interesting update.
    Turns out the fuel injectors went out, AGAIN. This is the second time in under 50k miles. Except the dealer just told me that fuel injectors are a 3yr 36k mile part, and I’m at 48k miles. They’re trying to get it approved through toyota corp. since I’ve been back n forth with multiple idling/misfire issues for some time now. Hopefully it gets approved.. just odd to have fuel injectors fail twice in under 50k miles.
    • 3rd update. Dealer said there’s water in the fuel.. currently contemplating fixing it myself in lieu of paying them $1,100
    • New update (page 5, #100) or see below.
    list of codes It’s throwing at me.
    P008A00
    Low pressure fuel system pressure - too low
    P008700
    Fuel rail system pressure - too low
    P01902A
    Fuel pressure sensor “A” circuit: signal possibility failure
    P107A2A
    Fuel rail pressure sensor (low) possibility failure
    P107A64
  2. Oct 2, 2021 at 11:03 PM
    Bishop84
    Bishop84 Well-Known Member
    Most tow trucks are flat decks now. I rarely see old style tow trucks bringing anything to my dealer.
  3. Oct 2, 2021 at 11:07 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    If you're using AAA just request a flat bed....
  4. Oct 3, 2021 at 7:24 AM
    robe689
    robe689 Well-Known Member
    Bob
    SE Connecticut
    2020 Silver Tacoma SR5 Access Cab V6 4WD
    Your Operators Manual gives some pretty good information concerning towing the vehicle (see attached pages).
    tacotoe, Mully, nictarine and 4 others like this.
  5. Oct 3, 2021 at 7:26 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    When you call the tow company, just tell them what they are towing and your concerns. Back your conversation with an email.
    If the tow company damages the truck.....its their nickel. Might be a bugger to prove. Suggest to take pictures of the tow truck (include lic plate & driver), your truck before and after loading.
    Thatbassguy and SandyTaco4x4 like this.
  6. Oct 3, 2021 at 7:32 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Flat towing or towing with the front wheels off the ground will do the same damage. The tailshaft of the transmission will spin. The pump to provide lubrication is spun when the engine is running. Not when the rear shaft is spinning. You could cause serious damage to the transmission in even a short tow.
  7. Oct 3, 2021 at 7:37 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Simple. Put it on the hook from the rear. So what if the front wheels are on the ground. They free spin unless in 4 x 4.
  8. Oct 3, 2021 at 7:48 AM
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    Why you call it a POS ?
  9. Oct 3, 2021 at 7:53 AM
    Knute
    POS = Point Of Sale.
  10. Oct 3, 2021 at 7:55 AM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Powerful Overland Ship
  11. Oct 3, 2021 at 9:10 AM
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Lol! Long story short I’ve had misfire issues for some time now. Truck will misfire, turn off, not turn on. I take it in and they can’t figure it out or “fix” something and somehow it’s happened again. Odds are the fuel pump failed again but who knows. I’m pretty fed up with it at this point and just going to sell it.
    Anywhoo, this time took the longest to turn on. I was about to call AAA but by the grace of the car gods it’s on and at the dealership. I appreciate everyone’s input btw.
  12. Oct 3, 2021 at 7:25 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Please let us know what they find. Good luck.
  13. Oct 3, 2021 at 7:34 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    whats wrong with it ??
  14. Oct 4, 2021 at 5:13 AM
    RI_OR21
    RI_OR21 Well-Known Member
    RI
    21 TRD OR/DCLB Army Green (1st Taco)
    Post #11
    shakerhood and SR-71A like this.
  15. Oct 4, 2021 at 5:39 AM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    Have you tried.... taking it anywhere else? Some Dealers have crappy shops, some have good ones. Most independent shops are better. Unless it's a recall or a warranty repair I'd take it elsewhere
    RTD, Thatbassguy and nictarine like this.
  16. Oct 4, 2021 at 5:47 AM
    dklehman
    dklehman Well-Known Member
    Darin
    Eastern wa
    2021 TRD off road
    Most tow truck companies can dolly your truck if they don't have a flatbed available or the driver can disconnect your rear driveline. However the company will usually charge a more to dolly your truck and the drivers absolutely hate doing it.
    Big tall dave and Junkhead like this.
  17. Oct 4, 2021 at 6:03 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Oh yeah good ideal to sell a truck because it might have a bad fuel pump.
  18. Oct 4, 2021 at 6:10 AM
    nictarine
    nictarine Well-Known Member
    Nick
    Years ago my wife's Tacoma's AC would only blow on high, her mom told her to sell it and get a new car, a $30 resistor and 20 minutes of work had the issue resolved!
    For the record, we had just started dating and 18 of the 20 minutes was me trying to wedge my big body in upside down to be able to get to the damn thing lol
    auskip07, tarbal255 and doublethebass like this.
  19. Oct 4, 2021 at 6:12 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    I saw an RV with a new Ranger behind it being flat towed. I don't know if it was 2wd, most likely the driveshaft was disconnected.
    Big tall dave and shakerhood like this.
  20. Oct 4, 2021 at 10:32 AM
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Amongst other things, but sure.
    Thatbassguy likes this.
