This what I need for differnential fluid?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Feb 7, 2010.
  1. Feb 7, 2010 at 8:18 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
  2. Feb 7, 2010 at 8:22 AM
    blendedfamily
    blendedfamily Well-Known Member
    'Burque(sucks)
    What model do you have? Sport, or non? I've read around, and I'm sure people will chime in, that the LS additive in the mobile 1 sucks for the LSD in the sport -- they are mostly running non synthetic oils, and using their own additive.
    Im running that same oil in my non-LSD truck, and I have no complaints so far -- When I pull the plug again in another 25k or so, I'll let you know for sure. :p:p
  3. Feb 7, 2010 at 8:32 AM
    jeremy_283
    I have an 08 4x4 TRD Offroad
  4. Feb 7, 2010 at 8:33 AM
    jeremy_283
    I am just wondering, I dont need to put any other additives in it do I?
  5. Feb 7, 2010 at 8:35 AM
    blendedfamily
    'Burque(sucks)
  6. Feb 7, 2010 at 9:23 AM
    PA452
    PA452 Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    I know it doesn't apply to the OP's situation, but I just want to point out that just because you don't have a Sport doesn't mean you don't have an LSD. I have an SR5, non-TRD, and I have an LSD.
  7. Feb 7, 2010 at 12:42 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    ^ proof of window sticker? i have never seen/heard of a mechanical LSD on a non-sport truck. what makes you think you have one?
  8. Feb 7, 2010 at 12:45 PM
    blendedfamily
    'Burque(sucks)
    I haven't either, but for the sake of causing some drama and jacking this dudes thread, I didn't say anything. I'm sure anything is an option if you pay enough for it...
    Jeremy -- if you're unsure about it, check your window sticker. But, unless there are some exceptions, if you don't have a sport, you dont have the LSD. And, if your totally worried, just toss the additive in there anyway.
  9. Feb 7, 2010 at 12:49 PM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Mobil 1 is good. I put some of this in there and so far so good, I'll find out more next change.
  10. Feb 7, 2010 at 12:53 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if you have the trd offroad.....as your info says...then you have the locker.....and any 75w90 will be fine.
  11. Feb 7, 2010 at 3:34 PM
    huskertacoma
    huskertacoma Member
    Nebraska
    06 SR5,dbl,lngbd,4x4
    Here is proof you can purchase a non-sport truck with LSD. Mine has a LSD sticker on the differential.
    scan0003.pdf :p
  12. Feb 7, 2010 at 7:39 PM
    PA452
    Western PA
    I've gone through two moves since I bought the truck, it would take me a while to find the window sticker.
    I have the "LSD Oil Only" on the back of the rear diff, and I know the info sheet (window sticker) had it also. Besides that, it's fairly obvious when driving it in certain situations that it has an LSD and not an open differential. There have been others who point out the same thing, I just usually clarify that because I see a lot of people here, including yourself, assume it was only installed on the TRD Sport packages.
    Also, I didn't even special order mine, it was on the lot. That said, I specifically wanted an SR5 with an LSD, so had I not found exactly what I wanted on the lot, I would have asked them for it.
