thorny suspension problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by mwhelm, Sep 7, 2014.
  1. Sep 7, 2014 at 3:00 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    Had a bad off road driving experience, and now having what
    seems like some suspension trouble. Any advice or ideas on
    how to make this truck happier would be much appreciated!
    When the wheels are turned left and right - usually far left or far right -
    there is a grinding sound. You have to have someone sitting in the passenger
    seat to hear it, I don't think it's audible without a passenger.
    The tires are a bit oversize but they've been on there for years &
    no problems before.
    We've been around the world of mechanics with this car. It can't
    quite be brought into correct alignment, but it's close, & different adjustments
    don't make any difference with the noise. Some people think the knuckle
    needs to be replaced, but can't tell for sure (no obvious bends). Some
    people think the struts need to be replaced, but they don't seem that
    weak to me (bounce test). The noise sounds a little like CV joint problems
    in other cars, but only a little - is there a good test for this? And why
    would it need a passenger to show?
    We were convinced to replace the lower control arm (driver's side),
    which then convinced me that the person who did this didn't know
    the answer either, because it made no difference.
    The tires are a bit cupped but that probably means either (a) they wear
    like that anyway, like some people have told us or (b) the alignment's
    been a bit off for a while, like others say.
    It doesn't seem likely the frame is bent. If it were, we'd have a ton of
    problems, & nothing is obvious (but nothing's been measured).
    I'm thinking of putting the standard size tires on here but I fear that's not
    going to solve the underlying problem (needs tires soon, tho).
    How can I do this smarter than replacing random parts?
    Thanks!
  2. Sep 7, 2014 at 6:38 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    We worked on this problem in detail this afternoon.
    The 2nd alignment seems to have reduced or eliminated the
    noise on the front RH/passenger side almost completely, but
    it still is present on the front LH/driver's side, particularly
    when a passenger sits in.
    We chalked the wheel wells thoroly, to try to find tire rub,
    & we found some. The back mudflap areas of the front wheel
    wells both show rubbing. The RH side shows rubbing but
    doesn't seem to make much noise. the LH side is missing
    its mudflap & is noisier. It looks to me like the back,
    inside edge of the tire can catch the inside edge of the
    wheel well and this is what seems to make the noise.
    This should eliminate CV joints as a problem.
    Why would the tires/wheels now be relatively further back?
    Is this a suspension or frame problem after all?
  3. Sep 7, 2014 at 6:42 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    I have my money on wheel bearings.
  4. Sep 7, 2014 at 9:03 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    A real troubleshooting test for this would be a vid w/audio & kinda hard to tell you anything without some description with any susp. MODS/upgrades, you say you can't get alignment within specs ?? Ok, this could mean it's lifted or it could mean its stock but the susp. is so FUBAR'd it'll never hits specs without new parts.....just sayin'...
  5. Sep 9, 2014 at 2:24 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    I'm sure it's a severe suspension problem, I just don't know
    how to proceed. I'm somewhat sure its CV joints aren't the
    problem (they're not the noise source). I don't think it's
    lifted but I think it does have old KYB struts.
    I did some more investigation & made a photo album that will help.
    I hope this url works - uploaded images here would be too low res
    to be useful.
    https://www.flickr.com/photos/32292837@N06/sets/72157647016769568/
    The first shows how the wheel touches the wheel well.
    The 2nd shows the shocks + knuckle
    The 4th shows the current alignment reading; hard to read, but
    LF caster should be 1.1 - -0.5 deg; it's greater, -1.4 deg.
    The 3rd shows something I noticed. On the center left at top,
    you can see what looks like the polish from the upper control arm
    hitting the matting at the top of the wheel well, & on the right
    what looks like a hole or rip dug into the mat by the bolt on the
    knuckle. There's something similar on the RH side. I don't know
    whether these were there before our off road incident but it
    seems likely our bounding over rocks could have done this.
    Any opinions about what I should do to get the alignment
    into spec?
    Thanks!
  6. Sep 9, 2014 at 2:50 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Look how chewed up the under splash guard is in Pic #2. I'll bet moola that your tires are too big (Or Wheels), or the struts are gone and not holding up the truck correctly. that would explain why it's worse when someone is sitting in the Passenger seat. Also, I had a fit with my shop about making the camber dead zero and I stood there early 1 morning and watched the Mech make it dead zero on both sides. I know it's in "Spec" but geeze Mech's, get it dead on.
  7. Sep 9, 2014 at 4:22 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    Some of that chew up look is coming from
    the chalk I put all over the wheel well to find the rubbing
    point (it turned out to be obvious).
    What do you think of the impact points in picture #3?
  8. Sep 9, 2014 at 4:25 PM
    GREEKBOY12295
    GREEKBOY12295 Well-Known Member
    Nick
    Phoenix, AZ
    2005 Toyota Tacoma PreRunner
    Radflo 2.5 Coilovers, Viper Alarm 5902, Bilstein 5100's, Polk Speakers, Blacked out grille and Emblems, All Pro 3" leafs, Pioneer AVH-4300 Double Din, BHLM, 4" Maxtrac Spindle, Aero Turbine 2525xl, Ultra Gauge, Rockford Fosgate 300 mono amp, 10" Kicker CVR
    I think it may be a change of caster in your alignment. idk though
  9. Sep 9, 2014 at 4:49 PM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    I didn't notice on 1st look. Something is terribly wrong for that to be where the strut hits. Has this ever been in a accident?
  10. Sep 9, 2014 at 9:46 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    Bouncing over rocks, too fast.
  11. Sep 9, 2014 at 10:01 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If the noise is occurring when you are turning that's indicative that the grinding sound occurs only under a load on the wheels due to body weight transfer. The wheel bearings going out typically make a noise you are describing given the symptoms and conditions it happens under. If they are bad enough, they could potentially be causing an unseen wobble in the tire which is causing the premature wear on it.
    If you want to check the bearings take your tire while still mounted on the vehicle in the air and attempt to wiggle it not horizontally (side to side motion) but vertically (up and down). If the tire wiggles at all that's a problem and your bearing should be replaced.
    Good luck and let us know how it goes.
  12. Sep 9, 2014 at 11:12 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    I'm pretty (99.9%) sure all the noise I'm hearing is from the left front
    wheel brushing the back of of the wheel well. Why it's doing it now, & why
    the alignment is not in spec, is
    the puzzle. I'm leaning towards either the knuckle, or the shock/struts,
    being bent (or shot).
    Did I miss anything else I should be considering? Are there any
    good diagnostics I might not know about? Mechanics I've talked
    to can't seem to resolve it, & replacing either = expensive experiments :)
  13. Sep 9, 2014 at 11:27 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You might want to strongly consider taking the truck into a shop hat has a laser alignment machine. They can typically take measurements of wheelbase width and length, which can help you determine if something is bent or if the frame itself is bent.
    Do you happen to have any current alignment specs?
  14. Sep 10, 2014 at 4:24 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    I've never heard of that kind of alignment place. How would I know/
    find one?
    Current alignment specs:
    4th pic on right
  15. Sep 10, 2014 at 7:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Holy shit :eek: look at that negative camber on the drivers side! It's also wonky on the passenger side also. What kind of suspension do you have? Try and take a picture of the upper/lower control arm, better yet just try to snap a pic of the entire suspension. You either have a tweaked control arm, or spindle, but I can't tell from the angle of the shots. Take several pictures of the suspension, front to rear. If control arms or spindle is not the problem, the next problem could, I know you don't want to hear it, frame.
    As far as finding an alignment shop that offers laser alignments, you are going to have to look around. I know Hunter has a laser alignment machine. They are the most accurate within at least 1/10 of a degree. If you can find a shop that has one of those machines or equal to. Get all that info checked out there.
    Judging by the other pictures on your flickr account, It looks like the vehicle took a hard impact which caused the UCA to contact and rupture a hole through the fender well sheetmetal. As a sidenote.
  16. Sep 11, 2014 at 12:41 AM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    I think the judgment in the last paragraph is exactly right.
    Now I need to get right with it.
    Do you know of such a shop around you? I live in the west part of the
    same county.
    I'll take some more pix tomorrow. We've talked about frame with
    other places but they don't believe it - the claim is that these
    trucks usually don't bend frames, other things in the suspension bend
    first, and any frame bending & the vehicle would show a lot more
    problems. This one has what turns out to be a relatively minor
    noise problem but the alignment is sure whacky. More soon.
    Thanks for giving it all a look!
  17. Sep 11, 2014 at 1:03 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What part of California do you live in bud? Bay area?
    Actually, that argument would be more or less correct. Rarely do you see these trucks with bent frames, usually things like the tie rods, spindles, and control arms as well as sometimes even the coil buckets bending first. That's not to say that a bent frame should ever be ruled out of the equation.
    BTW. I would strongly suggest you check out those wheel bearing as well, especially if the noise is more pronounced with a weight load on it, like turning, or even an extra 130lbs of a passenger.
    No problem bud! I did alignments for about 3 years and worked on vehicles for over 11, so I never voicing my opinion on issues similar to these. I am here to help!
  18. Sep 11, 2014 at 6:10 PM
    mwhelm
    mwhelm [OP] Member
    Michael
    California
    SR5
    I posted a series of pictures in the same place that show the LF wheel suspension
    area, some with the wheel turned to the left, some with the wheel straight
    forward. I just can't see much (but I'm no expert). Not sure if the upload
    is in the same order but the first 7-8 should be with the wheel turned.
    I live in Richmond CA.
  19. Sep 11, 2014 at 6:11 PM
    crushh87
    crushh87 Woo Pig
    Jack
    Texas
    2013 Prerunner Silver
    4in MaxTrac Lift Spindles, 2in Pro Comp AAL, MB 352 16x8.5 Wheels, 285/75/r16 General Grabber AT2s, 2.7L I4
    <offtopic>
    The way you space your wording makes it look like poetry for some reason
    </offtopic>
  20. Sep 12, 2014 at 1:01 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll take a look at them when I have better reception. You live ridiculously close to me! I'll PM you a shop's name. They have the alignment machine I am talking about. They'll take care of you. If they can't, they'll set you straight to a place that can determine frame damage.
