those 2 little threaded holes in the front of your bed...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by stan23, Mar 2, 2016.
  1. Mar 2, 2016 at 11:59 AM
    stan23
    stan23 [OP] Well-Known Member
    stan
    Santa Clara, CA
    2025 DCSB TRD Sport 4x4
    All,
    Is there anyway I can add a tie down point there? Do you think those threaded holes will be strong enough?
    Thanks!
  2. Mar 2, 2016 at 12:41 PM
    Sbpark
    Sbpark Well-Known Member
    2017 Subaru Outback 2.5i Limited
    You talking about the holes just below the rear windshield on the bed? If that's what you're talking about it's where the piece sits that supports the OEM tonneau cover.
    PFB likes this.
  3. Mar 2, 2016 at 12:42 PM
    stan23
    stan
    Santa Clara, CA
    Yeah, I know it's for the factory tonneau. I just want to know if those threaded holes are strong enough for a tie down loop of I make one.
  4. Mar 2, 2016 at 12:44 PM
    Sbpark
    Deet and ChadsPride like this.
  5. Mar 2, 2016 at 12:58 PM
    stan23
    stan
    Santa Clara, CA
  6. Mar 2, 2016 at 2:06 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If your not going to trust a bed cleat mounted to a rail then why trust the tonneau mount?
  7. Mar 2, 2016 at 2:23 PM
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    I put a couple stainless steel bolts to put in those holes. Have no clue what they are for.
  8. Mar 2, 2016 at 2:31 PM
    stan23
    stan
    Santa Clara, CA
    Huh? The bed cleats are on the rail. The 2 bolt holes are on the bed itself.
    doyouevenprerun likes this.
  9. Mar 2, 2016 at 2:32 PM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    if you do that make sure you use a backing plate to distribute the load
  10. Mar 2, 2016 at 2:35 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I know that, probably only 2 or 3 small bolts that hold the rail. If you have the cleats tight they aren't going to move. I don't know exactly what the threads look like you want to tie to but it sounds less stable than using the cleats
  11. Mar 2, 2016 at 2:40 PM
    stan23
    stan
    Santa Clara, CA
    There are 5 bolts holding the front rail in place. The plastic bed cleats are only rated 200 or so lbs (and not laterally) If you tie down 2 bikes on the bike using a cleat in the middle, you've already gone beyond the holding weight limit.
    There just so happens that there are 2 threaded bolt holes in front of the bed (for the OEM Tonneau cover) I want to fab a u bolt and use those threaded holes as a tie down point.
  12. Mar 2, 2016 at 2:44 PM
    stan23
    stan
    Santa Clara, CA
    Here is a great picture I found on this forum of what i'm talking about.
    I want to use those 2 holes and install a D-ring to use as a tie down point for motorcycles.
    Sure I can buy the front bed rail and install (see 5 bolts underneath) and use a bed cleat, but the cleats are not strong enough.
  13. Mar 2, 2016 at 2:48 PM
    Kawirdr728
    Kawirdr728 Well-Known Member
    Austin, TX
    '18 Red DCSBOR
    I've never had issues tieing two bikes down on one cleat
    If you wanna do it, then do it. There's only one way to find out if it'd be strong enough.
    Topanga Taco likes this.
  14. Mar 2, 2016 at 2:48 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I would buy the rail and find better cleats that work with the rail or make your own. Or custom make some d-rings that will mount to the bed bolts in the front. Unless that's too low for you. Guessing your already using the 2 front corner bracket mounts?
  15. Mar 2, 2016 at 2:49 PM
    stan23
    stan
    Santa Clara, CA
    Dirt bikes maybe OK, but my ducati sport bikes? I don't want to risk it.
  16. Mar 2, 2016 at 2:50 PM
    Kawirdr728
    Austin, TX
    '18 Red DCSBOR
    Now I find it hard to believe that you can fit two sport bikes in the bed of your truck o_O
    tcjacado likes this.
  17. Mar 2, 2016 at 2:52 PM
    stan23
    stan
    Santa Clara, CA
    Exactly what I want to do.. Add a d ring right in the middle and front of the bed using the 2 threaded holes. Just wondering if it is strong enough.
    Yes, the 2 front grey mounts are used too. Some bikes, I don't like to criss/cross tie downs. Thus, I want a tie down point in the middle.
  18. Mar 2, 2016 at 2:57 PM
    Iamraiderpower
    What about the BAMF corner brackets?
  19. Mar 2, 2016 at 2:57 PM
    stan23
    stan
    Santa Clara, CA
    Can't tell if you're serious.. I used to take 2 sport bikes on my 2nd gen tacoma to the track all the time (same bed size as 3rd gen). I did the criss/cross tie down thing, but with my new truck I wanted to make life easier by adding a 3rd D-ring in the middle.
    Here's a pic I found. (not mine, I had an xrunner)
    RyanDCLB and doyouevenprerun like this.
  20. Mar 2, 2016 at 3:01 PM
    stan23
    stan
    Santa Clara, CA
    Thanks, I got the corners covered -- gonna use the tie down points on the front side of the bed.
    I just want a tie down point between the 2 bikes in front of the bed.
    A bed buddy would be obvious, but I can't use that because I have a tri fold cover and the bed buddy has a tie down that points straight up in the middle.
