Those of you with the Lund Genesis cover..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by semper000, Oct 29, 2007.
  1. Oct 29, 2007 at 4:12 PM
    semper000
    semper000 [OP] Member
    2008 Black Double Cab TRD Sport Long Bed
    I just got an 08 DC Sport Longbed. I've been looking for a soft tonneau cover, and I think I've narrowed it down to the Lund Geniesis Seal and Peel. I basically want a cover that I can put on the truck when I take road trips. Normally I dont like to have a tonneau cover. Why questions are:
    1. Can the cover be folded or rolled up to sit behind the back seat and pulled out when needed?
    2. How easy are the the frame rail supports for the cover removed. I want to be able to use the bed and have cargo extend above the top of the bed, I think they would just be in in the way most of the time. I like to just slide them all up toward the front of the truck then space them out when I have the cover on.
    3. How does the cover seal to the sides of the bed? Is the zip channel just bolted to the bed? Does that make sense?
  2. Oct 29, 2007 at 5:08 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    #1. u wont be able to roll it and stick it behind the seats b/c its broken into 2 chambers the size of the seats...now folded might fit befind the passenger side rear....
    #2. as long as it isnt a proped up kind of osft tonneau, the center tension rails SHOULD come out fairly easy.
    #3. i have no idea...haha
    hope it helps out some
