those plastic wheel well liners
Discussion in '1st Gen. Tacomas (1995-2004)' started by wstacolvr, Feb 12, 2010.
  1. Feb 12, 2010 at 1:26 PM
    wstacolvr
    wstacolvr [OP] Member
    a couple of the wheel well liners seem to have pulled away from the tabs but the tabs are still there. Can the tabs be removed without breaking them?
  2. Feb 12, 2010 at 1:31 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    2002 4x4 Limited TRD V6 Auto (234k+, 1-owner)
    Lots of small stuff; Grillcraft MX, Bilstein 5100's, Deck Plate Mod w/ AFE air filter, Airaid MIT, braided SS brake lines, Redline Tuning QuickLIFT hood struts, Extang Full-Tilt tonneau cover, fog light mod, gray wire mod, power outlets on-demand, Diff breather ext, additional contours to passenger side from oak tree.
    The only ones I've been able to remove without breaking are those that I can reach from the back. Then you can compress the tabs to get 'em out. The good news is that they have a few tabs on them. I usually end up braking one or two of the tabs so they can be reused.
    I just keep a supply of new ones on hand...
  3. Feb 12, 2010 at 1:50 PM
    wstacolvr
    Thanks for the info.
  4. Feb 12, 2010 at 1:59 PM
    Blumpkinson
    Blumpkinson Fuelled by plutonium and wild animals
    OR
    03 4x4 5spd
    The tabs can be removed theres two parts that compress, all i did was take a flat head and push one of them then pull with a pair of pliers. Then use the flathead to compress the other part and just pull it right out. After you get one out it'll be really obvious and much easier on the rest of them
    Ecnerwal likes this.
  5. Feb 12, 2010 at 7:19 PM
    ak47
    ak47 v.hey its my Avatar avatar.v
    Anthony
    Washington
    stock 2nd owner
    i broke the ones holding the drivers side splash gaurd on while changing my oil and just zip tied them. works good for me
  6. Feb 12, 2010 at 7:22 PM
    ywen
    ywen Well-Known Member
    I'm missing one liner on the front of the wheel well.. where do i acquire replacements?
  7. Feb 12, 2010 at 7:41 PM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    You can order them at the stealership. They're technically called 'skirts'.
  8. Feb 12, 2010 at 8:18 PM
    ywen
    hmm couldn't find it on toyotapartscheap.com
  9. Feb 12, 2010 at 9:30 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    can you get those clips online or at the dealer? And the splash gaurd?
  10. Feb 12, 2010 at 9:32 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    You can find them at pretty much any autoparts store..
  11. Feb 12, 2010 at 9:40 PM
    ETaco23
    Evan
    PNW
    what? the clips or the entire gaud?
  12. Feb 12, 2010 at 10:07 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    i dont have either splash guards..... the clips stay on and the material rips. are they actually important?
  13. Feb 13, 2010 at 7:08 AM
    Beau02
    Beau02 Black Taco
    Beau
    Indianapolis, IN
    My opinion would be that their a good thing to have, but not necessary. I've always assumed they keep rocks & debris from getting thrown up in there and causing problems and unwanted buildup.
    You can get both the clips and skirts at a stealership. You may be able to get similar clips at an auto parts store, but I've never looked. For the record, the Toyota Item Number for the clips is 90080-46327. Most usually have some in stock, but sometimes you'll have to order them. Like all things there, the clips are a rip-off. The last time I bought some they were $1.09 a piece!
  14. Feb 13, 2010 at 8:04 AM
    wstacolvr
    that's pretty expensive for some clips. And, the tearing of the material, as you have said, is also another problem. I guess I "prefer" to have them on my truck tho. They have kept alot of debris from getting up into where it doesn't belong (out on the trails). Well...at least for me it has been useful.
  15. Jan 12, 2011 at 11:55 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    can we use some rolled ruber or something and use that instead? And i'll just zip tie them. Does home depot sell rolled rubber or something like it by the foot??
  16. Jan 12, 2011 at 1:03 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I have fiberglass fenders so if anyone needs the stock inner fender wells I would sell for pretty much nothing. I have no need for them. They are off of a 2002 Tacoma prerunner. I made new ones for my fiberglass out of the old mudflaps :)
  17. Jan 12, 2011 at 2:19 PM
    mackattack07
    mackattack07 Well-Known Member
    william
    Jacksonville NC/Graceville FL
    99 Prerunner 3.4/2000 4Runner3.4/85 Pickup22R
    i got new pushclips from autozone i think there actually for a gm door panel but they fit tight with no problems
  18. Feb 7, 2016 at 1:15 PM
    McTeague
    McTeague Well-Known Member
    Alan
    2012 MGM Tacoma DCSB TRD Off Road
    Stock
    This is why I joined after lurking for years, to thank YOU sir! I have been screwing around with various solutions and listening to my rear inner fender wells rattle like crazy for a year now. People on the sidewalk could hear it clearly its ridiculous! Anyways, I just went out there with some zip ties and even though it does not look possible it is possible to secure the inner fender wells with zip ties and STOP THE RATTLING! Nothing better than fixing something for free since I already have many zip ties.
    THANKS!!!
