Those Tiny Annoyances
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Graffin, May 24, 2015.
  1. May 24, 2015 at 8:15 PM
    Grego67
    Grego67 Well-Known Member
    2015 4x4 V6 Tacoma
    The fact that there always seems to be cool air blowing in from the dash area, even when the a/c and fan are off. Not much of a big deal in the summer, but it can be quite annoying in the winter or in the morning before the truck is fully warmed up. My '04 did the exact same thing...
  2. May 24, 2015 at 8:18 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Start engine, -tick tick tick- put in gear -clunk- tick tick, -honda civic sound pulling out- barely touch brakes, comes to a complete sudden stop. -tick tick tick- clunk, vrooooom... however you get the satisfaction of the smog pump making its little sound when you shut it off!
  3. May 24, 2015 at 8:28 PM
    Justn868
    Justn868 Well-Known Member
    Justin
    Kansas City
    14 4x4 TRD OR
    Poor interior quality and wind noise through the drivers door seal
  4. May 24, 2015 at 8:29 PM
    Larry
    Larry CARL
    CARL
    Some of y'all should be driving different truck :laugh:
  5. May 24, 2015 at 8:43 PM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
    I don't like how my left leg doesn't fit under the left door panel armrest, drives me nuts how some vehicles angle up towards the front to give more clearance, but ours doesn't.
  6. May 24, 2015 at 9:01 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    I remember this with my 08, my 15 dosent do that anymore, its weird.
  7. May 24, 2015 at 10:22 PM
    Pigpen
    Dan
    Northwest Montana
    usafwx, your sig took me a second, but I almost laughed margarita out my nose!
    jlastic likes this.
  8. May 25, 2015 at 9:38 AM
    MeefZah
    MeefZah -----------
    Mark
    Lexington, Ohio
    2020 GX460
    Center console too high for me to receive road head and the plastic scratches when she drags her earrings on it.
  9. May 25, 2015 at 9:52 AM
    TruKnight
    TruKnight Well-Known Member
    Tru
    Arkansas
    Autobot Mall Crawler
    read build thread
    hrm lets see. the seatbelt likes to lock halfway when I pull it over to plug it in, and it does this several times. plastic scratches too, but the whole truck is made of plastic. that bird singing in the air conditioning vents, would love to kill it.
    [QUOTE="usafwx
    love that sig, I giggled. :laughing:
  10. May 25, 2015 at 10:06 AM
    Samjo
    Samjo Member
    Covington, Georgia
    15 DCSB TRD 4x4
    That's easy enough to fix. Search "Anytime Fog light Mod".
    Mine is the fact that instead of fixing an overhead console that had display problems....they just did away with it. I miss the hell out of my clock/temp display. Only clock the '15 has is in the radio, and if you use "screen off" mode......you're screwed.
