Those who's 2TR-FE left them stranded - what went wrong?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by andrew61987, Sep 26, 2016.
  1. Sep 26, 2016 at 3:51 PM
    andrew61987
    andrew61987 [OP] Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    if your 2TR-FE has ever left you stranded - what went wrong?
    I'm asking this to help myself gather spare parts for long trips.
    I married my tacoma likes this.
  2. Sep 26, 2016 at 6:19 PM
    HDMac07
    HDMac07 Active Member
    2011 Tacoma Standard Cab 4x4
    Worked as a Toyota technician for several years.. only had one TR get towed in. It blew a head gasket with over 200k miles on it and admittedly towed well over what the truck is rated for. Water pump failed, the rest was history. We put a head gasket on it and the truck is still on the road.
  3. Sep 26, 2016 at 7:52 PM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    The 2trfe doesn't fail... took mine on a 4k km trip this summer, brought spate spark plugs, cv axles and fluids. I only carry spare CVS because I'm locked in the front.
    4x2maury, Gunshot-6A, Paul631 and 2 others like this.
  4. Sep 27, 2016 at 7:05 AM
    TYetti
    Mat
    Did you drink a few beers before typing this ? You're alt blew up and the tensioner seized?
  5. Sep 27, 2016 at 7:44 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Close, I changed the squeaking tensioner pulley before it seized (forcing me to buy the entire tensioner). Just looking for good low mile alternator, now
  6. Sep 27, 2016 at 8:01 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    keep a spare serpentine... or hell replace your current serpentine and keep the old one as a spare. Thats about it really... the 2TR is a freaking bullet proof motor.
  7. Sep 27, 2016 at 8:10 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    My starter started going out at about 175k, it didnt leave me stranded per say, since i have a manual, but its something to bear in mind if you have an auto and are traveling quite a bit. I replaced mine and my alternator at the same time for preventative maintenance. Im now at 205k with no problems. I agree 100% with the comment on the 2TR being bullet proof. I run mine hard and never think twice about it
  8. Sep 27, 2016 at 8:23 AM
    jbrenn
    jbrenn Well-Known Member
    allen texas
    10 sr5
    The tensioner pulley bolt worked its way lose at 75 mph. I replaced the pulley 2 years prior. It really is a terrible design a nut that can not easily be access to change the pulley. The replacement tensioner is threaded to eliminate the problem. happened right around 100k.
  9. Sep 27, 2016 at 8:32 AM
    AJH387
    AJH387 Well-Known Member
    AJ
    Pittsburgh, PA
    '19 TRD OR DCLB
    I love threads like this. Makes me feel good about my purchase. And ya, I'd maybe keep plugs and a serpentine. Not sure what else would be useful for a long trip.
  10. Sep 27, 2016 at 8:37 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Just twice. Unrelated to engine durability.
  11. Sep 27, 2016 at 11:57 AM
    BassAckwards
    What does this mean?? Lol sorry if i missed something in prior posts, im just confused..
    cryptolime likes this.
  12. Sep 27, 2016 at 12:07 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    If the manifold air injection pump fails, does the truck go into limp mode or does it just illuminate the CEL with no functional limitations?
  13. Sep 27, 2016 at 12:21 PM
    HDMac07
    Pump failure is rare enough on our trucks that I wouldn't let it keep you up at night. They were awful about failing on the Tundra, but very seldom do they poop out on our trucks.
  14. Sep 27, 2016 at 1:03 PM
    T4RFTMFW
    I had a problem with misfires after an engine TSB.
  15. Sep 27, 2016 at 1:04 PM
    HDMac07
    Which TSB was it? If you don't mind me asking
  16. Mar 17, 2017 at 11:01 AM
    andrew61987
    I'm going to bump this to see if any others have input!
  17. Jul 20, 2017 at 7:25 PM
    GDT
    GDT Well-Known Member
    '09 Tacoma 4x4 access base 2.7l 5spd
    I'd be very interested in this info as well.
  18. Dec 10, 2017 at 8:31 PM
    andrew61987
    Bumping yet again for more info
    BassAckwards likes this.
  19. Dec 10, 2017 at 8:49 PM
    SocalTaco15
    SocalTaco15 Well-Known Member
    Glen
    Socal, Orange County
    My old first gen 2.7 had the head gasket and ceramic exhaust ring go at 187k. That was about $500.
  20. Feb 9, 2018 at 11:03 AM
    05yoter
    05yoter Active Member
    Joshua
    Connecticut
    Tacoma 4x4
    3" Supreme Suspension Lift Kit, Bilstein 5100, K&N, Curtis Tatton driveshaft, Detroit Trutrac, some other doodads...
    My 05' has a coolant leak in cyl #1. Im praying it doesnt have a cracked head, and it just needs the head gasket replaced. 228k. Other than that, I have only replaced belt, water pump and t-stat, starter, coolant bypass, valve cover gasket, and regular maintenance ie plugs, air and cabin filter, coolant flush, oil and filter etc. There were issues with the charcoal canister/evap system throwing codes but I read on TW that overfilling fuel could be the issue and so far its gone away (fingers crossed). I personally think the 2TR series is a very dependable engine, as long as its taken care of.
