Those with 285's and 6 speed!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HuntnTruk, Apr 5, 2011.
  1. Apr 5, 2011 at 3:03 PM
    HuntnTruk
    HuntnTruk [OP] Tacohead
    Kevin
    New York-not the City
    Indigo SR5 4x4
    How well does that combination interact. I would imagine that it would make first gear better for more than 5mph haha. Although I drive like a grandma with a flat, I dont want to suffer massive power loss. So Im wondering if I should just make the plunge to 285s rather than the 265 70 17's I was planning.
    What was your mpg loss also? Looking at the load range C duratracs, either size 265 70 17 or 285 70 17. I drive more than most and commute 44 miles a day.
    Convince me
    Eibachs with 5100 at zero or .85 depending on tire size.
  2. Apr 5, 2011 at 3:26 PM
    Brunes
    Brunes abides.
    Rotorhead
    I didn't take a massive hit when I swapped. It's well worth it for the bigger meats under the wheel wells imho...but it's just that. My personal opinion....
  3. Apr 5, 2011 at 3:33 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    I have the duratrac's in 285 and I notice the power loss while in 6th on the freeway but its really not that bad. The MPG difference is not too much either; I never really got good mileage anyway. I will probably go with 255/85/16 next time around for mileage and less rolling resistance/weight.
  4. Apr 5, 2011 at 3:57 PM
    jspadaro
    jspadaro Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Don't the bilsteins have to be set at 0 with the eibachs?
  5. Apr 5, 2011 at 4:25 PM
    BarefootBandit
    BarefootBandit Well-Known Member
    06 Double-Cab TRD Sport 6-Speed
    I noticed a power loss immediately after having them installed. I notice now that when I release clutch in 2nd gear at 15mph, and floor the gas, my truck shudders and sounds like it's bogged down. It used to never do that when I had 265's. When I had 265's it would throw me back in my seat.
    Def going to re-gear to 4.56 during the summer.
  6. Apr 5, 2011 at 4:44 PM
    Kauluwela
    Kauluwela Well-Known Member
    Dave
    Seattle, WA
    07 TACOMA DOUBLE CAB V6 6SPD TRD
    TOYTEC SPACER, OME 885'S, OME STRUTS, TOYTEC DIFF DROP KIT, TOYTEC CARRIER BEARING DROP KIT, LIGHT RACING UCA'S, DEALER TSB'S, OME AAL, OME SHOCKS, VISTA TOP, GROM AUDIO IPOD INTERFACE, ALL PRO EXTENDED BRAKE LINES, ALL PRO SLIDERS, FULL LIMO TINT, AMERICAN RACING MOJAVE WHEELS, WILD COUNTRY XTX 285-70-17, HI-LIFT, TOYTEC HI-LIFT SLIDER ADAPTER
    I am running 285-70-17s and like Tacoma 831 I noticed power loss in 6th gear at 60 MPH. At 75 MPH 6th gear is great. The beauty of the 6 speed is you can always.......downshift. The auto tranny's have a real problem at around 50 mph from what I hear it is hard to get up to 5th gear and they tend to jump around.
    I get about 15 mpg in the City (stoplights) and seriously get about 19-21 on the freeway (flat at sea level no traffic at 4 AM no wind), but it goes WAY down in the mountains.
    In all honesty, I would have gone with something about 1" less in diameter instead of the 285-70-17s, but that is becuase when really wailing on it, the tires do rub, more than I would like.
  7. Apr 5, 2011 at 4:47 PM
    Kauluwela
    Dave
    Seattle, WA
    I probably would have gone with some of these, commercial grade tires: http://toyotires.com/tire/pattern/m-55
    Last longer
    Narrower
    Great tread depth
    Great weight range
    But they are firking expensive!
  8. Apr 5, 2011 at 6:12 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I've got the eibachs with 5100's at .85. 285/70/17 duratracs and 6 speed
    I have no complaints with the amount of power my truck has.
    I can't really compare to how it was before since I lifted and put tires on it only a few weeks into having it.
    I get about 15ish mpg's mostly town driving.
  9. Apr 5, 2011 at 6:22 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    285 DTs are 9 pounds heavier each, and 2 cm wider than 265s (load c) so maybe a slight difference in mpgs. I lost about 3 mpgs however going from worn out hiway tread 245s to my 265 DTs, and I did weigh but I forget the difference. Perhaps 6 to 7 pounds heavier per tire. Anyway, that hurt.
