Those with 5100's @ 2.5...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WilsonTheDog, Mar 16, 2012.
  1. Mar 16, 2012 at 10:12 AM
    WilsonTheDog
    WilsonTheDog [OP] Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    Are you having trouble getting the alignment right? Just brought mine to Firestone because tires are wearing on the outside edges with the camber at .7 positive and it came back the same way. Not sure what to do because I have new tires being delivered today and need this sorted out. I guess I'll have to lower it a notch?
  2. Mar 16, 2012 at 10:16 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    What are your alignment specs
  3. Mar 16, 2012 at 10:21 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    My camber is at +.8 on both sides, I haven't noticed any premature tire wear on the outside edges of my tires. Make sure your toe is right, toe will wear tires worse than camber will. My toe is was set at .05 on both sides when they did my alignment.
  4. Mar 16, 2012 at 11:08 AM
    lonecountryboy
    lonecountryboy Well-Known Member
    I put UCA's in just to get the alignment right highly recommend putting in UCA's otherwise you have all kinds of different problems, went with a set from wheelers offroad think they ran me 420ish well worth the money I believe they were the LR's do a little search I think fat bobs had them on sale for under 400.
  5. Mar 16, 2012 at 11:51 AM
    Large
    Large Red
    Your first mistake is going to Firestone, I've had 2 visits and 2 disappointing drives home.
  6. Mar 16, 2012 at 1:13 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    My experience at firestone wasn't too bad. I go quite often because I bought the lifetime alignment. I'm about to go again next week after I install my kings. :D
    BTW OP I am at 2.5 with no problems. Try another shop that gets its share of race/track cars. Usually they know what they are doing.
  7. Mar 16, 2012 at 1:49 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I'm wondering if this is it. Toe is now .02/.05. Was .07/.07. Camber was .7/.7 and is now .6/.8.
    Bottom line, I can't have my tires destroyed in a year. I have no problem lowering it a notch of it would fix the problem.
  8. Mar 16, 2012 at 1:53 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    A few weeks back, I measured the tire wear on a members truck, who had the same Camber, and it was found that the outside tread was 4/32's less than the inside. This is due to the lift causing a loss of Camber/Caster. You need new UCA's to get the alignment right. As for the Toe causing the wear, when the Camber is too much (over .4*) the tires ride on the outside edges like so:
    This will cause more wear on the outside of the tires, than the inside.
  9. Mar 16, 2012 at 1:54 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Ok, that makes sense. Thanks.
  10. Mar 16, 2012 at 2:21 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    As usual, Chris is right. Spoke with a Toyota master tech and the caster, and it's affect on camber, is the issue. He says he thinks he can get a percent of caster back so I'll get it done tomorrow. Guy is very familiar with this issue.
    Thanks everyone
  11. Mar 16, 2012 at 2:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Keep in mind, the more Caster added, then the more Camber will be added too. So the tires will be even higher in Posative Camber.
  12. Mar 16, 2012 at 3:39 PM
    seric007
    seric007 Well-Known Member
    you either get camber perfect with shit caster or camber sacrifice with less-shit caster.
    either way, buy the new UCA if you want the problem fixed.
  13. Mar 16, 2012 at 6:46 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    I want whatever causes less tire wear. I will have to go with new UCA's for sure. Thanks again.
  14. Mar 16, 2012 at 7:16 PM
    seric007
    if you want no unusual tire wear then you're going to have to sacrifice the caster - just tell them to set the camber to 0. but, you will have some wandering. try it out, if you can live with it.. great..
    or let it drive you insane until you decide to get new UCA (currently what im doing... :annoyed:)
  15. Mar 16, 2012 at 9:13 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Sounds like a plan lol! Caster is out a good bit now so no big deal if it's a little more, I guess.
  16. Mar 17, 2012 at 2:45 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    OK so I had the alignment redone and this is totally counter to what I told them (I want camber at 0):
    Camber +1.2/+1.4
    Caster -.08/+09 (wtf!?)
    Toe +.12/+.13
    How the hell can you leave caster like that? I honestly think I'm speaking a foreign language. Obviously I need to go somewhere else.
  17. Mar 17, 2012 at 2:51 PM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    My Camber is near opposite in the rear, from the front. I simply rotate the tires front to rear every 5k miles. I've never experienced uneven tire wear, even with stock UCA's.
  18. Mar 17, 2012 at 3:10 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Sorry if I am jumping in here. What would be considered proper/healthy range in camber, caster and toe measurements?
  19. Mar 17, 2012 at 3:13 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Camber 0, Toe 0, and Caster 2.5 would be about ideal.
  20. Mar 17, 2012 at 3:37 PM
    Hairy Taco
    North of Hell
    08 TRD
    Ok, well my camber is at 1.07 left and .98 right. I am now under the impression that this is pretty far from ideal. Given that I have only 1.6" of lift over stock specs, did I get a crap alignment job?
