Those with Extang Solid Fold - Question about install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by parkp81, Jul 14, 2012.
  1. Jul 14, 2012 at 5:01 PM
    parkp81
    parkp81 [OP] Well-Known Member
    Fil
    Southern California
    I just installed my Extang Solid Fold and had a question about the latches and the adapters that came with the tonneau.
    Did you guys use those silver adapters/brackets slide onto the bed rails?
    I currently have the latches from the tonneau clipped onto the bed rails without using the silver adapters.
    Wondering if it has any long term issues, or any other problems that can arise from mounting it this way.
  2. Jul 14, 2012 at 5:56 PM
    AcadianTaco
    AcadianTaco Well-Known Member
    Vince
    N.B. Canada
    2015 AC TRD OFFROAD
    OME 885X with Bilstein 5100, Dakars with 5125, Wheeler's bumpstops, LR UCA
    I used all the hardware provided, in other word those silver pices that bolts on the the bed rails. If your tonneau cover flies off onto another vehicle you most likely will be responsable. If you use all the hardware provided and it flies off then you have a chance to blame the manufacturer. Just my $0.02 worth.
  3. Jul 14, 2012 at 8:08 PM
    parkp81
    Fil
    Southern California
    Very good point, I will probably go ahead and install the brackets. Didn't think of it in that aspect, of what could happen.
