those with Kings + Compression Adjusters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pkang0915, Oct 14, 2018.
  1. Oct 14, 2018 at 3:28 PM
    pkang0915
    pkang0915 [OP] Well-Known Member
    Bay Area, California
    2017 Tacoma DCLB OR (first time Taco owner)
    TOYTEC 2.5 kit, SPC UCA, N-fab side steps, TRD pro grille, FN FX PRO Wheels, BFG KO2S (265/70/17 C Rated), TRD Skid plate, Tyger Tonnue Cover, OVtune, Borla S type exhaust
    After a long time looking around and comparing prices I have finally come to a decision of getting Kings over other options. So my question.
    Those of you who have the kings with the adjuster on them are they worth the +$300 (front and back total +$600)?
    only off road probably 4 times a year and of course most of the rest is all road. From all my research the kings come out to be the best riding on the road. Are these adjusters really necessary (I understand they are more for fine tuning purposes) or should I save the $600 for something else down the road?
    thanks.
  2. Oct 14, 2018 at 4:06 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    If you don't do a lot of offroading, you probably don't need them in the front. The rear can be beneficial as you can stiffen them to help with whatever you hauling around.
    I've read for a lot of people its a set and forget type thing.
    pkang0915[QUOTED][OP] likes this.
  3. Oct 15, 2018 at 5:57 AM
    twitchhero
    twitchhero ___YOU BOYS LIKE___ MEX-I-CO???
    North Carolina
    2017 Tacoma TRD Off-Road
    See Profile for a full list of Modifications: *Suspension* -Total Chaos Upper Control Arms -Total Chaos Lower Control Arms -Rock Rash performace welded spindle gussets -King EXT Coilovers with adjusters (front) -King Tundra EXT Shock with adjusters (rear) -Icon RXT leaf pack (Option 2) -Timbren active off-road bump stops (front) -Timbren active off-road bump stops with U bolt flip kit (rear) -DRT cab mount relocation -DRT Shackle hangers with DRT cross member -Dobsins front leaf greasable bolts -Polyurethane front body mounts *Performance* -AFE intake (noisemaker) -JLT oil catch can -OTT Tune -Stoptech stainless steel brake lines -Power Brake D-Line kit -Extended stainless steel rear brake lines -AGM Odyssey battery -Tacoma TRD Pro Exhaust *Interior* -Window Tint -Tacoma Door Sill Protectors -Clazzio (black leather seat covers) -Dashtop Single Mount -Sound deadening material -GATOR floor mats -Cup holder hero mats -Garmin mini front dash cam -JOYING Headunit -Tacoma Kicker tweeter upgrade -Kicker KS front and rear speakers -Rear USB -Meso Customs interior lights *Exterior* -Tacoma tailgate inserts -Mobtown offroad "No drill" Bolt-on rock sliders. -All-Pro Hi-Lift bed rail mount /w Hi-Lift -Rear Diff breather relocated -Alpha REX TRD Pro style headlights -Baja Design squadron sport (Amber fog lights) -Total Chaos Fabrication bed stiffeners -Window Deflectors (AVS) -TRD Pro Grille -Summit DAKAR (BRONZE) -Toyo Open Country R/T Trail (35x12.50 R17) -Sequential turn signals -Softtopper (black) -Toyota Bed Mat -Vinyl wrapped tail gate (black) -C4 high clearance fender liners -C4 High clearance Rock Runner rear bumper w/ Baja Designs S1
    https://www.tacomaworld.com/threads/king-compression-adjusters-worth-it.566779/
    I asked this question in September. If you're only going to go off-road about 4 times a year you also need to ask your self "Are Kings worth it?". If you read the thread people who have kings with and without adjusters their opinions are almost split right down the middle. If you are going to spend that type of $$$ on suspension then I would go with the adjusters. Tw members with adjusters have also said they set it and almost never change it and sometimes forget they have it. I decided to go with the adjusters and honestly its still to early for me to tell you if they are worth it. I've done some light off roading and hauling but nothing to the point where i need to air down and make suspension adjustments. They only thing I can suggest is really look and see if you need Kings if the answer is yes then I would wait for a 4th of July sale or Labor day sale and you can get a some awesome savings and pull the trigger on a set Kings with adjusters and save yourself a good chunk of $$$.
