Those with Manual Transmission...why?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron172, Oct 29, 2020.
  1. Mar 26, 2021 at 1:56 PM
    #681
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    130k and only get chatter on cold damp/wet days for 1st half hour or so.
  2. Mar 26, 2021 at 1:57 PM
    #682
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That doesn't turn it off on mine. I know that I must be stopped for the TCS to turn off with the long press.
    Junkhead and shakerhood like this.
  3. Mar 26, 2021 at 2:00 PM
    #683
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    When you stop at a redlight you have to get moving again. You can start off in 2nd and not up shift if you want.
  4. Mar 26, 2021 at 2:02 PM
    #684
    Dirtridercrf250
    Burn 1st and half of 2nd with 295s lol
    Junkhead and tonered[QUOTED] like this.
  5. Mar 26, 2021 at 2:05 PM
    #685
    stuka
    stuka Well-Known Member
    21 Taco TRD Pro 6 speed
    I discovered that the other day, long press does nothing while moving and you get that auto LSD light.
    Well, here's the answer.
    Apparently I don't have it, I guess I wasn't on a steep enough hill.
    https://www.tacomaworld.com/threads/what-is-your-experience-with-hill-start-assist.459729/
  6. Mar 26, 2021 at 2:08 PM
    #686
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. While moving it is all equivalent to the short press.
    And, yes. No HA on MT ORs and Pros. The ATs ORs and Pros have the goofy HA. It pumps the ABS after they're already rolling back and doesn't stop the roll. That's messed up.
    The other crazy thing is that if the ATs are not completely stopped before grabbing drive, they will stall. Some ECU function.
  7. Mar 26, 2021 at 6:39 PM
    #687
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    I have to back and turn down a steep driveway (10’ drop in 30’) and towards the end the brakes make a rattle sound and momentarily let go, is this the ABS system? It’s fucking annoying.
  8. Mar 26, 2021 at 9:29 PM
    #688
    POW HOUND
    POW HOUND No friends on a powder day
    Idaho
    2020 Manual Trans Silver Sky
    Why do automatics have so many problems then?
    :bananadance:
    doublethebass likes this.
  9. Mar 26, 2021 at 9:40 PM
    #689
    mabepossibly
    mabepossibly I know enough to make an ass of myself
    Andrew
    Albany, NY
    2021 TRD OR Manual
    Skids, Sliders, Lights
    They are tuned to optimize EPA tests, not user experience. People buy cars off of mpg stats and then bitch about how they got there. Toyota (and every manufacturer) does it because buyers reward them for it.
  10. Mar 26, 2021 at 9:59 PM
    #690
    Fire
    Fire Well-Known Member
    Humboldt County
    2021 Toyota Tacoma with Poverty Package.
    Steering wheel
    They don’t have problems from my own perspective. I drive in S5 and ECT. If that was the default setting I’m sure there would be far less complaints. With muscle memory I do this without even thinking. Even with my M4 MT I still have to make adjustments before I take off due to ridiculous stock settings that can’t be fixed even with a tune.
  11. Mar 26, 2021 at 10:03 PM
    #691
    BigBlueTexas
    BigBlueTexas Well-Known Member
    Jason Im getting old and I don't know what a S5 and ECT is. Can you help me out ? Thx.
  12. Mar 26, 2021 at 10:07 PM
    #692
    Fire
    Humboldt County
    Steering wheel
    Shift to S mode. Shift down to S5 or up to S5 then hit the ECT button. Drive.
  13. Mar 26, 2021 at 10:27 PM
    #693
    BigBlueTexas
    Ok I'm really not sure if your messing with me because I really don't know what "S mode" and "S5" is. ECT button ? You lost me friend. Do you mean like shifting gears from current gear to 5th gear ("S5") ? With or with out the clutch because I have done both (Some of u old timers may remember this little trick....hee hee hee). I have done this from 3rd gear to 5th, but only when I'm going downhill, like getting onto the Interstate when the on ramp is on a steep downslope. Please explain.
  14. Mar 26, 2021 at 10:29 PM
    #694
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    He's talking about an automatic. Shifting to S5 limits the top gear if the transmission to 5th and ECT is a button that changes shift mapping in the auto. Stuff we don't have to worry about by doing it ourselves.
    POW HOUND and Fire like this.
  15. Mar 26, 2021 at 10:49 PM
    #695
    BigBlueTexas
    In the beginning, God made the H pattern transmission. It consisted of three forward gears and one reverse gear. The engraved H pattern was displayed on the shifter knob, in order to teach future drivers how to properly drive a pickup truck; ie; the top left of the letter H was the first gear; the bottom left of the H was 2nd gear; the top right of the H was 3rd gear, and the bottom right of the H pattern was R for reverse. When properly applying the clutch pedal while shifting gears, the proper speed and traction is attained to control the vehicle. Through the years, additional gears were added thus expanding the “H” pattern Manuel transmission. I hope this helps ya understand because it is now past midnight and my fingers are dead from all this typing.
    JDSmith and SilverBulletII like this.
  16. Mar 26, 2021 at 10:51 PM
    #696
    BigBlueTexas
    Oh. I didn't know that. Sorry. So that's what automatic gears are called these days ?
  17. Mar 26, 2021 at 11:13 PM
    #697
    Fire
    Humboldt County
    Steering wheel
    sorry I should have seen you had a MT in your profile. You’re good. Enjoy
  18. Mar 26, 2021 at 11:39 PM
    #698
    sailingtoweather
    sailingtoweather Member
    Michael
    SF Bay Area
    2021 Tacoma Access Cab TRD Offroad
    DD Selective Yellow Sport Fogs, Meso Customs Stage 1 Taillights, Daveeasa DIR Mod. Vagabond Drifter Camper.
    As a teenage new driver my parents failed at teaching me to drive MT. A friend with a red 1987 4WD Toyota Truck explained/taught it in a way that made sense to me, and gave me the confidence to have my first car be a MT. I LOVE driving MT.
    For 25 years I've only owned MT vehicles. Now I was faced with wanting a new Access Cab Tacoma to replace my 2001 extended cab, and needing a 6 foot bed. They are only offered in AT.
    Ive now come to terms with the AT. A big reason is my girlfriend can drive manual but isnt confident, so that left me driving 10 to 12 hours at a time on overland camping trips. Also, driving MT offroad in tight, sketchy situations is more difficult than with AT.
    Finally I realized that it just makes sense to have a heavy overlanding truck, driven long distances on highways until getting on dirt, driving shared with an unconfident girlfriend, and in sketchy offroad situations to be automatic. But! any other vehicle I buy will 100 percent be manual. Because I love driving MT.
    BC Hunter likes this.
  19. Mar 26, 2021 at 11:40 PM
    #699
    POW HOUND
    Idaho
    I understand why and how marketing works with the autos, maybe that's a downfall to the automatic trans in itself? I was just poking at the guy who called us cavemen haha
    BigBlueTexas likes this.
  20. Mar 26, 2021 at 11:40 PM
    #700
    Tehkoema
    Tehkoema Well-Known Member
    Ottawa, ON
    2024 TRD Sport 6MT
    I get the appeal and would love to own a MT but I never properly learned and how the hell am I going to now. Last time I tried I was in highschool, the constant stalling out and looking like an asshole in my neighborhood left a bad taste in my mouth.
    Definitely a bucket list thing but who has the time.
    POW HOUND likes this.
