Those with Manual Transmission...why?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron172, Oct 29, 2020.
  1. May 6, 2021 at 8:48 AM
    #1021
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Negative sir, stands for rocket mode.
    shakerhood and Green Jeans like this.
  2. May 6, 2021 at 9:32 AM
    #1022
    TacoMacs
    TacoMacs Well-Known Member
    2020 Tacoma TRD Off Road 6 speed manual
    Icon Stage 2 lift 32" KO2s on stock wheels RCI Sliders and rear diff skid CBI overland bars for RTT Prinsu Rack
    Because driving is an experience. MT adds to that experience.
  3. May 6, 2021 at 11:26 AM
    #1023
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Waiting to get my license it wasn’t an auto that I was anticipating. Nowadays I hear that more kids don’t even look forward to it at all.
    cosmicfires and tonered like this.
  4. May 6, 2021 at 11:53 AM
    #1024
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
  5. May 6, 2021 at 12:18 PM
    #1025
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Some would like to experience as little as possible. It is just too stressful. :)
    What if the gearshift lever happens to just break clean off!! - what do you do then, eh??? - you are stuffed! :eek:
    - Even table salt is much too spicy!
  6. May 6, 2021 at 1:09 PM
    #1026
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I had a shift rod connector break one time, only had 3rd and 5th gears but was able to drive it home.
    Junkhead likes this.
  7. May 6, 2021 at 1:21 PM
    #1027
    ret42
    ret42 Well-Known Member
    VA
    Cement 2021 TRD OR 6MT
    Just to clarify, this isn't completely true. S mode simply caps the top gear the transmission can be allowed to shift into. If you put it into S4, you're not locking it into 4th gear, you're telling the transmission it can shift from 1st to 4th, but you're locking out 5th and 6th. This doesn't change your point when applied to the example you're responding to, but I still do think it's an important distinction.
  8. May 6, 2021 at 1:29 PM
    #1028
    GarlicFarts
    GarlicFarts Bertolli Roberto
    Lil Rhody
    2020 White DCSB TRD OR
    SOS bolt-on sliders In-cab sleeping platform J-Dub IFS Skid
    The problem is it defaults to S4, when I'd really like to go from 6th to 5th ahead of a hill, pain in the dick. I have read some people (and I do it myself a lot too on varied terrain highway trips) leave it in S5 all the time. 5th is still an overdrive gear at a good ratio for driving in hilly highway sections and flats, and doesn't try to hunt to 4th all the time from 6th. That's the gear hunting - dropping out of an overdrive gear into 4th, then back up to the tall 6th ASAP, then back out of overdrive when it needs powahhh
  9. May 6, 2021 at 1:57 PM
    #1029
    ret42
    VA
    Yep, and that's where the distinction between putting the transmission in a gear and putting the transmission into S mode becomes significant. I am not inconvenienced by climbing a most hills in 4th gear at 40 MPH in my MT, but with an auto in drive it would slow down to about 35 MPH, then drop to 3rd, accelerate to 45, shift back into 6th (I don't know why I'm using cruise at 40 mph in this example, but I am). Putting it into S4 may reduce the gear hunting as you're not going up into those overdrive gears at 40 mph, but I'd wager it's still kicking you down to third pretty frequently.
    Junkhead and doublethebass like this.
  10. May 7, 2021 at 6:19 AM
    #1030
    TacoMacs
    What if we get hit by a buss? What if I get a quarter stuck up my nose? heh.
    cosmicfires likes this.
  11. May 7, 2021 at 6:21 AM
    #1031
    barf
    barf Petter of Dogs
    Barf
    WNC
    2019 m/t TRD OR DCSB
    OME Lift Viper Cut
    buss
    /bəs/
    BUSS
    INFORMAL•ARCHAIC
    noun
    1. a kiss.
    verb
    1. kiss.
      "he bussed her on the cheek"
  12. May 7, 2021 at 6:40 AM
    #1032
    TacoMacs
    Thanks. It is VERY important to point out when someone misspells a word on the Internet in a forum. Thank you for performing your civic duty appropriately. I'll go flog myself.
  13. May 7, 2021 at 6:48 AM
    #1033
    Eklectik78
    Eklectik78 Well-Known Member
    AJ
    Arvada, CO
    2018 Tacoma TRD Off Road
    1" level kit
    Same :thumbsup:
  14. May 7, 2021 at 6:53 AM
    #1034
    barf
    barf Petter of Dogs
    Barf
    WNC
    OME Lift Viper Cut
    Clearly you have a stick up your ass. Instead of having a laugh, your anus started bleeding. Might want to get that checked out.
  15. May 7, 2021 at 8:42 AM
    #1035
    TacoMacs
    Maybe! I've seen all sorts of posts with misspelled words. I don't point them out to the poster. But hey, if that's your thing then knock yourself out there, sport. Have a great day kiddo.
  16. May 7, 2021 at 8:43 AM
    #1036
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Right on sir!
    :headbang:
    Eklectik78[QUOTED] likes this.
  17. May 7, 2021 at 8:47 AM
    #1037
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    3rd gear would have been an interesting take off, but possible for sure.:rolleyes:
    The reverse in my Civic just stopped working. I was in my early 20s so broke of course, so i drove like that for about 8 months haha! I had to plan where i was gonna park, honestly it wasnt that bad at all.
  18. May 7, 2021 at 8:58 AM
    #1038
    ret42
    VA
    My Supra's original trans stopped going into 2nd at one point so I was constantly 1st to 3rd. Eventually 3rd went as well, so I was 1st to 4th. Man I do not miss that. The previous owner(s) must have savagely abused that poor R154.
    Fortunate college kid - I had the money to pay for a Supra, but not enough money to repair it. :rofl:
  19. May 7, 2021 at 9:42 AM
    #1039
    shakerhood
    Southern Ohio
    Yeah my house was up this steep little street that l would usually go up in 1st gear, had to fly up in 3rd. Was able to temporarily repair it until l got a new piece for it.
    Junkhead[QUOTED] likes this.
  20. May 7, 2021 at 9:46 AM
    #1040
    MallRoad2wd
    MallRoad2wd Well-Known Member
    Alex
    2020 Toyota Tacoma SR5 2WD SuperWhite
    You get used to it. I like manual transmission because I feel I can have more control over my vehicle, plus its really fun. The added benefit is that some thieves out there don't know how to drive a manual so its a bit of a safety feature as well. But mostly is for the control of the truck. Manual Landcruisers are super fun to drive I had a 2008 90 series.
    DBCoop, cosmicfires, Junkhead and 2 others like this.
