Those with Manual Transmission...why?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cameron172, Oct 29, 2020.
  1. Aug 30, 2021 at 6:58 PM
    #1281
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    It’s the old school key type No fob. No flip. Just a stubborn piece of metal that, when you’re aren’t driving, and sitting, it’s jabbing your ass cheek.
    02Duck likes this.
  2. Sep 14, 2021 at 8:11 AM
    #1282
    manncura
    manncura Well-Known Member
    2020 DCSB 6MT Sport
    Quick question MT peeps. What do you all do when you are stopped, in neutral, and go to put it in first and surprise! it won't let you in the gate? Am i doing something wrong that this sometimes happens? I learned MT on my high school and college Accord 20 years ago, and finally back in one,,,so I am no expert, but i figure 20,000k in, maybe should try to improve here and there :). Thx!
    SilverBulletII likes this.
  3. Sep 14, 2021 at 8:14 AM
    #1283
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Just reclutch and it ought to spin the gearing just enough to let you back into 1st. Worst case, shift to 2nd and then back to 1st.
  4. Sep 14, 2021 at 8:20 AM
    #1284
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It is not a gate, but that the noses of the splines are just perfectly aligned the wrong way. :D
    The fastest thing for me is usually to slap it into 2nd and then go back to 1st.
    The best perma fix that I have seen is an MT fluid swap. Going to Redline MT-90 or the highly rated Motocraft stuff (never used it) is a great fix with other good benefits. Once shifts get notchy or I start to get cockblocked out of 1st, usually after about 40k, it is an indicator that it is time for another swap.
    I changed the factory fluid at 7,000mi because of this issue and a UOA indicated some negatives about the Toyota fluid. See @Omar RVA 's thread for that info.
  5. Sep 14, 2021 at 8:41 AM
    #1285
    StandardTaco
    StandardTaco Well-Known Member
    Nebraska
    2020 MGM TRD-OR 6MT
    That's been a rare occurrence for me, but when it has happened pulling the shifter to 2nd then pushing back to 1st has always worked.
    SilverBulletII and Pablo8 like this.
  6. Sep 14, 2021 at 8:56 AM
    #1286
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    This happened with the factory fill, once at a stop light, going into 2nd then 1 BARELY worked. After a couple times I was getting cranky. About the same time I swapped all the fluids, went with Amsoil MTG in the MT. Has not done it in 12K+ miles since.
  7. Sep 14, 2021 at 9:00 AM
    #1287
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    When did you end up changing the fluid? I'm a few hundred miles shy of 15k currently, but so far so good.
  8. Sep 14, 2021 at 9:01 AM
    #1288
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    It is normal. If I pull into a parking spot and shut down the truck it is a 50/50 whether the shifter will go into a gear or not.
  9. Sep 14, 2021 at 9:04 AM
    #1289
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    In a parking lot, esp when waiting on the fam, I will row the gears until all seven are lined up. o_O
    I might be making engine sounds as I do it.
    :anonymous:
  10. Sep 14, 2021 at 9:06 AM
    #1290
    StandardTaco
    Nebraska
    2020 MGM TRD-OR 6MT
    I usually pick my nose, but maybe I'll try that next time I'm waiting
    RustyGreen, cosmicfires, utfi and 2 others like this.
  11. Sep 14, 2021 at 9:09 AM
    #1291
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For both, as long as no one is looking, it's fair game.
  12. Sep 14, 2021 at 9:14 AM
    #1292
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    I have an auto, I no longer trust my seventy-seven year old left knee actually work a hundred times in a day. I hope my right one holds up.
  13. Sep 14, 2021 at 9:18 AM
    #1293
    BigBlueTexas
    BigBlueTexas Well-Known Member
    Better to pick one's nose then to pick one's a$$.....
    Seriously, like others have said, when this happens to me, I go to 2nd gear then right back into 1st. Also, wait for the engine rpm's to slow down. :burnrubber:
    StandardTaco[QUOTED] likes this.
  14. Sep 14, 2021 at 9:59 AM
    #1294
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    When you get to reverse, do you make the wah wah wah reverse gear noise?
    doublethebass and cosmicfires like this.
  15. Sep 14, 2021 at 10:02 AM
    #1295
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Straight cut gears for the win! Like racecar speeled backwards. :cookiemonster:
  16. Sep 14, 2021 at 10:09 AM
    #1296
    Jurist
    Jurist Active Member
    Tom
    2021 TRD Offroad 3.5 M/T
    I did it because I hated how the automatic transmission searched for gears when I did the test drive.
    and everything I could read and find out said that the manual transmission was pretty much bulletproof.
    and now when I want to pass someone on a 2 Lane Highway that’s driving 52 miles an hour in a 55, I just shift into third gear hammer on the gas and I accelerate all the way to 85 miles an hour In a heartbeat.
  17. Sep 14, 2021 at 10:16 AM
    #1297
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    The whole downshifting thing has been eye opening for me. I came from a bunch of manuals with Heeps of torque. The other day I dropped into 4th and sped past a bunch of cars on “the grade”. Including a 3rd gen taco. I’m just hoping that guy was like what? How?
  18. Sep 14, 2021 at 10:16 AM
    #1298
    MoonKnight
    MoonKnight Well-Known Member
    chris
    Oromocto New Brunswick
    2018 silver Tacoma TRD or
    manual trans - why ?
    because its the Millennial security system
  19. Sep 14, 2021 at 10:17 AM
    #1299
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    You know…. If your gonna be stealing cars, you should know how to drive a manual.
    doublethebass likes this.
  20. Sep 14, 2021 at 10:19 AM
    #1300
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :notsure:
    Is that like The Anarchists Cookbook? :poking:
    I think it has been proven in many instances that the crims struggle with ATs also. :cookiemonster:
    Anybody got a GIF that I could borrow?
