Those with the TRD skid plate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by davidf, Sep 20, 2015.
  1. Sep 20, 2015 at 11:33 AM
    davidf
    davidf [OP] Well-Known Member
    David
    Texas
    Currently in the market.
    About to install my TRD skid plate. It is a Pre runner so no plans of going off road. I would like to remove the fact heavy skidplate but the instructions say not to. Will it fit without the fact. skid?
  2. Sep 20, 2015 at 11:47 AM
    skippermike
    skippermike Well-Known Member
    San Diego
    08 SR5 4x4 w/off road mods
    3" Icon lift, coilovers, reservoir r. shocks, AAL, Icon UCA, 17" Eagle wheels, extra electrical, inverter, ICOM VHF
    I installed my TRD front skid plate over (outside) the factory plate on my 4WD SR5. Then installed the further back skid plate. Both fit fine. The factory skid plate was kinda thin, but I thought it would augment the thicker TRD plate. I've scraped and bounced off stuff - though not rock crawling - and just have scrapes on the skid plates.
  3. Sep 20, 2015 at 11:49 AM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    Heavy factory skid?
  4. Sep 20, 2015 at 12:43 PM
    davidf
    David
    Texas
    Sorry, I meant the factory skidplate is heavier than the TRD. Since I do not go off road, I figure removing a little additional weight could'nt hurt. I assumed the factory plate was heavier than it looked.
  5. Sep 20, 2015 at 12:56 PM
    tacholio
    tacholio Active Member
    Columbus, IN
    '13 Access Cab TRD Sport 4X4
    It can be made to work leaving off factory skid - if you haven't had a chance yet compare mounting points current to TRD and you will see what I mean - have some extra washers or spacers handy as you may want to mimic the thickness of the stock in order to get desired spacing of the TRD front edge to the bumper
  6. Sep 20, 2015 at 1:03 PM
    TacoRph
    TacoRph How 'bout them Dawgs
    2015 MGM TRD OR 4WD
    I have a 4WD Off Road, and I installed the TRD accessory skid plate as per the instructions. I left the factory plate on. It took me about 30 minutes to install the TRD plate, because I had a little trouble getting the bolts to line up just right.
  7. Sep 20, 2015 at 2:17 PM
    davidf
    David
    Texas
    Thanks guys, you've supplied me great info. :thumbsup:
  8. Sep 20, 2015 at 2:21 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    If you're hoping for better milage I doubt removing the factory skid will make a noticeable difference.
  9. Sep 20, 2015 at 2:33 PM
    Dropitmore
    Dropitmore Panda Man
    Andy
    Downey, CA
    2013 TRD McDouble Cab
    Mall Crawler Edition
    I had removed the factory skid and installed just the TRD skid plate once, but I wasn't comfortable with how thin the TRD skid plate was alone so I added the factory skid back and combined it with the TRD skid plate on top. Better peace of mind for me and I'm not much of an offroader either. If you don't have the hardware that comes with it, make sure to note that the two bolts at the top of the skid should be longer than the two at the bottom or else it won't spin thru enough to grab both the TRD skid and the factor skid. A 1/4 inch longer should do the trick. You can find them at Pepboys. That's where I got mine.
  10. Sep 20, 2015 at 2:41 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The factory plates only weigh a few pounds and so you wouldn't save much weight and having them on gives you a cleaner botter for airflow and prevents road debris from bouncing up into important parts of the drivetrain.
  11. Sep 20, 2015 at 8:31 PM
    sonofarobin
    sonofarobin Well-Known Member
    Southeast USA
    '22 SR 4X4 3.5L MGM Access Cab
    I didn't even know you were supposed to leave the factory skid plate on!? I've had just the TRD skid plate on for over two years now.
    Guess I need to start reading the instructions better...:annoyed:
