Thought I could get away with it
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GuacTaco619, Feb 17, 2021.
  1. Feb 17, 2021 at 7:26 PM
    GuacTaco619
    GuacTaco619 [OP] Active Member
    Chula Vista
    2021 4Runner SR5P
    New to the forum, new to Tacoma’s and trucks in general. Please forgive me. I read that I couldn’t and also that I could fit them without issue.. So after all that I decided to put 285/75r16 on my truck. I was naive and thought I was going to be able to avoid the rub but nope. I’m getting a bit in the middle of rear wheel well. What is my best route to get rid of this issue (other than downsizing)? I’ve read about cmc, pinch weld, etc but I’m an unsure of what the details of these procedures are. Anybody local in San Diego willing to lend a helping hand? You will be handsomely rewarded :cheers:
    StayinStock likes this.
  2. Feb 17, 2021 at 7:29 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
  3. Feb 17, 2021 at 7:31 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    I assume you installed them on stock wheels? Yeah, I have heard both sides of this. Can you tell how bad it rubs? Is it barely or undrivable? I wonder if a spacer lift for now would work. Like a 2 inch
  4. Feb 17, 2021 at 7:33 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    GuacTaco619[OP] likes this.
  5. Feb 17, 2021 at 7:37 PM
    GuacTaco619
    Chula Vista
    2021 4Runner SR5P
    I should have added that, sorry! I’m on 16x8, 0 offset methods. Also running 5100s up front to level.
    It’s not terrible. I’ve only heard it coming in to my driveway basically at full lock. Little worse on the driver side than passenger.
  6. Feb 17, 2021 at 7:37 PM
    GuacTaco619
    Chula Vista
    2021 4Runner SR5P
    StayinStock[QUOTED] likes this.
  7. Feb 17, 2021 at 7:38 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    :hattip:
  8. Feb 17, 2021 at 7:40 PM
    RatDaddy
    Roy
    None
    I saw a few people on line say how they work with stock wheels. Maybe try that first?
  9. Feb 17, 2021 at 7:50 PM
    medic2230
    Murph
    Bama! Roll Tide
    You running any UCA’s and maxing the caster out?
  10. Feb 17, 2021 at 7:51 PM
    GuacTaco619
    Chula Vista
    2021 4Runner SR5P
    I love the wheels haha. I may just go back down to 265/75 and avoid a headache. Unless there’s any easy solution
  11. Feb 17, 2021 at 7:51 PM
    GuacTaco619
    Chula Vista
    2021 4Runner SR5P
    Damn he’s 2 hours north of me :(
  12. Feb 17, 2021 at 7:52 PM
    GuacTaco619
    Chula Vista
    2021 4Runner SR5P
    Just stock ucas. Not sure on the caster
  13. Feb 17, 2021 at 7:53 PM
    RatDaddy
    Roy
    None
    Try thosectires on your stock wheels. It may solve the problem for very little expense
  14. Feb 17, 2021 at 7:53 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Doesn't hurt to ask. I (think) he travels around some. Not positive about that tho. He's a good dude.
    Junkhead likes this.
  15. Feb 17, 2021 at 7:55 PM
    medic2230
    Murph
    Bama! Roll Tide
    The alignment on a lifted truck is different than a stock one. Unless you tell them where to set the alignment you’re going to rub because they’ll do a factory alignment on the truck. A lifted alignment will not be in the “green”. For a second gen those numbers were 3 on caster 0 on camber and 0 on toe. Believe the third gen is running a little over 3 on caster.
    RatDaddy likes this.
  16. Feb 17, 2021 at 7:57 PM
    medic2230
    Murph
    Bama! Roll Tide
    If your wheels push the tire out any you’re going to rub on turns because the arc of the tire is wider with the wheel pushed out any.
  17. Feb 17, 2021 at 8:01 PM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    Get ready to spend some money. Ucas and cmc will be needed, and a good alignment.
  18. Feb 17, 2021 at 8:02 PM
    medic2230
    Murph
    Bama! Roll Tide
    He may be able to get away with just UCA’s and a good alignment.
  19. Feb 17, 2021 at 8:09 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  20. Feb 17, 2021 at 8:19 PM
    Bishop84
    Bishop84 Well-Known Member
    Knowing what I know now, I wouldn't hesitate to start with CMC and work from there. It's so cheap and it really isn't easy to spot unless you're looking for it.
