Thought I had squeaky leaf springs....WRONG!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by afwxguy, Jun 3, 2019.
  1. Jun 3, 2019 at 4:55 PM
    afwxguy
    afwxguy [OP] Member
    Black 2012 DCSB OR
    3" Lift OME Springs on Bilstein 5100s, Camburg UCAs, Deaver AAL, K&N CAI
    Hey everybody. I had chirps and squeaks coming from the rear of my tacoma for the last three years. Based on what i found here, I assumed the culprit was the leaf springs due to the volume of posts regarding that issue. I had tried spraying graphite lubricant all over my leaf springs in an effort to stop the squeak, but to no avail. Tonight, I decided to have my wife help me find what was squeaking. I lowered the tailgate and had her push on it to make the truck bounce while I crawled under to look for where the squeak was coming from. After some crawling around it sounded like the sound was coming from in between the two sets of leaf springs. I thought that was odd since there aren't really any suspension parts there, just the spare tire. So I put some pressure on the spare....the squeak stopped! I went in the cab and pulled out the spare kit and tightened up the spare tire hoist by 1/4 to half a turn. I did the bounce test and there was silence. Then I took it through the neighborhood (which has speed bumps galore) and still no squeaks or chirps. It's like I'm driving a new truck! Hope this will help at least some of you guys out.
  2. Jun 4, 2019 at 6:42 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Good catch!
  3. Jun 4, 2019 at 8:09 PM
    CStafford
    CStafford Well-Known Member
    Cameron
    2006 Silver Tacoma TRD Access
  4. Jun 10, 2019 at 3:33 PM
    afwxguy
    afwxguy [OP] Member
    Black 2012 DCSB OR
    Stryker420 likes this.
  5. Jun 10, 2019 at 3:58 PM
    CStafford
    Cameron
    After re-reading it sounds like you were able to replicate the noise pretty easily by bouncing the truck on the rear end? I can't replicate with this so might he a different issue.
  6. Jun 10, 2019 at 4:02 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Bouncing the truck,huh.....when the trucks a rockin’, Don’t come a knockin’
  7. Jun 10, 2019 at 4:25 PM
    SixSpeedTaco
    SixSpeedTaco Active Member
    07 Tacoma TRD OR DCSB
    Nothin But Dust
    Try looking at your hood hinges mine were making a squeaking kinda like your video. Could try oiling them or stuff a rag underneath to keep pressure on them. I stuffed foam underneath to put pressure and that fixed mine. Mine was a little annoying squeak from the front right dash when hitting any little bump.
  8. Jun 12, 2019 at 8:03 AM
    CStafford
    Cameron
    Interesting, i'll take a look at that next time in investigating. Thanks!
  9. Jun 12, 2019 at 8:22 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    OMG, you might be onto something for me! I have had a lil squeak that sounds like its coming from behind the steering wheel, behind the vent, and a hood hinge could be it cus i have gone through EVERYTHING i can get to behind the dash!
  10. Jun 13, 2019 at 2:41 PM
    Phich
    Phich Porkchop Express
    San Antonio
    2017 TRD Off Road tuned to KDMax perfection
    Six Demon Bag
    After installing OME Dakar leaf springs (2" lift) I had a serious case of squeaks even though I greased the fittings liberally.
    My squeak was definitely not the spare tire, rather the plastic discs between the leafs.
    Now I'm not a user of engine/oil/gas additives (aside from Seafoam which is excellent) but I heard about the extreme lubricity and hydrophobic properties of Motorkote and decided to buy some ($15). Personally, I wouldn't put it in my engine, but I put it in a spray bottle, and sprayed it on my leaf springs (hinges and discs between the leafs) and haven't heard a peep out of them in over two months. Rain, mud, dirt, power washes, no problems, no squeaks. I'm sure they will eventually squeak again when the Motorkote wears off, but then I'll just respray.
    Amazing how the squeak has no effect at all on ride or performance, but the psychological effect of having no squeaks just makes the truck feel better.
    rosswood and PzTank like this.
  11. Jun 13, 2019 at 2:43 PM
    DrFunker
    DrFunker Well-Known Member
    :woot:
    I think you deserve a celebratory beer or two.
    tacomataco2, jeminyned and Phich like this.
  12. Jul 10, 2019 at 7:26 AM
    CemenTaco2019
    CemenTaco2019 Active Member
    2019 DCSB SR5
    None yet
    Having the same issue with only 2k on the odometer. Can hear it when I shut the doors or have the rear window open. Had a flat tire first week I had the truck and had to get the spare off so hopefully this is the cause of my squeaking as well.
  13. Oct 5, 2019 at 5:10 PM
    robfox
    robfox Well-Known Member
    Nice! I gotta diagnose my squeaks too.
  14. Oct 5, 2019 at 7:05 PM
    winkel
    Corydon, IN
    My hood latch on my old T-100 would squeak if I didn't keep it greased.
  15. Oct 7, 2019 at 8:04 AM
    CStafford
    Cameron
    Just an FYI to everyone: the squeak I am getting is related to my UCA on my driver side. Bushing is bad is what I was told. Waiting on a set of 3rd gen take offs to replace it all at once.
  16. Oct 7, 2019 at 8:09 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    These trucks are squeak and clunk machines. It makes you feel like you are driving junk.
    I have a clunk in the steering wheel that nothing that has been done will take care of.
    eon_blue likes this.
  17. Oct 7, 2019 at 9:25 AM
    IwasDacapsterAz
    IwasDacapsterAz Well-Known Member
    Cap
    14 4w4 Taco Access
    Bamf and Bilstien
    Every truck I have drove from 38 on has squeak's and pops. It's the nature of trucks.
    12TRDTacoma[QUOTED] likes this.
  18. Oct 7, 2019 at 9:26 AM
    eon_blue
    Azusa, CA
    Try driving a 1st gen, lol :laughing: Clunk city though I can't entirely blame the truck, it holds up to a fair amount of abuse. But yeah at some point you just have to accept the squeaks and clunks, every now and then I get intent on trying to solve one though.
  19. Oct 7, 2019 at 9:37 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yeah I mean you can only go so long without dealing with the clunk. These trucks are built tough, but sloppy.
    nd4spdbh and eon_blue[QUOTED] like this.
  20. Jul 27, 2021 at 2:59 PM
    Ledtoma11
    Ledtoma11 New Member
    Galen
    2019 Tacoma TRD
    Great work! I was getting ready to place an order for friction pads when I noticed your reply. I would’ve never thought of this, but I had a tire replaced a few weeks ago. Unfortunately said tire had to come from the warehouse the next day. The shop pulled and installed my spare and said see ya in the morning. Apparently they did not tension the chain enough when they put the spare back. Like you, I only turned a 1/4 of a turn and heavenly bliss bloomed…Thx again!
