Thoughts and opinions on THIRD BREAK LIGHT set-up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NavyDiver72, Jul 12, 2019.
Which configuration would be better?
  1. All 4 RED KC Cyclone lights - ALL BREAK, NO CARGO LIGHTS
    15.0%
  2. Two RED KC Cyclone lights and Two White Diffused KC Cyclone lights
    60.0%
  3. Nah, leave it stock
    25.0%
  1. Jul 12, 2019 at 6:58 PM
    NavyDiver72
    NavyDiver72 [OP] I DO ALL MY OWN STUNTS
    Rick
    Millington, TN
    2006 DCLB TRD Sport PreRunner
    Any Mods? One. Maybe two, tops...
    Hello everybody, so I have a few KC Cyclone lights and did not know what to do with them.
    I ended giving @MESO a call and the USPS dropped this at my door.
    Should I color key the housing OEM 1E7 Silver Streak Mica OR keep it flat black??
    Now, for the reason of this post. The poll, should I go All 4 RED KC Cyclone lights - ALL BREAK, NO CARGO LIGHTS
    Or should I go Two RED KC Cyclone lights and Two White Diffused KC Cyclone lights
    Any help and/or opinions will be greatly appreciated.
    Thanks!
    Rick
  2. Jul 12, 2019 at 7:14 PM
    caribe makaira
    Caribbean, Puerto Rico
    2 red in the middle, white on the ends...
    TRDSport10 likes this.
  3. Jul 12, 2019 at 7:23 PM
    NavyDiver72
    Rick
    Millington, TN
    Thank you sir!
  4. Jul 12, 2019 at 7:27 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Red inside, 2 white outside. Having the whites further apart increases your light spread.
    I’d also paint the PCB boards black inside the cyclones, make them not stand out as much.
    Color match might look ok, but can never go wrong with black accents.
  5. Jul 12, 2019 at 7:30 PM
    NavyDiver72
    Rick
    Millington, TN
    Thanks Stew! You are right, black accents never let you down. BTW, what black paint did you used?? Will need to repaint whole fixture after mock-up, want to have it nice and clean - ZERO scratches.
    Any ideas/suggestions on what to use for gasket between fixture and cab?? OEM??
    Thanks!
    Rick
  6. Jul 12, 2019 at 7:40 PM
    MESO
    State of Jefferson
    Yes it was designed to retain the OEM gasket seal. The paint is SEM black primer. I would not use that long term as it does not hold up well to scratching. It’s jist a good filler/sealer primer for the plastic.
  7. Jul 12, 2019 at 7:56 PM
    NavyDiver72
    Rick
    Millington, TN
    So, spray painting the PCB boards will not affect it? I’m sure paint is conductive, any thoughts?
    Also, if the PCB boards can be painted, how do I do it? What do I need to mask, etc.
    AND, what spay paint do you recommend on top of the SEM primer??
  8. Jul 12, 2019 at 8:11 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Trim black housing. Red centers. White putters.
  9. Jul 12, 2019 at 8:19 PM
    NavyDiver72
    Rick
    Millington, TN
    Thanks! What do you mean “trim black housing”?
  10. Jul 12, 2019 at 8:21 PM
    MESO
    State of Jefferson
    any krylon black paint. Spray over everything, Qtip with acetone and wipe the LED face off.
    See postHERE
    Blacked out looks much better and does not affect output.
    FishnTx, TRDSport10 and steveo27 like this.
  11. Jul 12, 2019 at 8:43 PM
    steveo27
    Pittsburgh
    Not gloss. Not flat. But a very nice OEM lookin matte sheen.
    4xdog and TRDSport10 like this.
  12. Jul 12, 2019 at 8:50 PM
    NavyDiver72
    Rick
    Millington, TN
    Awesome thanks!
    steveo27[QUOTED] likes this.
  13. Jul 12, 2019 at 9:20 PM
    MESO
    State of Jefferson
    that's great for a smooth look. If you want any type of texture, underbody coating works well too.
  14. Jul 12, 2019 at 10:40 PM
    caribe makaira
    Stop power via 87a to 30 to RED KC Cyclones
    DPDT Switch White ONLY - OFF - White & RED
  15. Jul 13, 2019 at 6:28 AM
    NavyDiver72
    Rick
    Millington, TN
    I have a 06 DCLB, I was thinking of wiring the red lights directly to the break lights, and the cargo white tap them to the dome light lights for a “auto” power up when opening doors.
    Can you explain a little bit the diagram that you sent? I’m not an electrical genius, but with a little guidance I can get it done. I am VERY familiar with my Taco.
    I was thinking of using the OEM cargo switch but have not figured out where to place it...
    Any other options/ideas would be greatly appreciated.
  16. Jul 13, 2019 at 8:51 AM
    caribe makaira
    This shows the center KC Cyclone's replacing the OEM center stop lamps. The Relay is a 5 pin which has 87a & 30 Normally Closed (NC), so without any power they are connected to provide the power when stop/brake is selected.
  17. Jul 13, 2019 at 8:57 AM
    Da Boogie Man
    Da Boogie Man Purple Nurple
    Seymour
    You should make a lens that is blacked out but when you stop, the word “BREAK” lights up.
  18. Jul 13, 2019 at 8:58 AM
    caribe makaira
  19. Jul 13, 2019 at 9:35 AM
    caribe makaira
  20. Jul 13, 2019 at 10:19 AM
    caribe makaira
    Red Cyclones to Stop circuit via 87a & 30 on relay (NC)
    White Cyclones to Cargo Lamp Switch.
    Hot Fuse to relay pins 87 & 86
    Relay pin 30 to White Cyclones and Red Cyclones relay, pins 86 &87
    White Cyclone relay pin 85 to Deck/Cargo switch #5
    Deck/Cargo switch wire #9 to relay pin 30 - to 87a to Door switch circuit or Driver's door Courtesy switch. (-)
    Deck/Cargo switch "ON" pin 30 goes to 87 - to ground (switching lights ON) relay to wire #10 provides ground to relay via wire #7.
