Thoughts?? Climate control lighting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by will5885, Jan 5, 2014.
  1. Jan 5, 2014 at 7:57 PM
    will5885
    will5885 [OP] Member
    Kevin
    Maryland
    2005 Tacoma Prerunner V6
    Homertaco Grill, Hella 500ff, BAMF Light Bar, OTRATTR Light Switch, Pioneer x5500BHS, Camerasource Backup Camera
    Hi TW,
    I recently installed a new headunit in my 2005 Tacoma. Not my first install so everything went great. However, now whenever I turn on my headlights my A/C selector push button and the vent selector light doesn't come on. Now with one good hit to the passenger side of the panel and everything comes back on and stays on until the next day. I have been researching all night and can't make sense of it. There are two bulbs controlling these and they are on different sides of the panel and the other two bulbs never have any problem. Anyone have any ideas? Anyone have a wiring diagram for the panel or at least what the wires are that are plugged into the back? I have checked to ensure the harness is firmly plugged in but no change.
    Thanks in advance,
    Kevin
  2. Jan 5, 2014 at 9:16 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    Sounds like you must have pushed a wire connector mostly off?
  3. Jan 5, 2014 at 9:24 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Mine used to do that. After hitting it for a few months, it stays on just fine :D
  4. Jan 6, 2014 at 7:34 AM
    81shark
    81shark Well-Known Member
    my fan speed light works sometimes and sometimes not. the other two knobs always work. well., except for that one time they didn't.
  5. Jan 6, 2014 at 7:36 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    check for shorts or a semi-loose connector
  6. Jan 6, 2014 at 9:02 AM
    TwoTacos
    TwoTacos Well-Known Member
    Winnipeg, MB.
    2011 TRD DCLB Sport
    3" Leveling Kit with AAL, 5160/6112 Billsteins, LED Bed and under hood Lighting, backflip F1 tonneau cover, TRS HID Headlights, Homemade Satoshi Grill, heated seats, cluster and dash white LEDS, TPMS disable switch, ABS/VSC disable switch, fog light anytime mod, Backup Camera On anytime mod, Power locking tailgate, blue LED floor lighting c/w dimmer, tinted windows, aftermarket Nav/Audio with built in sub, aftermarket homelink.
