Thoughts on 2 or 2.5” lift and 1” body lift
Discussion in 'New Members' started by TacoBlancoTRD, Jan 23, 2025.
  1. Jan 23, 2025 at 9:22 PM
    TacoBlancoTRD
    TacoBlancoTRD [OP] Member
    2023 White Tacoma TRD OR
    Hello trying to decide rather or not this is a good idea or even worth my time trying a 1” body lift. Im aiming to fit 34s or 35s for more ground clearance by raising the body 1” and using a 2.5” lift to get above 3” without maxing out suspension. I don’t want the standard 2” and 33s like everybody else has or cut and beat a lot to fit 34 or 35s. Would that 1” minimize all the cutting and beating or even none? I’m eyeing the eibach stage 2 at 2.5” or fox 2.5s or simply 5100s and ome 2888s unless someone has other suggestions to squeeze out more. I’ve seen having to adjust rear bumper, new ucas, a diff drop, regear, tune maybe ecgs. Anything else I’m missing? In my head I’m thinking of playing it safe at 2” from suspension, 2-4” from wheels depending on size I go with and 1” BL for a total of about 7” increase to cab height with 4” more ground clearance? I think it would look and have a great stance and have no negative effects really. Am I missing anything? Would that extra 1-1.5” be worth it?
    buckhuntin-tacoma and Finn-2187 like this.
  2. Jan 23, 2025 at 9:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The cab mounts are in the same place even with a body lift.
    It's going to rub......
  3. Jan 23, 2025 at 9:39 PM
    Finn-2187
    Finn-2187 Well-Known Member
    2021 White Tacoma SR 4x4 DCSB
    Fog lights, Vision Turbine 16x8 wheels, Goodyear Wrangler Ultraterrain 265/75/r16 AT's, janky LEDs that probably won't catch on fire
    Welcome!
    buckhuntin-tacoma likes this.
  4. Jan 24, 2025 at 4:42 AM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    Welcome to TW!
  5. Jan 24, 2025 at 9:58 AM
    TacoBlancoTRD
    So would the 1 inch body lift save me from trimming more of the inside I’d be fine with cmc?
  6. Jan 24, 2025 at 10:02 AM
    T4R_hereforbearings
    T4R_hereforbearings Dale Doback, M.D.
    WA
    08 4Runner
    I’ve bolted some stuff to it *lists cool stuff here*
    :popcorn:
  7. Jan 24, 2025 at 10:03 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    If you went to a 35 from a 30.5, assuming a true 35, you'd only gain 2.25 inches of clearance, not 4". Whatever the tire increase in height is, you cut in half for your increased clearance.
  8. Jan 24, 2025 at 10:03 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Welcome, one thing you’ve not mentioned is what size 34/35s you want to go with and your backspace. I don’t think you’ll get away from cutting no matter which size you go but skinny 35s and the sweet spot backspace will help out. There are a few good threads here all about fitting 35s.
    Pretty sure you won’t see many body lifts on the 3rd gen’s since they don’t seem to be beneficial. I could and might be wrong on that but from when I searched before, it wasn’t a common thing.
  9. Jan 24, 2025 at 7:45 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    It is good to think outside the box and consider all angles. Everything in fitting bigger tires is going to come down to 1/2" inch here and there, up, back and forth for turning. That is why guys say cut to fit and bore out the wheel well area first before a body lift and raising that weight higher above the frame.
    An easier method to try out and test before body lifting or cutting avoidance would be to suspension lift your truck and extend bump stops to limit compression.
