Thoughts on best after market headlights
Discussion in 'Lighting' started by CO_HOTTACO, Jun 28, 2021.
  1. Jun 28, 2021 at 3:57 PM
    CO_HOTTACO
    CO_HOTTACO [OP] New Member
    2009 TRD Sport
    I have an 09 with the original headlights that have run their course. I'm a little overwhelmed with all the aftermarket options and am wondering what you all think is the better option(s).
  2. Jun 28, 2021 at 4:01 PM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    From having tried a couple sets of aftermarket lights, I'd suggest going with OEM if possible. If you buy a pair of $100 eBay lights, that's just what you'll get. My 2¢.
  3. Jun 28, 2021 at 4:02 PM
    CO_HOTTACO
    2009 TRD Sport
    I was leaning this way too. They're so pricey, but I suppose there's a reason for that.
  4. Jun 29, 2021 at 1:16 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome! Nothing will compare to OEM. Most all aftermarket is a massive downgrade from stock. Check out the 2nd Gen headlight thread, great place to ask questions and get quick feedback:
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
  5. Jun 29, 2021 at 5:33 AM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    What is the reason you want to replace them? If they are sun faded and there is no spider web style cracking on the lens you can restore them for about $40 in supplies and a few hours of your time. Once the process (sanding and clear coat, very easy) is done they will be permanently fixed....or at least for another 10 years or so. I can explain the process if you want to go that route.
    If it is just restoring the headlights, do you have any pictures?
  6. Jun 29, 2021 at 10:15 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    My first question to anybody looking to replace their headlights is this: Which is more important to you, looks or performance?
    If performance is your highest priority, OEM is the only way to fly. If you're just interested in looks, I'm out.
    TacoFergie likes this.
  7. Jul 1, 2021 at 12:37 PM
    tacovsburrito
    tacovsburrito Member
    11 TRD Sport
    New here, but I'm in a similar boat looking for new headlights. I've read a bit through the other threads, but still a bit torn on how to proceed.
    The previous owner of my 2011 sport missed the TSB warranty period and my lights look exactly like the melted ones in the TSB, and in addition to the melted running light covers, the main headlight area is starting to get cloudy and crack too. Is this restorable in less than five hours effort?
    For me, I don't need high performance, but don't want dim lights, or blinding lights or some other terrible light pattern either. Mainly i just want to to fix the ugly melting and cloudiness at a reasonable cost. After reading through many reviews on Amazon and other places, it seems most complaints are about fogging or leaking water and you can get by with aftermarket ones if you do some caulking/sealing. From this forum and others it seems the performance also sucks, in particular the LED and HIDs seem to be poor for a number of reasons.
    - Is there middle ground here to go with an aftermarket (non LED / HID) setup and replace bulbs with good ones to get a clean look without losing on performance, or will I still regret it after a year because of other quality issues? What are the other issues with aftermarket?
    - I've seen in the forums and on amazon that there might be different lights for Sport vs non-sport. is this true?
    thanks in advance!
  8. Jul 1, 2021 at 12:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Read the link in post 4
  9. Jul 1, 2021 at 1:07 PM
    Too Stroked
    Tom
    Let me see if I can address your questions.
    First, if your lenses are starting to crack, although you can polish / restore them to get the oxidation out, the cracks are permanent. Using any of the commonly available restoration kits will net you significantly better looking lenses in an hour or two. If you want my opinion, lenses as bad as yours dictate new headlight housings.
    Speaking of housings, as I've stated before, OEM is the only way to fly to avoid crap light patterns, leaking and early oxidation. The big question is whether you buy new or find a good set of used housings. I'd check the Classifieds here for possible used ones if you want to save some money.
    If you really want good lighting without the risk of blinding oncoming drivers and / or not being able to see anything yourself, just go with new (or used) OEM housings and the Ultimate Headlight Upgrade. No LED or HID bulb slapped into an OEM housing will even come close to the performance. If you don't want to go through the trouble of adding the HD harness and higher wattage bulbs, look at the list of bulbs and use the ones that do not require a harness.
    The ultimate headlight upgrade H4 (not LED or HID) | Tacoma World
