Thoughts on buying a high mileage 06
Discussion in '2nd Gen. Tacomas (2005-2015)' started by zacbrown, Oct 20, 2013.
  1. Oct 20, 2013 at 8:49 AM
    zacbrown
    zacbrown [OP] Member
    PA
    looking
    Found an 06 Double Cab priced under $13000 with over 175000 miles. One owner. Is this worth the risk?
  2. Oct 20, 2013 at 8:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    As long as it was well maintained, all should be good. Most common things to go wrong on the higher millage trucks, are window regulators, and other minor electrical things.
  3. Oct 20, 2013 at 9:08 AM
    zacbrown
    PA
    looking
    I'm not very good about seeing any problem issues. I will poke around and check for rust. This could run well over 300,000 mikes, right?
  4. Oct 20, 2013 at 9:10 AM
    tyrantoo5
    tyrantoo5 New Member
    devon
    michigan
    2010 ACLB trd 6spd
    audio system Bilstein 5100s and icon aal Phoenix mini controller paired to a custom relay box running my auxbeam lights Raceline combats 17x9 wrapped in falken at3w 285/70r17
    i bought an 05 with 180xxx this summer for 11000 it runs great i got a manual tho id be worried about an automatic just drive it and see how it shifts go through all the gears
  5. Oct 20, 2013 at 9:12 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Where do you live? There may be some members nearby that have a scan gauge, they can use to check the health of the systems in the truck, and lend a hand in inspecting it.
  6. Oct 20, 2013 at 9:13 AM
    Rustbucket
    Rustbucket God Bless America
    Garrett
    Bay Area
    06 V6 Access Cab SR5 Manual in Speedway Blue
    That is an awesome deal. 1st gen trucks with that mileage go for about 11-12k at dealers around here. Like Chris said as long as it is clean and maintained well it should have plenty of years left in it.
  7. Oct 20, 2013 at 9:14 AM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Nope!
  8. Oct 20, 2013 at 9:26 AM
    ziggynagy
    ziggynagy All Glory To The Hypnotoad
    Stoughton, MA
    '11 Sport AC 4x4 V6 Auto Tow
    Westin step bars, led dome & map lights, tailgate hoseclamp, BluLogic, MetalMiller emblem, 35 tinted front windows, extra OEM d-rings, WeatherTech front/rear
  9. Oct 20, 2013 at 9:31 AM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    There should be little to no problems with it. One hand in the cookie jar for that amount of miles is great. It's better than a car with less miles and has 5 hands that were previously in the cookie jar. As long that all the maintenance was done then you should be good. Just check for the rust issue. If there isn't something that you're not sure of you can take it to an actual mechanic and have it inspected. But you should be good to go.
  10. Oct 20, 2013 at 9:40 AM
    Captain Drywall
    Captain Drywall Tacoma Enthusiast
    Carmichael, Ca
    Regular cab 5 bolt silver gray. Auto trans. P
    I have a bent up bumper.
    my 06 has 175 grand on it, I am the original owner i rarely do any maintenance. It runs like a champ. A beat up champ. runs great.
  11. Oct 20, 2013 at 10:45 AM
    nammer
    nammer Well-Known Member
    Nam
    Bradenton, Florida
    Wishing I had a Taco
    just curious if it's a 4x4 or prerunner, priced high for a prerunner imo, and double cab or access cab?
  12. Oct 20, 2013 at 11:03 AM
    zacbrown
    PA
    looking
    4x4 Double Cab at a dealer in Lancaster, Pa.
  13. Oct 20, 2013 at 11:12 AM
    nammer
    Nam
    Bradenton, Florida
    oh nice, doesnt sound bad at all, i'd def check it out, gl!
  14. Oct 20, 2013 at 12:03 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    Check the motor mounts. I remember reading something about motor mounts cracking/collapsing or something like that on some of the early 2nd gens. I bought an 05 dclb that i kept for about 2 years. it had no issues at all and it had 90k when i bought it. Like others have said, get all the maint. history you can on it b4 you buy.
  15. Oct 20, 2013 at 12:09 PM
    NorCalTRD
    NorCalTRD Well-Known Member
    Northern California
    '06 Indigo Ink DCLB TRD Sport V6
    40% Front Tint, Viper 5704 Alarm, Steel Cable Dog Tie, Super Sexy Driver Mod
    I bought my 06 with 230K on it, I have no problems besides a worn suspension.
    Thats fine though cuz ill be doing OME full 3" lift.
    New engine and tranny though since previous owner didnt put oil bolt back in after a change.
  16. Oct 20, 2013 at 12:15 PM
    duckcmdr
    duckcmdr If it flies it dies!!
    Joe
    New Jersey
    06 DCLB 4x4
    ARB Winch Bumper, Cabelas trial gear 2 mats, Wade vent shades, rear TSB, Toytec TSB AAL ,5100's set to 0,886 coils w/top plate 285/75/16 Treadwright at on Raceline Raptors, Toytec Diff drop, Bud Built Skids,Total Chaos LCA Skids,Devil horns,LED Dome Light,Scan Gauge, Rear Diff Breather, Revenge Fab Sliders. XRC 8 winch, Safari Snorkel, KC Daylighters 100 watt, Redline hood Struts & ez-down tailgate, G-stop extended SS brake lines,Homeroshi front grill and snorkle grill, relentless fab hc rear bumper
    I got my 06 dc 4x4 27000 for 19900
  17. Oct 20, 2013 at 12:38 PM
    nammer
    Nam
    Bradenton, Florida
  18. Oct 20, 2013 at 1:10 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    "Under" 13,000 for an '06 with almost 200k on it sounds pretty high.
    My '08 (5 lug RC) was $13,500 with 53k on it.
    Is that a 4x4 or Prerunner?
  19. Oct 20, 2013 at 2:29 PM
    jw1983
    Alberta
    You sound like my two roommates. Their 05' Lancer they have almost 200,000 km's on it(bought new). Original wipers, front windshield, rims. Never had a transmission flush, coolant flush. Even the dip stick was rusted to where no one could get it out. Some tools and some force got it out. The car has never left them stranded, doesn't leak, knock, nothing. The only thing that doesn't work is the trunk doesn't work with a key and the heating and AC box doesn't work(just blows warm air). The car got new wipers since I changed them. I think they got their monies worth with only paying $15k(CDN) out the door for the car lasting 8 years thus far.
    I'm sure hoping that my Tacoma will last just as long(or longer) with all the maintenance being done at the right times etc. I just did my engine air filter and cabin air filter today and my Tacoma has just over 14,000 km's on it(11 months old). But I am anal about my maintenance and having everything done. I am the kind of person I'd buy a car from.
  20. Oct 20, 2013 at 2:34 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Damn.
    Ran that through KBB with the PA zip code and in excellent condition, they're estimating it at 15k.
    Seems way high for a 7 year old truck with nearly 200k on it.
