thoughts on catch cans
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GaTaco75, Dec 30, 2024.
  1. Dec 30, 2024 at 11:29 AM
    GaTaco75
    GaTaco75 [OP] New Member
    William
    2017 Inferno Tacoma 4x4 Trd Sport
    wheels/tires/2"lift,bilsteins,bullybarfront,seatjackers,customeshifterknob,bedcover,mudflapdelete,moretocome
    anyone installed catch can on 2017 3.5 dual port injection Atkinson engine? just wondering if deleting the pcv would help run cleaner
  2. Dec 30, 2024 at 11:57 AM
    eurowner
    eurowner Duke Sky
    Scoty
  3. Dec 30, 2024 at 3:36 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Save you the reading: of the above links...
    The only reason I have found for a catch can is if you are an avid off-roader and will be going up steep inclines. Seems oil accumulates at the rear of the engine under that condition and it enters the air intake.
    I will be installing mine soon. Negative to deleting the PCV.
    Tacosha, GaTaco75[OP] and SH10151 like this.
  4. Dec 30, 2024 at 3:54 PM
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
