Thoughts on E load K02 for 1st gen ?
Discussion in '1st Gen. Tacomas (1995-2004)' started by chrispchicken9, Nov 28, 2019.
  1. Nov 28, 2019 at 6:06 PM
    chrispchicken9
    chrispchicken9 [OP] Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    Any thoughts on LT265/75/R16 E load BFg k02 tires for 1st gen ?
    Is this too much weight (10 ply) for ball joints, control arms or whatever else is down there to handle these heavy tires?
    Too much tire for this truck ?o_O
    looking for thoughts on mpg/wear of tires as well
    e/ for daily driver
    Happy thanksgiving !
    2002Tacoma4x4 likes this.
  2. Nov 28, 2019 at 6:22 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    I installed E rated BFG KO1’s on my ‘01, hated them. Now my 2013 has E rated BFG KO2’s that the previous owner installed. Hate them too. Go for the P metric or at least a C rated tire. Your ride quality will suffer badly with E rated tires.
  3. Nov 28, 2019 at 6:30 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Depends how you use your truck. Like the above guy said, E range is a rough ride on these small trucks. Also mpg will take a hit. But its worth it on rougher dirt / shale roads imo.
    I cant really see why it would specifically be bad for any components on the trucks though. If the wheel/tire moves, so does the suspension. Really the weight of the tire is only supported by the ground. Maybe it would be a bit harder on the steering linkages, Im not sure :notsure:
  4. Nov 28, 2019 at 6:39 PM
    Taco1.1
    Taco1.1 Well-Known Member
    2018 TRD Off-Road
    Debadged, Kenwood 9905 Head Unit, Tinted Windows, Remote Start
    I use C rated on my third gen...rides a lot nicer than my friends 4-Runner with E rated. Not an apples for apples comparisons but was enough to keep me away from an E rated tire.
  5. Nov 28, 2019 at 6:41 PM
    Bishop84
    Bishop84 Well-Known Member
    Deflate? sharp rocks? E rated. I'd even go E if I towed just for less flex in the tire.
    Otherwise go for C.
  6. Nov 28, 2019 at 6:49 PM
    Marcoma91
    Marcoma91 Well-Known Member
    Marc
    Los Angeles
    2002 Tacoma PreRunner Dbl Cab. Bilstien 5100, OME 883, AAL, 265/75 R16
    Have 265/75 r16 KOs on my 1st gen 2.7 for 6 years now. Tread wear was great, never had a flat despite some gashes in the sidewall, looks bad ass, ride is stiff. I’m getting 17-18 mpg at 35psi and about 30% hwy driving and 70%city. I’m going on 65,000 miles since I had them installed and there is still about 1/4 of an inch left. But I am going to try a C rated tire in the next couple of months. Never had any problem with Control arms or steering components.
  7. Nov 28, 2019 at 7:04 PM
    Buschman
    Buschman Well-Known Member
    Oregon
    1998 Tacoma V6 4x4 5speed
    Kings, TC uppers , TRD rear end, 4.30s, 285's
    I have 285/75/16 KM2's E rated. I would rather have a lighter tire but I haven't had any problems because of them and maybe I have avoided a flat because of them. I run 30/25 psi and the ride is fine. AT 10 psi wheeling I have never blown a bead knock on wood. I get about 17mpg but I have 4.30s with a 5 speed. I would think the 265 size would have even less negatives compared to my 285.
  8. Nov 28, 2019 at 7:05 PM
    chrispchicken9
    Thanks all for input
    will likely choose from tiny selection of C load tires in this size
    Any input or leads on C load tire is appreciated
  9. Nov 28, 2019 at 7:06 PM
    UnderFire
    UnderFire Well-Known Member
    I've had 285's, 315's and 35's in C, D and E rated. Ride quality differences are minute, weights all much heavier than any 265's, heaviest combo I ran was 35x13.50 on 15x10's easily 100lbs a corner. Still handled well and had no problems with steering or stopping when driving accordingly. I am talking about vehicles that served daily driver duty here as well.
    The difference between a C rated and E rated 265 will be so minute I would not even worry about it. Set your air pressure accordingly. I'd say most of the time that ride quality becomes a concern, either your expectations are higher than a 16-25 year old truck can deliver, or your suspension is in need of an overhaul.
  10. Nov 28, 2019 at 7:09 PM
    chrispchicken9
    Understood, main concern was full out mechanical issues with heavy tires. Suspension is fresh 5100s and coils should be ok
    It’s odd C load tire holds less load than a P tire, according to many of the tires specs I looked at
  11. Nov 28, 2019 at 7:13 PM
    Bishop84
    It's why its so hard to find C rated tires. Not terribly useful. I tried to find C duratracs and it was difficult.
  12. Nov 28, 2019 at 7:19 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I’d go with C rated if you can. The lighter the tire the better the suspension can cycle it. They are few and far between, you have limited options.
    32x10.5x15 have a ton of choices for C rated mud an all terrain tires. But that for a 15” rim.
    Duratrac Cs come in 265/75r16s.
    step up to a 17” rim and you can get 265/75r16 Duratracs or Ko2s.
    go with a 255/75r17 and you have more choices in C for some mud tires. Probably only because jeeps come with that size. Problem with the 255s is that they’re narrow at 10” versus a 10.5 in 265s
    2002Tacoma4x4 and Taco1.1 like this.
  13. Nov 28, 2019 at 7:32 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    E rated if you offroad a lot. They are difficult to destroy. Ride quality will suffer. I've had E rated KO2s on my 1st gen and now have E rated STMaxx. You sacrifice street ride quality for much better durability on the trail. Seen many C and especially P rated flats offroad, very few E rated ones.
    If you only ride on the street then E rated is way overkill and not necessary on these trucks
  14. Nov 28, 2019 at 7:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    How are some of you guys so sensitive?
    I have E rated tires and I daily drive my truck and love it. Roads feel just fine, both improved and unimproved and I don't find the ride rough at all.
    Love being able to deflate when going off road as well.
    Hamer95USA and Area51Runner like this.
  15. Nov 28, 2019 at 8:00 PM
    Taco1.1
    2018 TRD Off-Road
    it’s not so much sensitive as it is some people prefer stiffer rides and some softer. Plus - all the different suspension set ups make a huge impact. E rated with squishy stock suspension might feel like a Cadillac while e-rated with stiff racing suspension might cause you to lose a filling every pothole.
  16. Nov 28, 2019 at 8:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I get that but tires alone shouldn't be all that much of a difference to "hate them".
    I've got stiffer suspension as well.
  17. Nov 28, 2019 at 8:21 PM
    eon_blue
    Azusa, CA
    I think the biggest factor here that doesn't really get mentioned is personal taste...one guy's version of 'too harsh a ride' is another guy's 'thats not bad at all'. E's are definitely stiffer than Cs but in my opinion it's not all that bad, and knowing I don't have to worry about them on the trail as much is worth putting up with a bit of a stiffer ride
    Keeping the PSI a bit on the lower side with Es really helps on the street too. If you put them at 40+ its going to rattle your teeth
    Hamer95USA likes this.
  18. Nov 28, 2019 at 8:43 PM
    Styx586
    Terrance
    Lake Elsinore, Ca
    When I was running my E rated 285/75/16 BFG’s on my ‘01, I also had Icon suspension front and rear. At first I loved it and thought the ride wasn’t too stiff. But I ran that setup for about 6 years and grew to absolutely hate it...
  19. Nov 29, 2019 at 8:33 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I've used E-rated tires on my Tacoma for nearly 5 years. If you want off-road durability they are so worth it. I haven't noticed any unusual suspension wear. I lost maybe 2 MPG over bone stock with P-rated tires but I also have a lift, steel wheels, armor and a shell. I still regularly get 22-23 MPG Highway. Different brands will ride different. I wore out a set of Cooper ST Maxx's, they rode pretty firm and occasionally punishing. Now I have Yokohama Geolandar M/T's and they ride a lot nicer. For comparison, I have another truck on P-rated tires and the Yokohamas ride nearly as smooth.
  20. Nov 29, 2019 at 8:42 AM
    16Tacos
    16Tacos Well-Known Member
    Zach
    Boston
    08 Access Cab 4x4 V6 SR5
    OME Nitrochargers w/886s & Dakars, ARB Deluxe Bull Bar w/Warn winch, RCI sliders with kick out, IFS & Mid skids, BFF Hi-clearance rear bumper, Brushed Copper 17" SCS Ray10s w/285-70 KO2s, Black OEM 16" steelies w/255-85 KM2s, Leer contractor cap w/Smittybilt overlander xl RTT, Off-Grid Engineering dual battery kit and bed power panel, Blue sea aux fuse block, Wyntner 60L fridge freezer, ARB dual compressor, Pioneer 720BT head unit, CB radio, @Matt_Gecko bed and engine bay lights, @TacomaTruckParts Dirt bike tie down bar, color matched OEM grill, A-Pillar phone mount mod, @Docloco rear seat molle panel
    I had E-Load 265 KO2s and then E-Load 255/85/16s KM2s but ultimately got a second set of rims to run C-load 285s and am glad I did. Even on my second gen the E-load KM2s noticeably sapped the power and hurt MPGs. I have a good floor jack so I don't mind swapping my rims out for the KM2s when I go wheeling. As others have said it depends on your needs and for me that meant having two sets of rims/tires.
