Thoughts on Engine Grinding Noise, Oil Light Comes On
Discussion in '1st Gen. Tacomas (1995-2004)' started by josh0351, Apr 8, 2013.
  1. Apr 9, 2013 at 8:07 AM
    BamaToy1997
    Bill
    Navarre, FL
    I would ask for more details. What exactly says you need a new engine? I want specifics if someone says I need to replace something entirely. Not saying that they are wrong, as I think they are probably right, but still, just saying "You need a new engine" is pretty dang vague.
  2. Apr 9, 2013 at 12:53 PM
    josh0351
    josh0351 [OP] Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    He said that the clicking was coming from the back lower part of the engine. He said something about the lower bearings getting ready to seize and causing the upper valves to knock, if that makes sense (sorry, I'm not a mechanic and was trying to jot everything down as he rattled it off).
  3. Apr 9, 2013 at 5:41 PM
    josh0351
    Josh
    VA
    Some stuff...
    Got her home today, driving easy in 85+ degree heat for about 5 miles. No oil light or loss of power until the last mile when I was climbing a slight incline. Noticed loss of power first, then oil light came on. Oil light persisted at the 3-way stop when at at stop, and I noticed that it was all downhill from there (fortunately I was less than 1/2 a mile from the hood).
    Made it home and parked it in the driveway, but it's leaking anti-freeze now. I don't think I need to waste another $150 on a second opinion from another shop, I think the engine is fried.
    Bill - Do you concur? Or should I get it into my regular shop for a 2nd look?
  4. Apr 9, 2013 at 6:02 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    It sounded to me like the engine was probably toast ever since you said it had less than 3 qts in it. I'm not surprised at all that the bearings are shot. That's rough on your rod bearings, journals, oil pump, main bearings, everything. Luckily a 2.7l engine should be easy to find.
  5. Apr 9, 2013 at 6:56 PM
    BamaToy1997
    Bill
    Navarre, FL
    At this point you have most likely completely fried your engine. Time to start looking for another one.
  6. Apr 9, 2013 at 7:55 PM
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Buy a hilux d4 motor!
  7. Apr 10, 2013 at 9:37 AM
    josh0351
    Josh
    VA
    Some stuff...
    Thanks. I'll be looking into all options & entertaining any & all suggestions!
    Heh, what a rough start to my first Tacoma!
  8. Apr 10, 2013 at 9:54 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    I can't stop looking a Katy Perry.
  9. May 28, 2013 at 8:10 AM
    josh0351
    Josh
    VA
    Some stuff...
    UPDATE: Work has had me on the road the last month plus other things going on, but I finally bought an engine hoist and pulled the engine last night. As soon as I removed the oil pan I picked this out of the bottom! :eek:
    Not good. The crankshaft has some metal chunks missing as well (I'll get some pics tonight) where the bearing tore it up. Can't wait to see what's jacked up on the top end and causing the clicking...:crapstorm:
    Stay tuned.....
  10. May 28, 2013 at 12:43 PM
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    would that be a chewed up bearing insert? I would get this to your local high quality automotive machine shop, I bet it will need a crank before you get done.
    Howard
  11. May 28, 2013 at 12:52 PM
    beaver_scott
    beaver_scott Well-Known Member
    scott
    renton, wa
    2015 inferno trd pro
    vent shades, tinted windows, clear bra, pop n lock tail gate lock, anytime fog light mod.
    the clicking was probably the valves running dry...They are the first to get noisy when the pump fails because no oil gets to the top of the motor. I wouldn't even consider rebuilding that beast.
  12. May 28, 2013 at 1:17 PM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Find a decent used motor, and drop it in. Sell the old one for parts.
  13. May 28, 2013 at 1:19 PM
    hetkind
    Howard
    Johnson City
    I have done much better in rebuilding the existing engine if possible over a used motor...just about every used motor I have installed, I have regretted while the last two I had rebuilt, one in 99 and one is 05 are still in service.
    Howard
  14. May 29, 2013 at 6:23 AM
    josh0351
    Josh
    VA
    Some stuff...
    I'm gonna press on breaking it down and make a final determination once I assess the overall damage. I'll keep you all posted...
  15. May 29, 2013 at 9:58 AM
    #35
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    i would say that looks like crank shaft bearing... anyone else?
