Thoughts on getting the clutch done?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jmettx, May 19, 2015.
  1. May 19, 2015 at 4:06 PM
    jmettx
    jmettx [OP] Active Member
    2005 TRD V6
    I have to bring my 2005 Tacoma V6 6speed in to have the throwout bearing replaced. Some people have told me that I should have the shop replace the clutch while they have the trans out. It has 130,000 miles on the original clutch. Any thoughts on whether I should have the clutch done at this point? Should I have the flywheel done, too? Thanks.
  2. May 19, 2015 at 4:20 PM
    Zach O
    Zach O Well-Known Member
    Zach
    Texas
    2015 TRD Off-Road SWFTMFW 6 speed
    If it were me and I had the extra cash I probably would have the clutch replaced just for piece of mind. I have no idea about the flywheel though.
  3. May 19, 2015 at 5:51 PM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Have flywheel resurfaced. If to many burnt marks I would replace. Replacing the clutch (Aisin brand) would be a smart thing to do at this point.
  4. May 19, 2015 at 6:48 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    I took the easy way out one time when replacing a clutch. Just slapped it on and went. Followed by removing the tran, clutch, and taking the flywheel to a local machine shop to be resurfaced. Clutch chatter was beyond annoying. Easy enough to take off, and while you are there you could consider replacing the 20$ rear main seal as well. Rubber gets pretty hard after that many miles and high temps.
  5. May 19, 2015 at 8:15 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes! It is cheaper in the long run to only pull the transmission once.
    Clutch, Throw-out Bearing, Pressure Plate and Flywheel. I would inspect the rear main seal while you are there also, I'm not sure how hard this particular one is to get to.
