Thoughts on how to make wooden shop table more durable.....
Discussion in 'Garage / Workshop' started by chris4x4, Apr 26, 2015.
  1. Apr 26, 2015 at 4:37 PM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Im wondering if fiberglass resin would make a wooden shop bench top more durable, and more resistant to water, or other liquids. Thoughts?
  2. Apr 26, 2015 at 4:43 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    not letting you anywhere near it would probably be the best suggestion
  3. Apr 26, 2015 at 4:44 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Don't be a dick. I built this table, and its fucking fantastic......Just want to make it better, and more resistant to wear.
  4. Apr 26, 2015 at 4:45 PM
    tinker_troy
    T R O Y
    WY/SD
    are you building a new top or is this an existing top you have already scorched?
  5. Apr 26, 2015 at 4:46 PM
    tinker_troy
    T R O Y
    WY/SD
    what did you just call me?
    f*ck if I am going to waste my 9000th post on your bich azz
  6. Apr 26, 2015 at 4:46 PM
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    My old bench had what was essentially laminate flooring on it. No seems, repelled fluids, very durable. Paint, glue, and other sticky stuff could be scraped off with a razor. Stain was about the only thing that would harm it.
  7. Apr 26, 2015 at 4:47 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Arborite
  8. Apr 26, 2015 at 4:49 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Either steel or polycarbonate. Like a puck board would work. That would make it quite durable.
  9. Apr 26, 2015 at 4:49 PM
    tinker_troy
    T R O Y
    WY/SD
    need pics
  10. Apr 26, 2015 at 4:52 PM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Hankook DynaPro AT2 (Summer), Blizzak DM-V2 (Winter)
    Most guys I know here use sheets of steel or, if it can't be conductive, commercial formica.
  11. Apr 26, 2015 at 4:58 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Just want to keep the top I already have looking good.
    :cool:
    Yeah, This one is a nice dark color that I like. Just want to see if there is something I can do to keep the look, and make it more durable.
    gazuntite
    See my above comments.
  12. Apr 26, 2015 at 5:00 PM
    Clearwater Bill
    Billy
    Largo Florida
    My general working bench tops never have any seams, usually 3/4 plywood, maybe doubled for some beef. I've used leftover Thompson's water seal on them before, makes them pretty repellant.
    I have some cut to fit scraps of carpet (short nap commercial grade) that I lay on when working on fairly clean projects that I don't want things to roll around or to be marred (like fishing reel repair). If I get oil or grease on the carpet, I don't usually care very much. I have more.
    Been thinking about a nice piece of heavy sheet of aluminum to fit on too, with a front edge (90* bend). While 'noiser' it would be pretty durable. Problem is finding a piece of scrap large enough to work isn't easy.
    Also have an eye out for discarded commercial sink assemblies, which are usually stainless. One with a counter large enough to cut down for a top.
    The laminate Oz mentions looks like a reasonable choice too.
  13. Apr 26, 2015 at 5:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I don't want to use anything that's going to change the look of the wood. Fiberglass resin is clear, and durable, but just wondering about applying it to wood.
  14. Apr 26, 2015 at 5:04 PM
    OZ-T
    Peter North
    British Columbia
    Plexiglass
  15. Apr 26, 2015 at 5:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    A'ight......Do you know if Fiberglass resin will work?
  16. Apr 26, 2015 at 5:09 PM
    OZ-T
    Peter North
    British Columbia
  17. Apr 26, 2015 at 5:09 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    how about a 2 part epoxy? im sure they have something for your use
  18. Apr 26, 2015 at 5:10 PM
    OZ-T
    Peter North
    British Columbia
  19. Apr 26, 2015 at 5:11 PM
    OKJC
    Justin
    NWArkansas
    Clear polyurethane or resin may do the truck? Less toxic and messy than fiberglass resin.
  20. Apr 26, 2015 at 5:15 PM
    OZ-T
    Peter North
    British Columbia
