Thoughts on install of Fox Ultimate with Total Chaos UCA
Discussion in 'Suspension' started by MrT, May 19, 2015.
  1. May 19, 2015 at 10:09 AM
    MrT
    MrT [OP] Member
    Georgia
    2008 Prerunner V6 4 door Red
    None yet
    Just finished installing the UL-FOXTA05 Fox Ultimate suspension from Toytec on an 08 Prerunner 4 door.
    At $3300 it was not cheap and I was happy after receiving the parts that they too where not "cheap".
    It took a little over a day to do front and rear. I was in my driveway with jack stands and floor jack. My biggest fear was dropping the truck off of the jack stands while doing the rear as I had to have both wheels removed at the same time. I kept thinking, how will I get this back up if I drop it?
    The video here...https://www.youtube.com/watch?v=bbsTJgb6S_c was a great help, it just about perfectly explained the steps for the front. Kudos
    The only two difficulties are getting the loooong bolt out of the UCA shock tower. You really have to bend some metal. I ground the flange off of one side of the bolt in order to facilitate reinstallation. Secondly, I couldn't get the auxiliary reservoirs into the mounts. The stiffness and position of the hoses made mounting impossible, I had to bend the top portion over 90 degrees toward the outside of the truck and they fit fine.
    The rear would have been easy but for the fear of dropping the truck. I have descent jack stands but are they descent enough?
    I left the front coils set where they where from factory and ended up with about 2.25" lift it was nose up at that point.
    After installing all of the leafs in the rear and now it looks just about level maybe a little ass high.
    People talk about leaving the stock overload spring out but I think if I remove anything it will be one or two of the smaller leaves. the overload only comes into play when the springs are flexed, removing the other softens the ride.
    I drove truck after installing the front and was surprised how smooth the ride was, Nice stuff! After installing the rear I could tell it was stiffer than the original but not too bad. 20150424_171553_resized.jpg
    Before
    After
    Now I'm off to get my baby a new set of shoes!
    Taco-2013 likes this.
  2. May 19, 2015 at 10:40 AM
    taco06
    taco06 Well-Known Member
    Alex
    pomona ,California
    06 sprt
    I can't let the wife know
    Looks good. Any pictures of the suspension?
  3. May 20, 2015 at 7:47 AM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    There you go, sorry I didn't take any during install I get in a bit of a hurry and tend to get tunnel vision.
  4. May 29, 2015 at 5:31 AM
    Taco-2013
    Taco-2013 Well-Known Member
    Long Island
    2013 Tacoma TRD Off Road
    Do you feel like this suspension was worth the money?
  5. May 29, 2015 at 5:38 AM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Looks good!
  6. May 29, 2015 at 4:07 PM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    The cost is high but the product appears to be very well made. So worth it? If you just want a lift for looks no, but if you really want to get better off road performance yes. I don't have much experience with this set up yet but the Fox and Total Chaos brands are well known for quality.
    One thing to note although the coil-overs are ride height adjustable, Fox recommends using a spring compressor before attempting to. That means removing the coil-over from the vehicle...not something you want to do too often. I have tried to adjust on the truck all weight off and had a hard time turning the ring nut. Gave up and will have to wait till I have time to remove them.
    Further more Fox has very little info on there site about the adjustment of the dampers. Strange for this day and age.
    But let me say Scott out at Toytec could not be more sincere and helpful BIG THUMBS UP for Toytec and Scott.
  7. May 29, 2015 at 4:08 PM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    Thanks ordered new tires and wheels just now, will post soon.
  8. May 30, 2015 at 7:07 AM
    Taco-2013
    Long Island
    Thank you for that info. Did you pick up and road vibrations or any other issues from the lift. Were you able to get your alignment back into spec? Thanks again for the info.
  9. Jun 1, 2015 at 5:11 PM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    No vibrations, alignment is back into spec. the front feels more nimble but the rear add a spring did make it slightly stiffer. The shocks are adjustable for fast and slow rebound according to what I can glean from the Foxes website and limited literature included with the kit. I have been working a lot lately and haven't had a lot of time behind the wheel to play with adjustments. When I do I'll up date this thread.
  10. Jun 2, 2015 at 10:59 PM
    Christel889
    Christel889 Member
    Christel
    Canada
    Blue '12 Tacoma TRD Sport
    Mayham Hammer rims, 32" Wrangler Duratacs, U-Guard Bullbar. Suspension lift, cold air intake, and exhaust in the future.
    Good to know...I have Fox 2.0s in the rear and looking into getting some 2.5 coilovers for the front with some aftermarket ucas (total chaos) but holy crap shipping to Canada is an extra 1000 bucks by itself :(
  11. Jun 3, 2015 at 1:33 PM
    NeverUnpack
    NeverUnpack Member
    Tyler
    Katzkin AllWeatherLeather Warrior Products Roof Rack
    Looks great, I can't say enough that everyone I know who runs Fox seems to stay happy when they are in the dirt.
  12. Jun 13, 2015 at 5:42 PM
    tacobrumz
    tacobrumz Active Member
    Tacoma
    Total Chaos Dual Shock with spindle gussets
    Try one of Total Chaos' retailers in canada.
    Bertram 4x4 Outfitters 9136 Yellowhead TrailEdmonton, Alberta, T5B-1G2Canada780-651-1621
    The Gearshop 1431 40th Ave NEBay 14Calgary, AB, T2E8N6Canada403-261-0011
    Baja North
    615 Dairy LoopKamloops , BC, V2B-8N5Canada250-579-8509
    Big Country Customs 2215 Carpenter St.Abbotsford, BC, V2T-6B4604-853-2896
    North Shore Offroad -Surrey 19257 Enterprise Way, Unit 9Surrey, B.C., V2S-6J8Canada(604) 534-4366 North Shore Offroad -North Vancouver
    1440 Columbia St.North Vancouver, B.C., V7J-1A2Canada(604) 988-7677
  13. Jun 15, 2015 at 2:03 PM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    ouch!
  14. Jun 17, 2015 at 2:59 PM
    Nginerd
    Nginerd Well-Known Member
    Tacoma Texas Edition
    Stock for now
    Looks good. Looking to do the same lift for my taco but not sure if I want to drop the coin. One question I had was on the adjustable dampening. Can you feel a difference with the different dampening settings?
  15. Jun 17, 2015 at 4:16 PM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    On the front it is very noticeable feels very...supple, much less harsh than stock suspension. I think though it will take some time to shake things out as I haven't found Fox to be very informative as to the settings. You might find one setting good for one type of driving or conditions and another for something different.
    The rear with the extra springs I find it hard to tell the difference on any setting. However I'm not the type to blast over jumps. I'm confident in the product, I think though if you purchase it you have to find out how to use it. Sounds strange but with all the different conditions and driving styles that's the way it is.
    I will probably remove one or more of the leaves on the rear when I get the time. I wanted a lift/level look but with the total spring pack in it sits with the same rake as stock just higher.
  16. Jun 17, 2015 at 5:12 PM
    Taco-2013
    Long Island
    So after reading your feedback and a bunch of others I placed the order with toyteclifts for the Fox suspension as well. Rear shocks are on back order so I have to wait a few more weeks. On the site it says to remove the factory overload leaf for best ride. Have you thought about that to remove the stiffness your describing?
  17. Jun 18, 2015 at 7:29 AM
    Nginerd
    Stock for now
    I will say your rear end does look a little high especially with a cap on. I can see it being a little stiff being that tall and no amount of shock dampening will help a stiff spring. Hopefully removing a leaf will help. I too will probably do this same lift in a couple of months just because I tried piecing something similar together and it ended up being more expensive and that TW discount code helps pay for the shipping.
  18. Jun 18, 2015 at 7:50 AM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    The overload spring doesn't contact the other spring until they go convex or concave depending on how you look at it. but it does help when you have a load. If I was just going for off road performance I may take it out. Unfortunately this is a daily driver that may get loaded up occasionally. So I feel for me it's best to leave it in and remove one or two of the added pack thus making the ride less harsh at least until I put a load on it.
    One thing I'm pondering is, the kit comes with two wedges that helps align the rear end to the half shaft bearing. right now I have no vibration, how much can I drop without removing this wedge.
  19. Jun 18, 2015 at 7:52 AM
    Taco-2013
    Long Island
    The tacomaworld discount was great. Only problem with this site is I keep finding things I want to buy.
  20. Jun 18, 2015 at 7:53 AM
    MrT
    MrT [OP] Member
    Georgia
    None yet
    I see you have a Texas edition are you in Texas? I'm headed to Corpus Christi Monday for a week long job.
