Thoughts on Japans nuke plant blowing up....
Discussion in 'Off-Topic Discussion' started by chris4x4, Mar 12, 2011.
  1. Mar 14, 2011 at 9:28 PM
    #261
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Hmm. The numbers are wrong or the distribution is wrong or it's just flat BS?
  2. Mar 14, 2011 at 9:31 PM
    #262
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    whole fallout maps bs
  3. Mar 14, 2011 at 9:33 PM
    #263
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    OK. I just read the snopes thing.
    The distribution looks like it's plausible when compared to any of the WX RADAR maps and ocean currents in the area though.
  4. Mar 14, 2011 at 11:45 PM
    #264
    BlazeTaco
    BlazeTaco Well-Known Member
    PA
    4.0l 6sp SR5
    TRD Exhaust TRD Filter
    I hope this one incident doesn’t cause a problem for US nuclear electricity. Because right now this is the cleanest way to efficiently produce electricity at least until they invent a sustainable fusion reactor. Coal is dirty and produces a lot of hazardous wastes especially the left over ash (yeah and there is a lot more of that produced than nuclear waste). Not to mention all of the mercury it’s putting in the sea life and ozone emissions. Oh and it takes hundreds of pounds of coal to put out the same amount of energy a couple of pounds of low grade uranium can do.
  5. Mar 15, 2011 at 7:24 AM
    #265
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    My biggest worry is they started with one reactor bad, now they're up to 3 explosions and 4 reactors failing... I just hope they arn't fighting a losing battle :S
  6. Mar 15, 2011 at 7:29 AM
    #266
    COACHPPARK
    COACHPPARK Well-Known Member
    JC
    ST. PETERSBURG
    2024 CELESTIAL SILVER METALLIC TRD SPORT
    TINTED ALL WINDOWS,REAR WINDOW VENTS,SOME GRILLE BADGES,TINT TAIL LIGHTS,SPORTS BAR, LIGHT BAR FOR SPORTS BAR,LIGHTS FOR UNDER CARRIAGE, FANG LIGHTS,NITTO GRAPPLERS 285/65 R18,BLAQUE DIAMOND OFFROAD RIMS BD-801,REAR ARB RECOVERY HOOKS, TWO TONE PAINT BLACK/SILVER,CAMX DASH CAM,
    TRUE THE LIFE IS ABOUT 8 SEC BUT ONCE IN COMES IN CONTACT WITH DEBREE AND DUST IT CAN GET IN THE WIND AND TRAVEL GREAT DISTANCES... NOT A GOOD THING AND THE WORST THING IT WILL AFFECT PPL FOR MANY MANY YEARS.....
  7. Mar 15, 2011 at 7:29 AM
    #267
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    where are you getting 8 seconds from? thats not true at all..
  8. Mar 15, 2011 at 7:30 AM
    #268
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    "Dangerous levels of radiation leaking from a crippled nuclear plant forced Japan to order 140,000 people to seal themselves indoors Tuesday after an explosion and a fire dramatically escalated the crisis spawned by a deadly tsunami."
    http://www.kob.com/article/stories/S2014407.shtml?cat=500
  9. Mar 15, 2011 at 7:32 AM
    #269
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    "Japan's nuclear crisis escalated ominously following a third and more dangerous hydrogen explosion early Tuesday local time that may have damaged part of the reactor's primary containment shell, and a fire at a fourth reactor building that caused a major new release of radioactive contamination."
    http://www.nytimes.com/cwire/2011/0...sion-rocks-fukushima-nuclear-plant-19902.html
    just keeps getting worse...
  10. Mar 15, 2011 at 7:36 AM
    #270
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
  11. Mar 15, 2011 at 7:48 AM
    #271
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    It does almost sound like they are fighting a losing battle :s
  12. Mar 15, 2011 at 8:14 AM
    #272
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    good point brought up by my dad..
    "Their position is usually assuming that everybody does their job and that equipment will work.
    Yesterday, the operators let the fire pump that was delivering sea water to the reactor #2 run out of diesel fuel. As a result, the hot core boiled off all the water and the hot fuel rods were left uncovered for almost two hours. Up until then, reactor #2 was almost under control.
    There's a good chance that part of that core melted or warped so it lost its physical geometry and cooling it is harder to do. Now they are having difficulty cooling it and keeping the pressure down. As a result, they blew out a valve or something that is now allowing water to leak out and that makes it harder to keep the water levels up.
    They might be under a little pressure so I can understand them making a mistake here and there, but that was a pretty big mistake.
    The longer they can hold on, the better off everything will be, but they need to keep pumping water for a few weeks until the residual heat in the core is low enough to stop making steam."
  13. Mar 15, 2011 at 8:21 AM
    #273
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    THEY LET THE PUMP RUN OUT OF FUEL???!!
    Wow, I'm in no position to be criticizing a natural disastor but that was kinda re-donkulous..
  14. Mar 15, 2011 at 8:28 AM
    #274
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Latest:
    http://www.bbc.co.uk/news/world-asia-pacific-12749444
    Reactor #1: Coming under control
    Reactor #2: Latest blast damaged containment, leaking 400 Miliseiverts of radiation currently.
    Reactor #3: Coming under control
    Reactor #4: Shutdown for maintenance due to nuclear fuel being spent, near zero hazard
    Reactor #5:Temperatures raising slightly
    Reactor #6:Temperatures raising slightly
  15. Mar 15, 2011 at 8:29 AM
    #275
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    How many reactors does Japan have? I thought I read they had 54?
  16. Mar 15, 2011 at 8:31 AM
    #276
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    The daiichi plant that has all the issues has 6, not sure about the rest
  17. Mar 15, 2011 at 8:33 AM
    #277
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was just wondering about the total number. They should have enough reserve power, that once lines are brought back on line, or re installed, they should be able to get power back to everyone whos home wasnt completely destroyed.
  18. Mar 15, 2011 at 8:36 AM
    #278
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    There are 17 nuclear power plants in Japan with a total of 55 nuclear reactors.
  19. Mar 15, 2011 at 8:37 AM
    #279
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
  20. Mar 15, 2011 at 2:26 PM
    #280
    FearNothing321
    FearNothing321 You gonna eat that taco?
    Tony
    Knoxville, TN
    2019 Audi S3
    http://www.foxnews.com/world/2011/0...ses-agency-says-radiation-leaking-atmosphere/
    Has anyone heard about this yet? I really hope they are able to get this situation under control.
