Thoughts on Japans nuke plant blowing up....
Discussion in 'Off-Topic Discussion' started by chris4x4, Mar 12, 2011.
  1. Mar 12, 2011 at 8:12 PM
    #101
    bobby15
    bobby15 Well-Known Member
    SoCal
    09 DC LB 4x4 magnetic grey tacoma
    Have to get an All-pro bumper to mow em' down !! haha:p
  2. Mar 12, 2011 at 8:13 PM
    #102
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I gots one, but I might need a bullet proof one first.:cool:
  3. Mar 12, 2011 at 9:08 PM
    #103
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Exactly! :smack:
    http://www.youtube.com/watch?v=AC8xecTjzvA&feature=player_embedded
  4. Mar 12, 2011 at 9:15 PM
    #104
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
  5. Mar 12, 2011 at 9:29 PM
    #105
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    what caused them to lose cooling capacity?
  6. Mar 12, 2011 at 9:38 PM
    #106
    Tacoyota
    08 4wd
    Not positive , but loss of power meant no main coolant pump circulation and heat built up too high.
  7. Mar 12, 2011 at 9:40 PM
    #107
    Yoytoda
    Roland
    completely stock
    but they make the power... how does the power go out in a power plant?
  8. Mar 12, 2011 at 9:43 PM
    #108
    trg37
    trg37 Well-Known Member
    Tyler
    South Jersey
    05 Tacoma OME Full Setup
    Electricity got knocked out with the quake and the tsunami and the ten or so backup generators that are supposed to kick on when these go off line all failed because of the tsunami and the water damage. There are backup batteries too, which did not work due to water damage. Everything that could have gone wrong did go wrong
  9. Mar 12, 2011 at 9:52 PM
    #109
    trg37
    Tyler
    South Jersey
    The energy directly produced by these reactors in not usable until it gets "stepped down" and goes through the appropriate transformers. The reactors use electricity that is already converted to cool themselves. So when the quake/water hit, the power lines bringing the electricity used in cooling were destroyed. This is where the generators are supposed to come into play. And finally when those failed, I believe some sort of batteries were supposed to come not play. All of these backup devices were damaged and not functioning. This is what I got from listening to Bill Nye the science guy.
  10. Mar 12, 2011 at 9:56 PM
    #110
    Tacoyota
    08 4wd
  11. Mar 12, 2011 at 10:04 PM
    #111
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    What I don't understand is why they built nuke plants right on top of the ring of fire?
  12. Mar 12, 2011 at 10:06 PM
    #112
    Yoytoda
    Roland
    completely stock
    yea i get that but seems crazy to have som many backups fail. im just surprised they were not able to figure some way to divert power for cooling
  13. Mar 12, 2011 at 10:12 PM
    #113
    Tacoyota
    08 4wd
    they have 450MW reactors, im guessing 80' long turbines or so . For a simple 20' off to the side , they could've added a smaller 500KW turbine just for that power, a simple copy of a nuke sub turbine/generator.
  14. Mar 12, 2011 at 10:18 PM
    #114
    Yoytoda
    Roland
    completely stock
    agreed. my thought process would be to make it a priority to make the plant able to run all by itself with no outside help... completely self sufficient not relying on generators or batteries
  15. Mar 12, 2011 at 10:18 PM
    #115
    trg37
    Tyler
    South Jersey
    I guess everythipng was engineered with given circumstancees in mind. A lot of the buildings were not designed to withstand a 8.9 quake. People never expected the water to reach 6 miles inland. Power to a lot of the country was and still is knocked out. Everything with th design and with the buildings was compromised from the quake and the water and no matter how "over-designed" the systems were, they were not designed for this.
  16. Mar 12, 2011 at 10:20 PM
    #116
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Why didn't they just get you guys to design it , I bet it would still be working .
  17. Mar 12, 2011 at 10:22 PM
    #117
    jdickey03
    jdickey03 $enior M3MB3R
    (SOLD)2006 Tacoma trd offroad
    3" skyjacker Lift,Pioneer touch screen unit. Relentless Rear Bumper.
    This was taking at the mouth of the Mad River, in McKinleyville(where I live). about an hr south of Crescent City. We had dumbasses lined all up and down hwy 101 standing on their cars trying to get a glimpse....and we had like 4 people get swept in by the Tsunami in Crescent City...yet all morning we had sirens going off, warnings all over the radio and televsion..yet they still wanted to go take pictures?!?!?!
  18. Mar 12, 2011 at 10:23 PM
    #118
    trg37
    Tyler
    South Jersey
    Yea I don't think that it was necessarily a design flaw as it was just a perfect storm of everything going perfectly wrong. The stars aligned on this one in a bad bad way.
  19. Mar 12, 2011 at 10:24 PM
    #119
    OZ-T
    Peter North
    British Columbia
    Agreed
  20. Mar 12, 2011 at 10:28 PM
    #120
    Yoytoda
    Roland
    completely stock
    dont have to be a smart ass. just thinking out loud.
    i agree that nothing good comes from a 8.9 quake. mother nature trumps anything man made. the media is probably making it so much worse than it is...10% fact 90% speculation...
