Thoughts on light weight aftermarket crank and water pump pulley?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by malatx, Jul 12, 2022.
  1. Jul 12, 2022 at 7:13 AM
    malatx
    malatx [OP] Well-Known Member
    2022 TRDOR DCLB Army Green
  2. Jul 12, 2022 at 7:14 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Sounds awfully optimistic to me...
    RustyGreen, Big tall dave and tonered like this.
  3. Jul 12, 2022 at 7:18 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Call me skeptical, but if it's thinner and lighter that means less material is used and thus, less stronger than the OEM. It would be susceptible to breaking down faster (stress from high heat comes to mind) or crack/warp faster.
    It sound like a very unnecessary risk to take, just to save a few pounds?
  4. Jul 12, 2022 at 7:24 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Swapping to a lighter crank pulley on my tC (2AR motor) made a pretty drastic difference in mid-range torque and smoothed out the idle and acceleration. A very worthwhile upgrade on that platform.
    That said the 3.5 is a completely different motor, can't say for sure how it would work on the truck or if it would have any ill-effects. With an intake and tune mine is nice and smooth - I don't find myself requiring a lot of additional power on this - but I do appreciate upgrades that make the truck feel like it's working together better. I've looked into these a bit for the 2GR, but I always find better stuff to spend the coin on.
    Lol the factory crank pulley/damper is actually much more likely to 'break down' due to it being a multi-piece design. These are cnc'd out of aluminum chunk - breaking is not in their M.O.
    The factory pieces are normally heavier to help reduce cost and NVH, but like other factory components designed for the masses - there is a small performance hinderance due to the NVH reduction. Racecars use aluminum pulleys when they can but they can cause additional vibrations and noise in certain applications.
    12TRDTacoma likes this.
  5. Jul 12, 2022 at 7:27 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I've never seen an aftermarket crank pulley fail on a street driven car.
    Vmax540 and 12TRDTacoma like this.
  6. Jul 12, 2022 at 7:27 AM
    Sungod
    Sungod Well-Known Member
    St Augustine
    The stock pulleys are heavy, but I doubt you would notice the gains. Unless you are building a race engine where you are replacing everything that those little gains add up, it is little more than a cool looking set.
  7. Jul 12, 2022 at 9:22 PM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    Interested in this idea.
  8. Jul 12, 2022 at 9:49 PM
    CPS-65
    CPS-65 I’m good for some, but I’m not for everyone.
    Alta Loma, CA
    2019 Quicksand TRD Off Road 4X4
    Mostly old man mods
    See if the pulleys are a different ratio. It’s not uncommon to change pulley sets to slow the accessories and reduce their draw, however, this can create its own set of problems like belt tension, charging, or heating at idle.
    Weight itself won’t make much difference, what’s really robbing power are parasitic losses from the drag the accessories create. A heavier or better dampened crank pulls might smooth out the power pulses some, but I don’t think there is any real power to be had outside of slowing the accessories.
    How an engine delivers power can be (as part of the design) be tuned by flywheel weight. As a broad generalization, engines which go up and down the powerband a lot (road racing) will use a light flywheel whereas ones that spend most of their time in a narrow range (drag racing) will run a heavier one.
    I don’t think the mass is significant enough, especially given the other objects on the crank plane also moving in circular motion, to make much difference.
    Just one guy’s 2 cents though.
    12TRDTacoma and Phlogiston like this.
  9. Jul 12, 2022 at 11:51 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    The computer is more of a limiting problem than a couple oz's off a pulley
