Thoughts on Nitro Worm Gear LSD?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by axulsuv, Dec 15, 2019.
  1. Dec 15, 2019 at 12:12 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Hmm. I could certainly be incorrect, I’m admittedly not as versed in 3rd Gen as 2nd.
    shakerhood[QUOTED] likes this.
  2. Dec 15, 2019 at 12:18 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Confirmed in diff wizard, 3rd Gen is 8” and 8.75”. No 8.4 which is required for the truetrac.
  3. Dec 15, 2019 at 1:55 PM
    axulsuv
    axulsuv [OP] Trials Rider
    Glenn
    Conifer Colorado
    2018 white double cab sr 4x4
    Tyger Flares % bed cover , intermitant wipers ...
  4. Dec 15, 2019 at 1:57 PM
    axulsuv
    Glenn
    Conifer Colorado
    guess I gotta call them and make sure that's the correct unit for my truck ...
    shakerhood likes this.
  5. Dec 15, 2019 at 2:00 PM
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Link above not going to work in a 2018(?)
    kahanabob likes this.
  6. Dec 15, 2019 at 2:03 PM
    su.b.rat
    su.b.rat broken truck
    last i looked Eaton still had nothing for us. last looked maybe a year ago. no truetrac or posi yet. seems eventually the truetrac will show as these diff sizes fill up the planet. doubt the posi will show although that's my preference.
  7. Dec 16, 2019 at 8:41 PM
    axulsuv
    Glenn
    Conifer Colorado
    Aurburngear shows lsd ‘s for the 8 inch but their website leaves a bit to be desired...
  8. Dec 17, 2019 at 4:42 AM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    x2, had them in both the front and rear axles on my last vehicle. although if i were to do it over i would have only put one in the front axle, it made the vehicle very pushy through turns and the rear end had a strong tendency to kick out with almost no effort. did great in mud, loose gravel, etc...
  9. Jan 11, 2020 at 9:29 AM
    axulsuv
    Glenn
    Conifer Colorado
    had a talk with nitro gear , was told my doublecab SR v6 4x4 has a the 8' 50mm 30 spline diff , the gentleman sounded knowledgeable and had zero hesitation in his answers , Said they've done boatload of them , all happy campers ! Now to find some free time ….
  10. Jan 11, 2020 at 9:50 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    What’s odd is there website doesn’t back this up. Everything listed for the LSD is Landcruisers and Hyluxs.
    The only thing popping out to me is they specifically call out high pinion differentials. Toyota runs high pinion in the front but low pinion rears.
    If it was Tacoma compatible, why not list it?
  11. Jan 11, 2020 at 9:55 AM
    axulsuv
    Glenn
    Conifer Colorado
    Kinda thought the same , forgot to ask when the last time they updated the listings , might improve sales !!!!
  12. Jan 11, 2020 at 10:00 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I didn't care for my truetrac's behavior in the snow. The truck always had to to be in 4WD. That was in my 1st gen
  13. Jan 11, 2020 at 10:00 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Whats wrong with the LSD in 4hi?
  14. Aug 29, 2021 at 5:45 PM
    ZizzwheelTaco
    ZizzwheelTaco New Member
    Ralph
    2021 Tacoma Trail Edition
    TRD Bilstein Struts & Shocks MagnaFlow cat-bak 3 inch lift Fuel Wheels LT285/65R18 tires Katzkin leather interior
    Has anyone looked into the TORS-TV6-30 from Nitro yet ? In their catalog they list this for 2016 and up Tacoma's with the 8" rear differential. I'd like to buy one but would like to know if anyone has installed one. Guys at Nitro say they have installed quite a few.
  15. Aug 29, 2021 at 9:12 PM
    #35
    JoeCOVA
    Joe
    Colorado Springs
    Haven’t seen much talk on the forum about them or LSDs. They are less common as most throw in a locker but torsion designs with worn gears such as this are desired. I personally would go with Eaton based on reputation.
