Thoughts on Performance Chips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lifer, Apr 27, 2013.
Performance chips, good or bad idea
Poll closed May 27, 2013.
  1. Good Idea
    8 vote(s)
    12.1%
  2. Bad Idea
    58 vote(s)
    87.9%
  1. Apr 27, 2013 at 8:47 AM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
    Was thinking about putting one in my Tacoma. What are your thoughts? Good or bad idea? Or recommendations on some? And the one I was looking at is this one, http://www.gfchips.com/toyotatacoma.aspx
  2. Apr 27, 2013 at 8:50 AM
    kirkofwimbo
    kirkofwimbo Say no to Bro
    Clayton
    Austin, TX
    SOLD :(
  3. Apr 27, 2013 at 8:52 AM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
    Ya but im asking a different question than he did =)
  4. Apr 27, 2013 at 8:53 AM
    Oowen
    Oowen Well-Known Member
    Owen
    Elko, NV
    '09 Offroad
    Lift Armor Badassery with a shit ton of pin stripes 18% Tint
    Waste of money
  5. Apr 27, 2013 at 8:54 AM
    kirkofwimbo
    Clayton
    Austin, TX
    SOLD :(
    In what way? I'm not seeing a difference.
  6. Apr 27, 2013 at 9:13 AM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
    What would be a good performance chip for a 4.0L tacoma that improves gas mileage plus horsepower/torque??? Thats what he asked. I'm asking if its a good idea. And if so which would be better for my truck. not his truck ;)
  7. Apr 27, 2013 at 9:13 AM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
    But why is it a waste of money?
  8. Apr 27, 2013 at 9:19 AM
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    The GForce chip will fry your engine. Its junk.
    It just advances timing to the point of being unsafe.
  9. Apr 27, 2013 at 9:29 AM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
  10. Apr 27, 2013 at 9:37 AM
    custom90gt
    custom90gt Well-Known Member
    Colorado
    05 SWB TRD Off Road
    All this "chip" does is change the resistance for the intake air temperature sensor so that the truck thinks it's cooler outside than it really is and it advances the timing. You could do the same thing with the proper 50 cent resistor from radio shack. Bad idea is my vote...
  11. Apr 27, 2013 at 9:38 AM
    custom90gt
    Colorado
    05 SWB TRD Off Road
  12. Apr 27, 2013 at 10:02 AM
    B11
    B11 Well-Known Member
    N.E. Wa.
    2013 TRD Off Road
    Is now SuperCharged
    I've personally never seen a "chip" in a gas motor equipped vehicle do anything. If we were talking about a diesel or maybe a turbo equipped vehicle then I would say go for it, otherwise, I'd say save your money.
  13. Apr 27, 2013 at 11:39 AM
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    Justin, chips work well for some applications. The Buick Grand National turbos (circa mid-1980's) come to mind, but I just don't see how they'd help our normally aspirated 4.0s.
  14. Apr 27, 2013 at 11:46 AM
    haider320
    haider320 Well-Known Member
    Roswell, NM
    2013 MGM Double Cab SR5 4x4
    "Chips" are nothing but snake oil. "Chips" you see today do nothing. Today it's called a "tune"; in which you have a hand held programmer that rewrites the factory ecu tune. Most are safe and put out decent numbers. However, if you run into engine problems, and the dealer finds an aftermarket tune; you run the risk of voiding your power train warranty.
  15. Apr 27, 2013 at 11:47 AM
    RiverBoyTRD
    RiverBoyTRD Well-Known Member
    Jonathan
    San Antonio
    05 TRD OR
    2 Hellas, 3 inch, spiders, grill guard, 285's, BHLM etc.
    Thinks......thought.....my thoughts are ummm...no
  16. Apr 27, 2013 at 2:27 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    The ONLY chips that do anything are the URD and the Unichip.
    They only operate when the engine is running in open loop... wide open throttle.
    The one you linked to is claiming fuel economy increase of 10% and 30hp.
    It's complete bullshit.
    Tipoff #1: MSRP $399 selling for $69?
    Drop-ticket marketing. The most expensive part is the fancy aluminum case and the monthly fees for their web page. It's a 50 cent resistor that plugs into your MAF or IAT and throws the fuel mixture off.
    Tipoff #2: You select the make and model truck, but don't specify your engine until AFTER giving them your name and address.
  17. Apr 27, 2013 at 2:56 PM
    teamamerica
    teamamerica Get off your horse and drink your milk.
    Wy
    2009 tacoma
    none yet
    dont you think that if there was an way to increase the Hosepower/gas mileage, toyota would of done that to begin with? chips work in some older vehicles and help, but since the 2000's vehicles have had one thing in mind. maximum milage for maximum Horsepower.
  18. Apr 27, 2013 at 2:56 PM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
    Well I work at a Toyota Dealership so I could always just take if it off if I needed to. But from the sounds of it its just a bad idea. Maybe ill go for a TRD supercharger instead! :p
  19. Apr 27, 2013 at 2:58 PM
    Lifer
    Lifer [OP] Member
    Justin
    St. George, Utah
    06 PreRunner
    Ya i thought that was pretty sketchy. Thanks for your input! Definitely not going that route!
  20. Apr 27, 2013 at 3:03 PM
    haider320
    Roswell, NM
    You get a supercharger, you will still have to get a tune to accommodate for fi. Like Ford and its Mustangs(since I have a lot of experience with the Mustang); if you let the dealer do the install and install a Toyota factory tune for the supercharger; you'll be good to go on your warranty.
