Thoughts on Prerunner?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2ndgenron, Mar 20, 2024.
  1. Mar 21, 2024 at 6:17 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Oh yeah, forgot to mention that you have the highest (or close to the highest) payload. Maybe it's second (1250), behind the 4 cylinder access cab Prerunner (1300), if I remember correctly from my 2012 manual.
    2ndgenron[OP] likes this.
  2. Mar 21, 2024 at 7:34 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad, 2022 Honda CB500X
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Are the 1250 and 1300 what you think are the highest payload numbers? They can definitely be higher.
    My 2011 DCSB TRD OR is either 1540 or 1550 for payload, as found on the door jamb label. (ANOTHER EDIT: my memory must be failing me, I can't find the pic of my door sticker but will need to verify. I regularly ignore that number anyhow)
    EDIT: not disagreeing that the prerunner should have more payload, though. Which is an obvious plus.
  3. Mar 21, 2024 at 10:45 AM
    Schlappesepple
    Joe
    2020 4Runner ORP
    From my manual:
    I have seen higher numbers online, but not from Toyota sources. And different years may be rated differently.
    2ndgenron[OP] and YF_Ryan like this.
  4. Mar 23, 2024 at 2:06 PM
    2ndgenron
    2ndgenron [OP] Well-Known Member
    Ron
    2nd Gen 2007 access cab
    I read somewhere payload is 1550 lbs. I’ll probably keep my pre runner for life and get a 4WD 4Runner or new Land Cruiser?
  5. Mar 23, 2024 at 3:55 PM
    CrazyCrewChief
    CrazyCrewChief Unknown Member
    Gordon
    NorCal
    2015 Tacoma AC TRD Sport MGM
    Love my Prerunner! Almost nine years old and about 124k on miles. I bought the truck new because I wanted the Access Cab, 2WD and the Bilstein suspension.
    2ndgenron[OP] and winkel like this.
  6. Mar 23, 2024 at 5:59 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Getting ready to put a Trutrac in my prerunner. That will get me anywhere I need to go.
    mojojojo78 and winkel like this.
  7. Mar 24, 2024 at 1:01 PM
    Regnar
    Regnar Well-Known Member
    Kodiak,AK
    2014 DCSB PreRunner SR5
    10 Years with the Pre Runner and only 1 time I wish it had 4x4. Tried doing a Uturn on a icy road and got stuck in the tire ruts. The truck has been just about everywhere in Alaska to the beaches in Florida. Everything that I want to do with 4x4 I dont want to do with my daily driver.
    Sidney Vicious and 2ndgenron[OP] like this.
  8. Mar 26, 2024 at 1:30 AM
    bkrdave36
    bkrdave36 Well-Known Member
    Dave
    Wittmann,AZ
    06 Prerunner Double Cab Black
    Front OME Springs, Upper Control Arms, Icon Stage 3 Rear Leaf Springs, Durobump bump stops,Bilstein 5125 shocks, BFG All Terrain KO2 Tires, Avid Light bar and step rails, Victory 4x4 bed rack with Tepui Ayer Rooftop Tent, Anytime Fog light mod, Outside Air Temp Gauge mod, ImMrYo Rearview Mirror mod, Chinese Knockoff LED lights, Body Armor 4x4 Offroad Swingout rear tire carrier and bumper, Victory 4x4 Bed Stiffeners, Rattle can Custom Camo paint stripe, Truxedo Lo Pro tonneau cover, various Blue Ridge Overland Gear storage solutions in cab, thats it so far .... to be continued!
    My 2006 Prerunner has 438000+ miles on it. Its my daily so I don't thrash it. I rebuilt the motor due to the dreaded head gasket leak. The cost to replace the gaskets was only a little less than a full rebuild at a local shop. Drivetrain is pretty stock. I added Bilstein 5100 series shocks all around, an Icon RXT Stage III leaf pack to the rear and Durobump bump stops. Other things added were a light bar on the front, a steel rear bumper with swing out spare tire carrier on the back, and a bedrack and RTT.
    I usually stick to forest roads and well worn desert trails. I'm not a rock crawler and I detest sand. I only got stuck two times. Once in a stream crossing that had a soft spot and the other time in sand. Did I say I detest sand? Anyway, I've since got a pair of Maxtrax just in case.
    My next move will be to get a steel front bumper so I can put a winch on it (and do the appropriate suspension upgrades to support the weight).
    Take care of it, and it will take care of you. Happy trails brother!
  9. Mar 26, 2024 at 8:24 AM
    MBO
    MBO Well-Known Member
    You'll still have great experiences with the 2wd. My first tacoma was the prerunner and I don't regret it. But the more you take it places (outside Socal) you'll see how much your horizon can expand with the 4wd.
  10. Mar 26, 2024 at 8:35 AM
    CrazyCrewChief
    Gordon
    NorCal
    That's why I also have a 4Runner.
  11. Mar 26, 2024 at 12:47 PM
    MBO
    Im hearing good things about 4runners. Can't go wrong with either
  12. Mar 28, 2024 at 7:16 AM
    2ndgenron
    Ron
    Amazing! I want the 5100s on my truck and eventually an ARB bumper. I believe the early 2005s and 06s were prone to head gasket issues. I’m at 266k miles at the moment. She ticks but I think it’s normal. Cheers
  13. Mar 28, 2024 at 7:18 AM
    2ndgenron
    Ron
    I’ll have my Tacoma till it rusts, next vehicle would be a 4WD 4Runner and a Prius for commuting
  14. Mar 28, 2024 at 8:32 AM
    MBO
    Maybe you can shed some light on the rust factor. Seems like a pretty common topic of conversation on here. Whereabouts specifically under my truck should I be looking to see if rust is becoming an issue?
    2ndgenron[QUOTED][OP] likes this.
  15. Mar 28, 2024 at 9:30 AM
    #35
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    the whole frame but:
    leaf springs connection to the frame
    inside of the frame rails by the secondary cats ob V6s, hammer test rots inside out
    any area that get a lot of splash from the tires
    MBO[QUOTED] likes this.
  16. Apr 17, 2024 at 5:54 PM
    #36
    bkrdave36
    Dave
    Wittmann,AZ
    You are correct about the head gasket issue. Keep an eye on your cooling system. If the motor overheats, you are highly likely to warp the head causing the leak. Check everything, including the hoses.
  17. Apr 17, 2024 at 7:03 PM
    #37
    2ndgenron
    Ron
    Correct, I don’t hear any noises coming from water pump, I just noticed there is coolant dripping from hose connecting to reservoir
  18. Apr 17, 2024 at 7:08 PM
    #38
    Fishsticks4Breakfast
    Fishsticks4Breakfast Member
    2014 PreRunner Access Cab
    Original owner, 2014 PreRunner, 2wd, access cab, 150K miles. Does everything I need it to, will keep for years to come. Put Bilstein 4600's all around it about a year ago just because. Looks and drives as good as the day I drove it off the lot. All maintenance kept up to date, even replaced the spare tire recently just because - actually (fortunately) never used it, but figured 10 years underneath the truck it was due to be replaced.
    CrazyCrewChief and 2ndgenron[OP] like this.
  19. Apr 17, 2024 at 8:02 PM
    #39
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Many don't realize how good modern drive-by-wire traction control has become. It basically makes up the former gray area between "I'd rather have 2wd for weight savings, cost savings, and simplicity" and "I need 4x4 a few times a year when I have to drive in the mud or snow".
    The serious 4x4 crowd know who they are and don't need to bother with this debate.
  20. Apr 17, 2024 at 9:36 PM
    #40
    bkrdave36
    Dave
    Wittmann,AZ
    If I were you I would go through every inch of the cooling system and check everything.
