Thoughts on rear bumper design?
Discussion in '1st Gen. Tacomas (1995-2004)' started by wolfgang123, Apr 20, 2013.
  1. Apr 20, 2013 at 10:48 PM
    wolfgang123
    wolfgang123 [OP] Well-Known Member
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    Just finished this in sketch up, looking for input, comments, suggestions or what ever before i move to the next step.
    Thanks fellas!!
  2. Apr 21, 2013 at 7:33 AM
    therexinator
    therexinator Central Oregon Member
    Rex
    Central Oregon
    1998 Toyota Tacoma TRD Supercharged
    Black billet grille, clear lights all around, black rear bumper.
    That looks awesome man!!
  3. Apr 21, 2013 at 11:44 AM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    impressive, few suggestions:
    1) will the side protectors be flush with the fender or stick out a bit?
    I would have it stick out a bit.
    2) do not forget to have a mount for a light for your license plate... it's required for inspection.
    3) for the tow hitch receiver, I did not see the hole for the lock pin.
    Can't wait to see the build!
  4. Apr 21, 2013 at 4:33 PM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    License plate led strip 6 inches long:
    Receiver Pin hole:
  5. Apr 21, 2013 at 4:37 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Don't forget hooks for the trailer chains also. :)
  6. Apr 21, 2013 at 4:39 PM
    TejasYOTA
    Nathan
    Country of TEXAS!
    Cool... question, are you going to weld it onto the frame or bolt on?
    My CBI was originally bolt on... but after awhile... it started to sag... so to fix it... I had it welded. :D
    You can see it in my Garage Section of TTORA.
  7. Apr 21, 2013 at 4:40 PM
    RAT PRODUCTS
    RAT PRODUCTS RAT Products
    Farmington, MN
    2016 Sierra Denali
    It's a high clearance so you cut the bed sides, correct?
  8. Apr 21, 2013 at 4:48 PM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2000 SR5 TRD 4x4 Ext Cab V6 Manual
    Looks somewhat similar to mine, minus the swing-out.
  9. Apr 21, 2013 at 6:52 PM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    it will be bolt on i just haven't done the measurements for the brackets yet, it will also be high clearance so i do plan on cutting the bedsides, where should i put the mount for the tow hook chains? maybe like this? (i don't really like this idea)
  10. Apr 22, 2013 at 11:44 AM
    Pugga
    Massachusetts
    F-150 Mod
    Mine just looks like an oversized chain link welded to the bottom of the receiver part. Very simple, just a metal oval welded to the bottom.
  11. Apr 22, 2013 at 8:20 PM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    I like this a lot better i think i will stick with it. Any other suggestions?
  12. Apr 22, 2013 at 8:24 PM
    BAMFTACO
    BAMFTACO CASH ME OFFROAD HOW BOUT DAT
    Jośe
    Woodlandland hills , CA
    Taco
    Lift- king 2.5 with light racing uppers,tc coil bucket gusset, 4 in spindles,timbern bumps all around ,wheelers 3 addaleaf, ato shackle flip kit with 6 inch HD shackles. Armor- tire gate, custom tube bumper, kr fab rear bumper,trail gear wiy 78 in sliders Performance-intake manifold spacer, hps silicone hoses Random stuff- kenwood head unit,b&m t shifter, hood bug deflector, rear dust lights with custom bed bar and hi lift mount.
    That's gunna look good nice and tucked up
  13. Apr 24, 2013 at 8:28 AM
    streamreeper
    streamreeper If you gonna shoot,shoot-don't talk
    matt
    the woods of western new york
    04 tacoma TRD. -2009 acess cab 4x4 green.
    2004 new frame dif breather deck plate ome 881's nitro's dakkar leafs nitro's access tanoue cover
    i love the led light over the plate! around here the number one reason cops pull you over is an inadequate light on the plate. good move i might just do that now thanx
  14. Apr 28, 2013 at 2:44 PM
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    that is exactly what i want to build for my truck. Is there anyway to get the dimensions for that?
  15. Apr 28, 2013 at 2:51 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    any reason you didn't put the recovery points directly next to the frame mounting plates? Then you wouldn't need that small piece of square attaching them to the frame plates.
    I'd also ditch that piece of flat stock attaching the hitch to the frame plates, it wont do much unless it's like 1/2". Instead have gussets on the back side of the hitch both in the vertical and horizontal directions. 1/4" should work for the gussets.
  16. Apr 28, 2013 at 3:18 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    07 sport, ARB rear locker, leveling kit
    ARB rear locker Leveling Kit Custom Rear Bumper Tires and Rims Air tank fully plumbed into truck
    If it helps, here are a few pics of the onsides of a few of the bumpers I have built
  17. Apr 29, 2013 at 9:20 AM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    I put the recovery point were they are (inward of frame plates) was strictly for aesthetics i might consider changing it but i love the way it looks from the rear, i am open on other opinions here if you have some ideas. :D
    i would like to ditch the flat stock now that you mention it. i should probably gusset the frame plate too, right? since i would be removing the flat stock?
  18. Apr 29, 2013 at 9:22 AM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    thats awesome! however this will only be my 3rd major fab project so i am looking to keep it simple and use rectangle tube for the whole thing.
  19. Apr 29, 2013 at 9:26 AM
    wolfgang123
    Skyler
    Statesboro, GA
    1997 TACOMA - 4x4
    I measured before i made the model. however i made SUPER quick measurements, they are good start point but by no means 100 percent accurate, this is only my first draft once i am happy with the design i am going to start from scratch and use more precise measurements.
  20. Apr 29, 2013 at 9:34 AM
    gatorboyy13
    gatorboyy13 Well-Known Member
    Brian
    Corvallis, OR
    2016 TRD OR DCSB Black
    CustomCarGrilles Small Perf & "TOYOTA" Grille Insert CaliRaised 31" Light Bar w/ ApexFab Stealth Mounts Header Rail w/Bike Mount
    First off, The bumper looks awesome! Great job on that! Just got into welding myself for this reason mainly, hopefully I'll have my own designed and built bumpers soon!
    Is that MIG welded?
