Thoughts on Redline oil.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Alaba4.02006, Jun 13, 2019.
  1. Jun 13, 2019 at 1:26 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    The 3rd gen tacomas are on a 10k oil interval schedule according Toyota
  2. Jun 13, 2019 at 1:47 PM
    hdn4space
    hdn4space Well-Known Member
    FL
    2013 Silver SR5 4x4
    Never used their motor oil. I've used their 75-85 in my front/rear diffs. Good quality product, kinda pricey.
  3. Jun 13, 2019 at 2:07 PM
    Taco'09
    Taco'09 Well-Known Member
    TacomaMike37, scocar and DaveInDenver like this.
  4. Jun 13, 2019 at 2:09 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    It's your truck. Use whatever puts your mind at ease.
    Since I'm paying the bills for my truck. That's what l do. But I don't go for the pricey stuff. l just grab whatever 10w30 l can find.
    5k mile intervals.
  5. Jun 13, 2019 at 2:10 PM
    TacomaSport86
    Yep brand doesnt matter
    Rick's 2012 likes this.
  6. Jun 13, 2019 at 9:30 PM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Redline will out perform the other oils but not by a huge margin so I guess it comes down to weather or not that little bit of extra quality is worth the cost to you. I’ve used other top shelf oils and never had any kind of problem with them
  7. Jun 13, 2019 at 9:37 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I would like to see under that engine's valve covers as well as behind the timing cover. There is an inspection cover on the passenger side. Be a good place to take a photo for science.
    b_r_o likes this.
  8. Jun 13, 2019 at 9:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You guys are all wasting your money. Just use assembly lube. Saves weight by only needing a fraction of the quantity. Has high antiwear additive content for the extended reapply.
    Redline assembly lube that is. For those with discerning pompousness.
    ecoterragaia and b_r_o like this.
  9. Jun 13, 2019 at 11:31 PM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    Same here
  10. Jun 14, 2019 at 3:08 AM
    TacomaSport86
    I'll do it when I get the chance. I have looked before and no gunk nice and clean.
    Torspd[QUOTED] likes this.
  11. Jun 14, 2019 at 3:29 AM
    wags
    wags Well-Known Member
    Walleye Capital of the World, Ohio
    2012 2.7L 5-Speed Manual SR5 4x4
    Same here, and Redline MT90 (75W-90) in my transmission & transfer case. I'll stick with Mobil 1 for my engine oil.
    In the Harley Davidson big twin community, Redline is a premium oil company that gets many kudos. Mainly for transmission and primary oil uses. I've never used it in any of my v-twins though. Spectro is my choice.
  12. Jun 14, 2019 at 5:08 AM
    Truc577
    Truc577 Well-Known Member
    Curt
    NOMO
    2005 TRD OR 4x MT, 2020 TRD OR 4x AT
    High output valve stem caps 2020: Bilstien 6112/5100 Mobtown sliders RRW RR-5 Bronze wheels 2005: 2018 frame and full suspension 2017 Dark Anthracite wheels ARB front bumper
    Golden black is still golden
    TacomaMike37[QUOTED] likes this.
  13. Jun 14, 2019 at 5:12 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Truc577[QUOTED] and Sig45 like this.
  14. Jun 14, 2019 at 5:25 AM
    Truc577
    Curt
    NOMO
    :rofl:If you smear it out on white paper...
  15. Jun 19, 2019 at 9:54 PM
    #35
    dlopan
    dlopan Well-Known Member
    Dave
    Albuquerque, NM
    2015 Pyrite Mica 4wd DCSB TRDSport
    Camper shell, CB radio. R-pod 179
    Another oil thread..
    I use M1 5w-30 I get at costco. Valvoline in the differentials and t-case.
    Regular Toyota oil filters I buy by the case.
    I change the oil 2 times a year (5k)
    Redline is really good oil probably the best you can get in the US but expensive
