thoughts on replacement antenna on my 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake1530, Sep 19, 2021.
  1. Sep 19, 2021 at 3:00 AM
    Jake1530
    Jake1530 [OP] Well-Known Member
    2015 Tacoma TRD
    It got bent (not bad) took it off and bent it back, but the black paint is off on some it. Thank you guys
  2. Sep 19, 2021 at 3:45 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I wanted an antenna that was long enough to use as a go/nogo gauge for my truck for garage doors and low limbs, the stock one was shorter than the highest point on my truck (snorkel/lightbar) so I went to my local pull a part and measured a few, found one that was perfect length for me off a Kia with the proper threads.
    Works just great, both as a height limit checker and as an antenna even if I haven't listened to the radio in years.
    Junkyard just let me take it free.
    If you don't use tour radio and have no alternative need like me I'd just remove the internal mast and put a dummy plug in the hole.
    TnShooter likes this.
  3. Sep 19, 2021 at 10:39 AM
    Yota105
    Yota105 Well-Known Member
    Jeremy
    Manchester
    15 MGM DCLB 4X4 (work in Progress)
    Just need more $$$ and time!
  4. Sep 20, 2021 at 11:35 AM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    I have a low overhead garage door and the stock antenna would clang across every time I parked inside. Replaced with a 21" antenna (A417-TY) from TheAntennaSource. No more annoying clanging, AM/FM still works, looks OEM, nobody else knowns the difference. Cost was like $25.
