Thoughts on Ruthenium plugs?
Discussion in 'Technical Chat' started by 19cfk58, Mar 21, 2021.
  1. Mar 21, 2021 at 12:56 PM
    19cfk58
    19cfk58 [OP] Member
    Charles
    2009 extended Tacoma V6
    just brought 2009 Tacoma V6 Black extended cab 2WD 180000 miles one owner.
    Says he never has changed spark plugs ever. Thinking about NGK ruthenium plugs.
    can't get enough info if it would work.
  2. Mar 21, 2021 at 1:05 PM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    180,000 on original plugs? Wow, when you do the plug change try and post a pic of how they look, would be curious to see. As for the rutheniums I see no problem to give them a try. Some of the supercharged guys are using them and so far seem happy. As long as they are the proper heat range for your truck I see no problem besides paying a premium price. Also, how about other maintenance, did the previous owner keep up with that oil, filter, etc...?
  3. Mar 21, 2021 at 1:08 PM
    Clearwater Bill
    Billy
    Largo Florida
    THAT is the ticking bomb question.
    Along with the frame condition if it was a salt country truck.
    doublethebass likes this.
  4. Mar 21, 2021 at 1:10 PM
    19cfk58
    19cfk58 [OP] Member
    Charles
    everything else is good and maintained
  5. Mar 21, 2021 at 1:11 PM
    19cfk58
    19cfk58 [OP] Member
    Charles
    truck life has been in Texas
  6. Mar 21, 2021 at 1:28 PM
    19cfk58
    19cfk58 [OP] Member
    Charles
    what does manufacture heat range mean? NGK is 6, denso is 20
  7. Mar 21, 2021 at 1:38 PM
    Amo-cat3
    Maui, Hawaii
    07 TRD Blown dubcab
    It can be confusing, but different manufacturers have different numbers which represent the same heat range, so both of the above plugs will work.
  8. Apr 2, 2021 at 7:39 PM
    Steamy Longbottom
    Steamy Longbottom Well-Known Member
    1LT Browneye
    East TN
    '21 Army Green TRD O/R 6MT
    Modifications are bad and only bad people modify.
    Interesting that there are ruthenium plugs for the 2nd gen but not the 3rd. I'm guessing many people 2016+ and up probably haven't got to the change interval.
    Have you had a chance to change the plugs yet?
  9. Apr 5, 2021 at 1:36 PM
    findingthingsout
    findingthingsout Well-Known Member
    midwest
    08 Tacoma TRD O/R A.C. MT
    Boost, armor, lights, big tires, no savings.
    Heat range conversion.
    --> https://www.ngk.com/heat-range-conversion-chart-2
    Ruthenium's will work but they have not been made for our specific application. They boot side connection is wonky. Several are running them as guinea pigs, with success so far.
    I'm sticking to Iridiums for my S/C application until...
    Steamy Longbottom likes this.
