Thoughts on seating improvements in the
Discussion in '4th Gen. Tacomas (2024+)' started by pMill, Jun 15, 2024.
  1. Jun 16, 2024 at 7:38 AM
    Txbudsmuggler
    Txbudsmuggler Chancla con queso
    4th gen TRD OR
    If thats an issue for you than you should definitely take that into consideration before deciding to buy this truck. The 4th gen is higher, or at least higher than my 3gen sr. So my dog has to jump a little higher to get in.
    pMill[OP] and Delta09[QUOTED] like this.
  2. Jun 16, 2024 at 8:41 AM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea it's notably taller than my past 3rd gens. I can get in it just fine despite my bum left knee.
  3. Jun 16, 2024 at 1:51 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Do you have side steps?
    Delta09[QUOTED] likes this.
  4. Jun 16, 2024 at 1:55 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    No I do not. I had a set on my 3rd gen and they actually made it worse o_O
  5. Jun 18, 2024 at 11:33 PM
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    Installed last night, just sat in for a minute and it felt much better.
    Kit comes with 4 spacers, 2 thicker and 2 thinner. Install one, the other or both depending on the angle you want. Just the thicker one works best for me. Will do the passenger side next, will try just the thinner ones, if sufficient, I just need 2 new bolts. Otherwise, I'll order a new kit.
    pMill[OP] likes this.
  6. Jun 19, 2024 at 1:05 AM
    pMill
    pMill [OP] Well-Known Member
    2023 TRD OR
    @Want-a-taco please keep providing updates as your issues resemble mine. I will have power seats, but I think these will help also.You added the spacers to the rear of the seats, correct?
  7. Jun 19, 2024 at 3:31 AM
    Want-a-taco
    That's correct. On cars with power seat, it's usually possible to raise/lower the front independently from the back. I could also with my 1988 Camry and 2012 Xterra because they had 3 knobs on the side for adjustments.
    pMill[QUOTED][OP] likes this.
  8. Jun 19, 2024 at 4:37 AM
    Poot Klopp
    Poot Klopp Well-Known Member
    Ben
    New Jersey
    2024 Bronze Oxide TRD OR
    I'm confused but your pricing explanation. You can get a manual OR with the upgrade package and it's $4,625 and gives you power seats.
  9. Jun 19, 2024 at 6:24 AM
    Want-a-taco
    In Canada, we have limited options for MT. TRD OR or TRD Sport, and it's not possible to add on options to either of those. We get them as-is or not at all.
    Poot Klopp[QUOTED] likes this.
  10. Jun 19, 2024 at 6:44 AM
    Want-a-taco
    Went for a short drive, 12km round trip. Feels much better, especially on the left leg when having to hold the clutch in at a stop or light.
  11. Jun 20, 2024 at 6:39 AM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Agree with this 100%.
    I bought the front kit for the front 2 seat bolts off Amazon for $30 CDN. Greatly improved seat comfort, did not impact visibility out the front windshield, headroom or shifting (I've got a manual).
    A little tighter to get knees around the steering column while getting in the truck and the keys jangle on my knees a bit more - but this is nothing major. As an FYI I'm 6 foot tall.
  12. Jun 20, 2024 at 6:41 AM
    pMill
    2023 TRD OR
    @Want-a-taco - thanks for the update. Even the my new to me (still looking for the right one) OR comes with power seats, I still may give these a try.
  13. Apr 17, 2025 at 8:03 PM
    laocie
    laocie Member
    2025 4x4 SR5 Tacoma, TRD 2 inch suspension and TRD exhaust
    Yeah the seats are lower, which caused a problem with the seatbelts. When I first got into mine, the seatbelt was rubbing up against my leg and my stomach. When I talked to Toyota, they said just to lift the seat up higher. They are very uncomfortable and there’s little to no room in the back. This will be my fourth Toyota and my third Tacoma and I have to say this one is very disappointing.
  14. Apr 17, 2025 at 8:17 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Holy sh*t.. you thought the 3rd gen seat comfort and ergonomics were worse than a 2007 Civic? Go full size.
  15. Apr 18, 2025 at 12:37 PM
    #35
    dweid
    dweid Member
    Toyota dealers (at least locally here) will rent vehicles to you.
  16. Apr 18, 2025 at 2:46 PM
    #36
    TACODOC1
    TACODOC1 Well-Known Member
    SoCal
    2024 Tacoma Trailhunter - Bronze Oxide
    This. 2G and 3G seating was “on the floor” compared to a more conventional arrangement in the 4G.
    YMMV, but I vastly prefer the 4G seats.
    Gamma11[QUOTED] likes this.
  17. Apr 22, 2025 at 9:49 PM
    #37
    jaylee
    jaylee Active Member
    jay
    Santa Cruz
    tacoma
    not yet
    I need to try the to get the rear of my front seat up a bit due to 3 crushed disc’s in my lower back. I use the pump on side of seat but it drops down over time and really hurts when I go long distances. The seat jackers work on 4th gen? The jungle site don’t have them yet for 4th gen, that I have seen anyone got a link?
  18. Apr 22, 2025 at 10:04 PM
    #38
    MGMDesertTaco
    https://desertdoesit.com/products/seat-jackers-2024-toyota-tacoma
  19. Apr 25, 2025 at 12:09 PM
    #39
    laocie
    laocie Member
    I don’t even have 1000 miles on my new fourth GEN. I have had nothing but issues with the seat, the safety belt and the comfortability of the truck. This thing is built like crap it rattles and shakes and makes all kinds of noises when driving down the road. The seats are uncomfortable, the Lombard support cracks and crinkles like it’s not actually hooked up correctly. My suggestion would be keep your third GEN. I miss mine .
