Thoughts on spindle lift ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by reidu8, Apr 14, 2015.
  1. Apr 14, 2015 at 7:57 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
  2. Apr 14, 2015 at 8:07 PM
    VolcomTacoma
    Jeff
    NorCal
    Just sayin :D
  3. Apr 14, 2015 at 8:14 PM
    Kerleyfries
    Kerleyfries Idk what the hell I'm doing
    Zack
    Lebanon
    ‘17 F150 and SAS ‘98 4runner
  4. Apr 14, 2015 at 8:16 PM
    VolcomTacoma
    Jeff
    NorCal
    Prob $100 on spindles. Still less than new :D. I'd wait for a holiday for free shipping from All-pro for the expos.
  5. Apr 14, 2015 at 8:23 PM
    Kerleyfries
    Zack
    Lebanon
    Shit, If you could get all of that securely strapped down on a pallet and dropped off at fastenal, I bet it'd be about $150 for all of it shipped (If fastenal operates out there, not sure?) lol. GLWS though.
    Back on topic, I think spindle lifts are great for prerunners. They keep the factory geometry and allow you to put factory height springs that allow for a softer ride than most lift springs and still get a 4" lift or you could stack them with say, some OME 885's on 5100's and get 7" of lift.
  6. Apr 14, 2015 at 8:31 PM
    millertime89
    millertime89 Flatlander
    Erik
    Saskatchewan
    06 TRD Sport DCLB 4x4
    Yes sir
    Gross... a mall crawler :D To each his own I suppose. But for what it's worth, I would also recommend just going with a DB lift, I can't imagine the prices will be that different considering all the stuff everyone's said you'll need with the spindles. Just my .02 though
  7. Apr 14, 2015 at 8:36 PM
    Kerleyfries
    Zack
    Lebanon
    All that you NEED with spindles is extended brake lines. So lets call it $750 shipped for a factory riding 4" lift for the front.
  8. Apr 14, 2015 at 9:18 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    Yea for the front like you said, and I mean he should definitely be doing it right the first time, which means going further than what he "needs." Like you don't need new UCA's when you lift with let's say an icon or OME lift, but it's a very good idea.
    In my opinion, do it right the first time. But I mean, I hate anything higher then 3 inches of lift on tacomas because it isn't practical generally. But again, just my opinion :D
  9. Apr 14, 2015 at 9:23 PM
    Kerleyfries
    Zack
    Lebanon
    Uca's aren't needed at all with spindles, it would be like putting aftermarket uca's on a non-lifted tacoma. The Uca's are to correct the suspension geometry, which is not necessary since the spindles keep factory geometry. Just spindles and brake lines is doing it 100% right.
    But if you're so for "doing it right the first time" then why are you on a 2.5" spacer lift? Just curious. Kinda contradicting yourself there.
  10. Apr 14, 2015 at 9:46 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    1. I was using the UCA's with my example of doing it right with a different setup like OME or icon. I don't know all the specifics about spindles but I'd go further than the basics that you need to get the lift done.
    2. I'm completely honest in my mistake for buying spacers, if you read whatever you read to find that out, I'm sure you'd notice I'm upgrading to an OME setup. My stuffs in the garage but I haven't put it on yet.
    3. It's not contradiction if I'm aware of my mistake and now adamant about doing it right the first time. Sooooooo what's your problem? You seem really upset. If you look at the title of the thread, it says "Thoughts on spindle lifts?," and my thoughts are not to get em
  11. Apr 14, 2015 at 9:53 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    When people ask for thoughts, the implied task is informed thoughts.
    Besides a long travel suspension system, there's no better suspension system for a two wheel drive than a spindle lift. Maintains factory ride while gaining pure ground clearance (no drop bracket). No permanent modification to the vehicle, unlike some DB lifts that require welding the DB in place.
    The purpose of a UCA on a mid-travel lift is to bring the camber back in spec. That's not an issue with the spindle lift. The additional travel gained (which is minimal and requires coil overs to gain) is of no use to a guy who states he will not offroad the truck, and the heims will just wear out faster than ball joints and are prone to be noisy.
    And lastly, (multiple) mostly stock trucks that cruise dirt roads look silly when they start throwing out the terms "mall crawler" and "pavement princess". If AAA will come rescue you, you're not offroad - despite what they put on the bill. The man just wants to lift his vehicle for looks - there's nothing wrong with that.
  12. Apr 14, 2015 at 10:13 PM
    Kerleyfries
    Zack
    Lebanon
    I'm not upset in the least bit, I was just trying stating what I knew on the subject at hand. I was throwing it out there that spindles were all thats necessary and especially if no serious offroad is done, there is no reason to go over-kill with upgrading every little piece along with spindles. They are an easier and less permanent modification than a DB lift. As far as your spacer lift goes, I commend you for admitting mistake and replacing them with an OME setup, I didn't go any farther into you other than the mods that popped up when I scrolled over by your name. I'm not here to get in a dick measuring contest or argue. Just trying to discuss opinions on spindle lift and was waiting on you to say why you thought a DB would be better than a spindle lift for a 2wd.
  13. Apr 14, 2015 at 10:26 PM
    millertime89
    Erik
    Saskatchewan
    Yes sir
    I'm sorry, I'm wrong and I'm saying this sincerely and I'll leave it at that. But I wanna say my dick is bigger though...
  14. Apr 14, 2015 at 11:04 PM
    Kerleyfries
    Zack
    Lebanon
    Lol. You're fine. I was kinda being a dick, sorry about that. Engineering and Calculus work were starting to piss me off so I got on here and I guess released some anger. But my dick is definitely the biggest.
  15. Apr 13, 2021 at 10:17 AM
    #35
    jfit7468
    jfit7468 New Member
    Justin
    2015 Toyota Tacoma Trd 4x4 Texas edition
    6 Inch rough country lift , 20x12 fuel chrome offsets with 33 inch fuel gripper my’s, true dual exhaust cat back to 5 inch tips
    I currently have a 4 inch spindle lift on my tackle for the front but I also have some 4.5 inch strut spacers I was thinking about adding. Does anyone know if it will work even though I already have the extended spindle ?
