Thoughts on These Allignment #'s
Discussion in '1st Gen. Tacomas (1995-2004)' started by Red_03Taco, May 1, 2024.
  1. May 1, 2024 at 2:22 PM
    Red_03Taco
    Red_03Taco [OP] Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Just got my truck back from the alignment shop yesterday afternoon. I installed Icon 2.5 VS coilovers and Delta Joint UCAs over the weekend. I for some reason had it in my head that I should be able to get 3.5-4.0° of positive castor. Instead the alignment tech couldn't get it over the mid 2's. Does that sound about right for this setup?
  2. May 1, 2024 at 2:37 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    Looks good to me, Jerad. All within specs :)
  3. May 1, 2024 at 6:38 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    1) the (modified specs) means he changed one of the specs most likely so everything will print green. All he did was fix the toe and for some reason add camber to the passenger side? There looks to be no attempt to adjust the caster or camber. If you like the way it currently drives I wouldn't bother but if you find it wonders on the highway I'd take it somewhere else and try to get more caster.
    TheWildMan likes this.
  4. May 1, 2024 at 7:09 PM
    Red_03Taco
    Jerad
    So far it does seem to drive better than before the Icon UCAs went on (far less wandering, almost none).
    He told me the caster adjustment on the front cams was maxed out and that adjusting the rear would give more caster at the expense of adding negative camber. I'll drive it around more before deciding whether or not to try another alignment shop.
  5. May 1, 2024 at 7:17 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    I agree with the comments above in general, but the numbers that bother me are the rear toe. Judging by those, your rear axle in in a bit crooked. The tech should have noticed that and tried to address it. Even though there are locating pins, there is some play where very slight adjustments can be had. Whether it's enough to be an issue, I can't say, but it is there, staring you right in the face.
  6. May 1, 2024 at 7:21 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I'm not an alignment expert but that looks to be within the normal variation. It does look like it's ever so slightly dog tracking. Those numbers are so small you could probably change them more by just making sure the wheel reflectors are mounted properly and not on some dirt.
    and honestly, i doubt any changes at all were made on the before and after. Just shaking the vehicle will probably do that.
    Here is an alignment I got a few days ago on an '02. I just installed the same suspension components. This truck has a problem on the drivers front, so I had to switch to SPCs to get it to align and not run the 33" into the rear fender well.
    Red_03Taco[OP] likes this.
  7. May 1, 2024 at 7:34 PM
    ZColorado
    13 DCSB OR 6MT
    This was with brand new Icons, and Icon delta joint control arms like you. I could barely leave the parking lot like this.
  8. May 1, 2024 at 9:19 PM
    Red_03Taco
    Jerad
    Wow your #'s with the Icons make me feel better about mine lol. Have you identified the problem on the driver's side? You needed SPC arms to fix the negative caster that the Icons created? Is something wrong with your coil bucket where the UCAs mount to?
  9. May 1, 2024 at 10:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Looks like a "toe and go" to me. Meaning, the tech only adjusted the Otres to set the toe.
    There is no evidence the LCA adjusters were touched. The caster numbers are unchanged from the before and after results.
    It is possible the adjusters are not moving freely. Have you looked at your adjuster cams? It is pretty obvious when they are maxed out.
    Of course, as mentioned already, what is most important is how it drives and whether you like it.
  10. May 1, 2024 at 11:47 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Get the KPOffroad alignment cams and set the caster yourself using their recommended setting. Then have an alignment shop to set the toe.
    One of the best mods I did for my suspension. Takes setting the caster out of the alignment shop’s hands.
    leid and Red_03Taco[OP] like this.
  11. May 2, 2024 at 4:23 AM
    ZColorado
    13 DCSB OR 6MT
    The vehicle was in a small accident at some point, possibly two. I was not terribly shocked it was wonky. I just finished a lot of work that included a new fender, door, and fixing a very bent bumper. All low speed stuff, but enough. Still. I expected the caster on the passenger side to be more than that.
  12. May 2, 2024 at 5:39 AM
    Red_03Taco
    Jerad
    The adjusters are definitely moving freely. They're about a year or two old, and up here I'm Northern AZ we get no rust. I'll snap some pics of them and see if anyone can tell me if they were already maxed out (caster wise).
  13. May 2, 2024 at 5:42 AM
    Red_03Taco
    Jerad
    That makes sense. You were able to overcome that though with the SPC uppers though right?
  14. May 2, 2024 at 5:43 AM
    Red_03Taco
    Jerad
    I was looking at the Solo LCAs that push the ball joint forwards too, to gain more caster. Would you recommend recommend the KPO cam adjusters over them for this purpose?
  15. May 2, 2024 at 5:52 AM
    Red_03Taco
    Jerad
    So here's all my cam adjusters:
    Driver's Front:
    Driver's Rear:
    Passenger Front:
    Passenger Rear:
  16. May 2, 2024 at 6:42 AM
    ChargedSHOTaco
    Cumulatively, you are far from maxing out the caster. But you also don’t want to max it out, or you’ll go through lower control arm bushing quickly.
    The most notable thing is that the passenger front does not mirror the driver front. They should relatively be in the same, but mirrored, position.
    There is definitely more caster to squeeze out of that alignment. The alignment shop corrected the toe, and nothing more.
  17. May 2, 2024 at 6:51 AM
    ChargedSHOTaco
    The KPO cam adjusters make alignments simple, and locks the alignment in place. If you do plan on the Solo LCAs, I would definitely recommended the KPO cam adjusters so that you can ensure that you are getting the caster you want out of your setup.
    I have the Icon UCAs and Solo LCAs and have them dialed in with 5 degrees of caster…and it rides and handles better than ever, even with a lift.
    A lazy alignment tech can have you feeling like you’ve wasted your money, even after you’ve purchased the best suspension parts.
  18. May 2, 2024 at 7:07 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    In the pics nothing is "maxed out" in regards to caster. Looks like they didn't touch the LCA cams at all.
  19. May 2, 2024 at 7:10 AM
    ChargedSHOTaco
    He states above that the cam adjusters are 1-2 years old and it moves freely, and he lives in AZ, so they are not rusted.
    Do you agree now that the alignment tech was lazy?
  20. May 2, 2024 at 7:12 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I missed the part where he said they were moving freely.
    9/10 times they're stuck
