Thoughts on This lift?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Lost pilot, May 27, 2014.
  1. May 27, 2014 at 10:26 AM
    Lost pilot
    Lost pilot [OP] Well-Known Member
    Reid
    Nashville, TN
    04 TRD 4x4
    Front window tint, some other stuff
  2. May 27, 2014 at 10:31 AM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    That's all you need
  3. May 27, 2014 at 11:05 AM
    teehext
    teehext Well-Known Member
    Tyler
    CA
    2001 PreRunner SR5
    If that's everything you want then just buy the kit. Keep in mind you may need to modify the brake proportioning valve bracket depending on how high the back is lifted
  4. May 27, 2014 at 11:18 AM
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    Awesome thanks.. I can adjust the rear correct? I.E. Lift it 2 inches instead of 3 so I wouldn't need to adjust the brakes?
  5. May 27, 2014 at 11:25 AM
    Cohbsteq
    Cohbsteq Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
  6. May 27, 2014 at 11:50 AM
    zacharypaul89
    Zach
    Georgia
    If you get the rear ToyTec AAL, you won't need to do any brake modifications, as it only gives you 2"
  7. May 27, 2014 at 2:18 PM
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    So it will only give me 2" in the rear? It's confusing cause it says 3" lift but it's 2" AAL.
  8. May 27, 2014 at 2:42 PM
    zacharypaul89
    Zach
    Georgia
    The front sits a little lower than the rear (it's called rake), so if you get a 3" lift for the front and an AAL for the rear, it'll level out. Even stock, the sits so insignificantly lower, you can't notice
  9. May 27, 2014 at 3:26 PM
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    Ah, gotcha. So the amount of lift is measured from the front I guess.. Makes sense. What is the purpose of the front sitting lower in the first place?
  10. May 27, 2014 at 3:51 PM
    zacharypaul89
    Zach
    Georgia
    I'm pretty sure it's just from the engine being up there....I could be wrong though
  11. May 27, 2014 at 3:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Thats a good kit. Installed that on a buddies 2nd gen and he loves it!
  12. May 27, 2014 at 4:19 PM
    zacharypaul89
    Zach
    Georgia
    I've got that, but w/o the diff drop b/c I have a 2wd and w/o the Bilstein's for the rear b/c they're not necessary. It's much cheaper just to buy Bilstein 5100's, Eibach coils, and an AAL
    But like DeeKay21 said, it's a great kit, no matter what you decide to do
  13. May 27, 2014 at 4:42 PM
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    Hurrrllll yeah should be sweet. And you could just do the coils and shocks on the front, but i don't see why not just put a little extra money into it. The back shocks already got 100k on them, can't hurt to go with 5100's all around.
  14. May 27, 2014 at 4:43 PM
    DirtyDTaco
    DirtyDTaco Talk slow, shoot fast.
    Matthew
    Mississippi
    '00 XtraCab 4x4 3.4L V6 5-Speed, 240K miles
    Polk 6.5" Coaxial Door Speakers, Pioneer DEH-X6500BT Head Unit, Black Bed-Lined Badges, 15% Tint, JL Audio 10" BassWedge, Alpine 500w Mono Amp
    Helps when you have weight in the bed.
  15. May 27, 2014 at 4:46 PM
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    There's me truck btw.
  16. May 27, 2014 at 5:28 PM
    Lost pilot
    Reid
    Nashville, TN
    04 TRD 4x4
    On a related note, does anyone have any input about how a 3 inch lift will effect the tendency of a tacoma to roll? Can you pretty much drive it like normal on the road or do you need to take it easy on turns?
  17. May 27, 2014 at 6:29 PM
    zacharypaul89
    Zach
    Georgia
    I wouldn't go crazy, but I drive mine no different.
  18. May 27, 2014 at 11:33 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    My rear lift is only 1.5", and I needed both a longer break line and proportioning valve extension. The break line was obvious, but the Tacoma mechanic at the dealer pointed out the problem with the valve when my truck was on the lift. The extension is cheap; $15 at Wheeler's.
  19. May 28, 2014 at 3:35 AM
    shoeless
    shoeless Well-Known Member
    Brian
    Nashville
    Bit of a thread hijack:
    Would the AAL be ok with flat leafs? Or would there be reverse rake?
    Im looking for suspension as well but my stock leafs are flat. Would rather get a AAL for now and a new pack later this year.
    Thoughts?
  20. May 28, 2014 at 6:19 AM
    zacharypaul89
    Zach
    Georgia
    You might be okay. The ToyTec AAL (as well as most other brands) are curved and very stiff, so they will still give you lift, maybe just not quite as much as if you had new leafs that were in better shape. It probably won't even be noticeable if you can't notice a height difference between the front and back now
