Thoughts on this quote from my local shop?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pigeonguy, Aug 24, 2017.
  1. Aug 24, 2017 at 10:05 PM
    pigeonguy
    pigeonguy [OP] Active Member
    Tacoma 2017 Super White TRD Sports SB
    GPsevinSixx[QUOTED] likes this.
  2. Aug 24, 2017 at 10:07 PM
    erok81
    erok81 Well-Known Member
    Imposter
    So the ten hours for clearancing is beyond ridiculous but three hours for a cab mount chop isn't bad.
    125/hr makes me glad I can work on my own truck. :D
    Edit. Nevermind. That ten hours is for installing the kit plus time for clearancing for the tires. Which is dumb since that should be in the cab mount chop.
    I didn't check much else but I'd recommend talking to them about those two lines.
    scottalot likes this.
  3. Aug 24, 2017 at 10:12 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
    Probably good work and the profit there making they damn sure better give great service. OP shop this quote !
  4. Aug 24, 2017 at 10:13 PM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    It took me 1.5 hours to lift front end with beers. Rear takes max 3-4 hours if you do new leafs with beers and hassles. That's me in my drive way without a lift....
    youcantseeme, Fortunt1 and hoverlover like this.
  5. Aug 24, 2017 at 10:13 PM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    A 6" lift is going to invite a lot of headaches with this truck. They are not designed to drive well with this much lift. You will end up needing to regear the rear differential because it is going to feel like you're towing a 5,000lb trailer all the time with 35" tires. The stock gear ratios are not designed to turn big tires like that. I recommend keeping the lift below 3"...you can get a really solid performing lift for less than 3 grand....BDS lift is a drop bracket lift and just is not really popular here.
    Garyji, speedtre, jc11taco89 and 3 others like this.
  6. Aug 24, 2017 at 10:21 PM
    erok81
    Imposter
    For the record gear ratios and tire size is completely subjective.
    I drove around 8k miles with 35's and stock gears. I had gears in my garage for 7500 of those miles. I got used to it and didn't mind driving around that way. Mines an auto too.
    Some people can't handle 33's and stock gears. Some people can't handle stock tires without 500hp.
    All depends on what you can tolerate.
    rlx02, Victory and MESO like this.
  7. Aug 24, 2017 at 10:24 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    I would have to agree with smitty above. If you are set on a 6in thought I'd shop around. Now if that included regearing would be another story because you will need it.
  8. Aug 24, 2017 at 10:26 PM
    pigeonguy
    I have so much to learn... thanks all.
    Tacomamike mike likes this.
  9. Aug 24, 2017 at 10:29 PM
    Tacomamike mike
    Michael
    Chop shop Dixon ca. Great work done , very honest. Was done right first time on 4 rigs for me. And Veteran owned and operated .
    pigeonguy[QUOTED][OP] likes this.
  10. Aug 24, 2017 at 10:30 PM
    Tacomamike mike
    Michael
    See my last post...call the chop shop. They will take care of you.
  11. Aug 24, 2017 at 10:33 PM
    20tacoma17
    2017 DCLB Sport AT
    It's all good. Some may give you a hard time but all in fun.. it's your truck and get what makes you happy. Get more quotes and use the search tool to do lots of research on what you want and will need. There should be a 6in lift thread somewhere where you can find what others have done and everything that was needed. Some may even give you goid idea on what it cost them?
  12. Aug 24, 2017 at 10:39 PM
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    Ditto.
    You'd be surprised what you can do yourself with common tools and a little bit of reading. Save that money and buy tools instead. Lots of Tacos in Cali, I'm sure you could even make some cool new friends that would enjoy helping you out with an installation. You could spend a lot less and end up with a lot more in the end. Just my $.02.
    pigeonguy[OP] likes this.
  13. Aug 24, 2017 at 11:34 PM
    Hummer911
    Hummer911 Well-Known Member
    Rick
    So. Cal
    2014 RC 4X4 MGM Auto
    BDS 6" lift, Toyo tires on Method wheels
    If you really have your heart set on a 6" drop bracket lift then at least you picked the best. BDS is the very best. For $1800 that is their basic kit. Their premium kit is about $3,400. That kit includes Fox 2.5 coil-overs for the front and they are $800 each. Its an 8 hour job not 10 so labor should be around $1000 maybe a little more. If you drop down a size on your tire selection and go with 33" tires you may be able to do without the CMC but only if you don't wheel too hard. Alignments should be around $130. You will have to regear even with 33"tires if you have an automatic.
    Be advised that if you choose to go with a BDS 6" lift kit...you will need to have 18x9 wheels with a 4.5 back spacing to clear some components of the lift kit. 16" and 17" wheels will not work even with spacers. Ask me how I know. LOL. A drop bracket lift requires part of your frame being cutout and removed just so you know.
    There seems to be guys that prefer a 3" lift and guys that prefer a 6" lift. Just remember...it's your truck and your money so you can do what you want with it. Go for a ride in a lifted truck first and see if it's for you.
    Good luck.
    get_nick, FStewart17, JimBeam and 3 others like this.
  14. Aug 25, 2017 at 3:27 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    FWIW just 10 miles per day commute (5 each way?) is about the worst service duty you could give that engine, poor thing will never get hot enough to burn off the nasties in the oil. Make sure you keep the oil clean with changes at least each 3500-4000 miles...
  15. Aug 25, 2017 at 3:36 AM
    #35
    Mr-Paul
    Mr-Paul Well-Known Member
    Paul
    2017 Qucksand Tacoma SR5 4x4 V6 Access-Cab
    I would look at getting a 2 to 3 inch lift and 33" tires for the truck. A 6 inch lift is mostly for looks and not for off road performance. The quote seems very expensive. You probably need a regear for 35s.
    Your truck/ your decision.
  16. Aug 25, 2017 at 3:50 AM
    #36
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    FStewart17 and speedtre like this.
  17. Aug 25, 2017 at 4:00 AM
    #37
    lynyrd3
    Bill
    East Central Upstate NY
  18. Aug 25, 2017 at 4:24 AM
    #38
    vinnyd34
    vinnyd34 Well-Known Member
    Vincent
    Williamsburg, VA
    2016 Silver Tacoma TRD Sport DCSB
    TRD Pro skid, TRD Pro Wheels , TRD Pro Grill, Factory Mud Guards, Factory Bed Mat, Exhaust Tip, N-Fab Nerf bars, Pop-N-Lock Tailgate Lock, MicTuning 32" Lightbar.
    I like to get kissed when I get screwed! I don't see any kisses on the quote sheet!lol
  19. Aug 25, 2017 at 4:26 AM
    #39
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I say for that amount of coin to look into some quality coilovers and rear suspension and have a TW meet up install party. You will have quality stuff from the start and likely spend about half.
    medic2230, Mr-Paul and pigeonguy[OP] like this.
  20. Aug 25, 2017 at 5:28 AM
    #40
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    I believe that is 10 hours to install the lift, with additional time added for tire clearance.
    Overall this sounds like a pretty decent deal to me.
    Especially considering what people pay for lifted tacos from the dealer!
