thoughts on timing chain change
Discussion in '4 Cylinder' started by coffeesnob, Sep 21, 2016.
  1. Sep 21, 2016 at 3:17 PM
    coffeesnob
    coffeesnob [OP] Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    4 cylinders have timing chains. Timing chains don't last forever either. They can break and stretch.Any thoughts on changing them?
  2. Sep 21, 2016 at 3:22 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    Once mechanic at Toyota dealer told me that I will not need to replace timing chain in my 1995 2.7 Taco before I replace the engine. When we change head gasket at 302k miles I did not see any anomalies in timing chain setting - the tensioner was still within normal limits, no cracks no signs of wear on gears or chain itself. I think I will continue to believe Toyota dealer mechanic.
    Mush Mouse and inwood customs like this.
  3. Sep 21, 2016 at 3:28 PM
    coffeesnob
    VA
    How did you check for cracks in the chain?
  4. Sep 21, 2016 at 3:54 PM
    RysiuM
    Rysiu
    Nothing fancy - just inspected it with good lamp. The same I did to all head moving parts while I had the head out.
    I was curious what kind of wear is there. Nothing that I would concern about. I hope I did not miss anything but so far 4 years and 14k miles later (this truck is now the secondary as I drive new 4Runner as DD) there is no change in performance. Smog test (CA needs it every 2 years) at least 3 times below average on all numbers.
  5. Sep 23, 2016 at 9:54 AM
    JPT4x4ac
    JPT4x4ac Well-Known Member
    Jon
    Broadalbin , NY
    2012 Grn Tacoma AC 2.7 MT
    I believe the 2.7 has more than one timing chain because of the VVTi
  6. Sep 23, 2016 at 10:11 AM
    RysiuM
    Rysiu
    At least 95 version has only one.
  7. Sep 28, 2016 at 2:52 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    The 2TR-FE has two timing chains. One driven off the crank to one camshaft, and another between the two camshafts. I kinda wish Toyota kept the gear drive between the two cams, a much simpler connection.
    I would not open up the engine just to replace the cam chains, no matter the mileage -- timing chains are designed to last the life of the engine and Toyota 4-cylinder engines typically live a very long time. Timing belts are another story entirely.
    If the engine is open anyway, I would change the timing chains if it's over 150,000 miles or so...
    Markcal and Mush Mouse like this.
  8. Sep 28, 2016 at 6:19 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    Just use decent oil and it should last a long time.
  9. Sep 30, 2016 at 6:08 AM
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    Isn't the life expectancy of the 2tr like 400k miles or something awesome like that
    Mush Mouse and AJH387 like this.
  10. Sep 30, 2016 at 6:56 AM
    tgear.shead
    tgear.shead Well-Known Member
    That would be a very short life for a 2TR.
    GDT, Mush Mouse, 3rYODA and 1 other person like this.
  11. Dec 23, 2016 at 6:07 AM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Mine started making noise a few days ago (replacement kit has been ordered).
    My 2TR only has 140K on it...so I guess they don't last forever :(
  12. Dec 23, 2016 at 6:43 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
  13. Dec 23, 2016 at 6:47 AM
    Clearwater Bill
    Billy
    Largo Florida
    How do you know it's the chain(s) making noise?
  14. Dec 23, 2016 at 6:49 AM
    Mush Mouse
    mush
    2013 SR5
    usually the chain guides(plastic) break and the chain starts flapping that's what happen to the 22r series engines, this in my 1st 2.7l not sure if its the same guides issue as the older 4 cylinders
  15. Dec 23, 2016 at 9:02 AM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Intermittent noise from front of motor at idle, with belt removed as well as noise when coasting.
    Don't believe there's noise under power...probably due to tension on the chain.
    Really hope she doesn't break before chain is replaced.
  16. Dec 23, 2016 at 9:07 AM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Will post failed component when chain is replaced.
    Good info...Thanks for the reply.
  17. Dec 23, 2016 at 9:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's kinda unusual for the chain to actually break. In the days of yore, they would stretch, then either wear a hole in the cover and dump the oil, or they would jump teeth (like a bike chain) and screw the timing all up.
    If the guides are the failure point, see if there are upgraded guides available.
  18. Dec 23, 2016 at 11:00 AM
    Mush Mouse
    mush
    2013 SR5
    i had a 1995 22RE engine where the plastic OEM guides broke and stretched chain was really making noise. the mechanic I had replaced the chain with an aftermarket one it had steel chain guides and was a hard job to do. also replaced water pump while the engine was apart too
  19. Dec 23, 2016 at 11:52 AM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Drove the truck today, she definitely makes more noise when coasting (or lightly off skinny pedal)...no noise when under load.
    Kinda sounds like a Honda vtec engine :p
  20. Dec 30, 2016 at 7:33 AM
    mistermanny
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    I checked the oil level again, and found it to be low..2qtrs low.
    After Adding Oil, the noise is Gone :)
    Mea Culpa Mea Maxima Culpa
    Feel like I dodged a bullet on this one...I will do a better job maintaining my tacoma, promise.
