Thoughts on transmission flushes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Codys9469, Feb 23, 2020.
  1. Feb 23, 2020 at 5:12 PM
    Codys9469
    Codys9469 [OP] Member
    Cody
    2017 Tacoma SR5
    Just curious who on here believes in transmission flushes vs. Not touching it?
    I have heard of doing both from people just wondering what everyone on here thinks...
  2. Feb 23, 2020 at 5:21 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    I do a drain and fill every 10k. Just for piece of mind
    koditten and Codys9469[OP] like this.
  3. Feb 23, 2020 at 5:30 PM
    Marek71
    Marek71 Well-Known Member
    2019 TRD Sport DCSB
    I would flush it at regular maintenance intervals unless you're ready at over a hundred thousand miles and never did anything then I would leave it alone or just drain the oil and replace whatever came out.
    Codys9469[OP] likes this.
  4. Feb 23, 2020 at 5:33 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
  5. Feb 23, 2020 at 5:39 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The only time a flush is needed is after an internal failure. Flushing the lines and cooler will prevent contamination and premature failure of the new transmission.
    Draining and replacing the fluid will be fine.
    auskip07, stun gun, Junkhead and 3 others like this.
  6. Feb 23, 2020 at 6:09 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Always drain and install a new filter.
    Flushing automatic transmissions have a habit of causing premature transmission failure.
  7. Feb 23, 2020 at 6:27 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    @gearcruncher
    A lot of old wives tales around this topic. Instead of “flush” call it a “fluid exchange.”
    The transmission pump runs as usual. Fluid being returned from the transmission cooler to the pan is diverted into a pail and replaced with fresh fluid.
    From the transmission’s perspective it’s invisible. Business as usual, but clean fluid at the end of the day.
  8. Feb 23, 2020 at 6:28 PM
    DANGERMONEY
    DANGERMONEY Well-Known Member
    +1^
  9. Feb 23, 2020 at 6:55 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Over a 100,000 I don't touch them. "The crap in the fluid is holding the thing together" Fluid Exchange is the propaganda Firestone taught us in Chicago, and I agree with the principal. Flush is something a toilet does...lol.
    Zim
    PS. Honestly I would follow the Manufactures guidelines. If it says piss in the fill tube, do it. My favorite line is;
    "There is a guy in Japan, or Detroit, who sits in a nice leather chair, and makes $238,000 a year. He's a smart MF. I don't know too many automotive engineers that hang out on forums, and tell folks to pull the positive cable off to check the alternator"
    Z
  10. Feb 23, 2020 at 7:00 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    :duh: He must have oil futures stock, there’s no need to replace transmission oil that often.
    Pro-Taco, Kevin Jones and Skydvrr like this.
  11. Feb 23, 2020 at 7:03 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Lol, hey it may be a good thing. I've done this crap a long time, and have avoided automatic transmissions for a reason. The reason is if you open one, you're screwed..lol
    Zim
  12. Feb 23, 2020 at 7:07 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    "Lifetime fluid" = the fluid reaches end of life at some point after your powertrain warranty expires. :devil: Therefore if you flush at the 5 yr / 60k intervals, the fluid will always be at a serviceable condition.
    Flushing is easily done with a $35 Amazon transfer pump. Just disconnect the transmission hoses at the radiator and connect to the pump as per the video. Fluid flows in the same direction as it normally does in the vehicle:
    Level check procedure will obviously be different with the AC60.
  13. Feb 23, 2020 at 7:10 PM
    OnHartung'sRoad
    I’ve probably done it longer than you, and had auto transmissions the whole time, except the ‘85 Toyota PU. All the other automatic Toyota transmissions I’ve owned lasted more than 250,000 miles on those trucks before I sold them, and they still worked great. Even the auto transmissions in my Chevy and Ford did well over the whole life of those two trucks with a little more than the recommended transmission fluid changes, it’s just not necessary to do that more often than what the manufacturer says.
    Skydvrr and Tacman19[QUOTED] like this.
  14. Feb 23, 2020 at 7:21 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    Agreed. I traded a Subaru for the Toyota. They make really good stuff. Love the quote on you sig too. Thanks
    Zim
  15. Feb 23, 2020 at 7:39 PM
    OnHartung'sRoad
    We had a 4wd turbo GL10 (for my wife’s car)- fastest little family station wagon I ever drove! :)
    Tacman19[QUOTED] likes this.
  16. Feb 23, 2020 at 8:09 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I'm always worried when I hear "oh it never has to be changed", "sealed unit" which is what I was told when I bought the truck. I didn't see any interval mentioned in the owners manual but I would think that 60-75 would be a good time to change the fluid.
  17. Feb 23, 2020 at 8:34 PM
    Sharpish
    Brian
    I do a full fluid EXCHANGE every 100 000 km because it’s a nice round number and it’s Only $200 at my dealer.
  18. Feb 23, 2020 at 8:49 PM
    Amanelot
    Amanelot Member
    Texas
    Its like 2 quarts
    And I tow a lot
  19. Feb 23, 2020 at 9:03 PM
    GOLIVER0131
    GOLIVER0131 TrdMo
    Socal
    '17 Wht Trd OR DCLB(TrdMo)
    TrdPro grille, blackout badges. Pretty much stock.
    Every 50k for the transmission and diffs on my other cars, jeep I6(w/trans cooler) and mbe550(stock). Each has over 175k miles on them and never any issues.
  20. Feb 23, 2020 at 9:16 PM
    OnHartung'sRoad
    We RV too- a 20ft Jayco.:cheers:
    Amanelot[QUOTED] likes this.
