thoughts on wheel spacers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blaine546, Jan 4, 2013.
  1. Jan 4, 2013 at 1:58 PM
    blaine546
    blaine546 [OP] Active Member
    blaine
    rockport
    07 tacoma trd sport
    3'' pro comp front lift, all pro leaf springs. afe intake, avid offroad light bar
    Hey everyone, just bought a set of nitto's 295/70/17 and im trying to fit them with my 3'' pro comp lift but the uca's are way too close to my stock tires as is (265/65/17) so the nittos are definatley going to cause issues. has anyone had any success using wheel spacers? ive heard bad things about using them but wanted to hear first hand from someone else who may have ran into the same issue.. thanks everyone!!
  2. Jan 4, 2013 at 4:01 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Search.
    You will find your answer and then some. This forum has a huge database and a nice search function versus other forums.
    Alot of users run them no issues. I am one of them.
  3. Jan 4, 2013 at 9:08 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
  4. Jan 4, 2013 at 10:32 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    I love my spidertrax, bought them for my 09, and took them off before selling it and out on my 12. Only issue with having spacers is, no major shops (NTB, discount tire, etc) will balance or rotate your wheels due to liability issues.
  5. Jan 4, 2013 at 10:37 PM
    05TacoDblCab
    05TacoDblCab Member
    Word of advice man is that if money isn't an issue buy new rims with a different offset over the spacers. If money is an issue get the spacers. Now with spacers some say they come with locktite I never seen a package of it in the same box as a space, but none the less use locktite when you put them on. I'm sure you don't have to use much but somes better than none. I've seen 2 trucks lose a front tire Øn the road due to spacers becoming loose. You should check them periodicly regardless. If something feels weird out of the blue do yourself a favor and get off the road asap and check them. Good luck with your decision Øn whatever you do. I personally got a set of rims do to my situation with tire clearances around tax time a couple years ago and have had no tires come off thus far.
  6. Jan 4, 2013 at 10:44 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    I run all-pro spacers, i think the 1.5". No problems so far! I know what the risks are, but I've been off roading, taken some hard hits and they are just fine!
  7. Jan 4, 2013 at 10:55 PM
    rawdog
    rawdog Well-Known Member
    Kelowna B.C.
    2016 TRD Sport Upgrade PKG DCSB
    Huh, that doesn't make sense, last I checked when you balance your tires, they are not on your truck and not even bolted to your spacers.
  8. Jan 4, 2013 at 11:05 PM
    BMOC
    BMOC Well-Known Member
    Paden
    Phoenix, AZ
    get them hub-centric. should be good to go. i use ballistic fab hub-centric spacers on my rear axle, no problems @ 10k miles.
    better option would to get less backspaced wheels though IMO.
  9. Jan 5, 2013 at 12:26 AM
    pra4sno
    pra4sno Well-Known Member
    Fort Collins, Colorado
    2017 DCSB OR MT. Previously 2013 DCSB SR5
    Not sure if its the same on the Toyotas, but I've shied away from wheel spacers after long term ownership of two Jeeps. I had wheel spacers on one, and the added offset ate a pair of wheel bearings about every 25,000 miles.
    My buddy's silverado had more significant offset than mine, and his went through bearings every 20k as well.
  10. Jan 16, 2013 at 10:08 AM
    rawdog
    Kelowna B.C.
    That's interesting about the wheel bearings.. Maybe more pressure on them from the tire further out like a lever... But then again, how does your wheel bearing know the difference between a spacer and just less back spacing?
  11. Jan 16, 2013 at 10:11 AM
    acdronin
    acdronin Well-Known Member
    Beat the hell out of my spidertax 1.25's no problems here, make sure to use the Loctite though
  12. Jan 16, 2013 at 10:16 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    It doesn't. Having the tire spaced out by either using different offset wheels or spacers will have the same effect on your wheel bearings. It will put more stress on them. It's not a science though to say how much quicker they'll wear out or if you'll even notice.
  13. Jan 16, 2013 at 10:29 AM
    rawdog
    Kelowna B.C.
    Luckily I have warranty for much longer than 20k so I don't give a shit haha. Throw the stock wheels on and off to Toyota she goes!
