Thoughts?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kirkofwimbo, Apr 14, 2012.
  1. Apr 14, 2012 at 8:45 AM
    kirkofwimbo
    kirkofwimbo [OP] Say no to Bro
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    So I was about to start washing my truck, and was spraying down my engine bay when I noticed there is no cap on my oil fill neck. I know that I surely got some water in there, not alot, but a fair amount. So what do you think? Full oil change? Anything else?
  2. Apr 14, 2012 at 9:08 AM
    ROGU3 PR3DATOR
    ROGU3 PR3DATOR Space Shuttle Door Gunner
    Jake
    Niceville, Florida
    MGM 2011 TRD Off-Road
    Lifted, Supercharged, Armored, and lots more
    Id drain the oil completely and then before putting the plug in, dump another quart in and let it drain out to hopefully get most of the water out. That and don't run it at all till that happens.
  3. Apr 14, 2012 at 9:15 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    Ditto
  4. Apr 14, 2012 at 9:20 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    #1 Where did the damn cap go? ...
    #2 I would do the same as above, drain it maybe pour alittle through and put new in. A tiny bit of water will not hurt, you get condinsation normally that burns off. After new oil in, I would run it, and just check it to make sure no water left.
  5. Apr 14, 2012 at 10:10 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘17 TRDOR DCSB
    I think I must've pulled a dumbass last time I changed the oil and forgot to put it back on. Thanks for the help guys! I'm just glad it won't need to be towed lol
  6. Apr 14, 2012 at 10:19 AM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    Drain,refil,run engine for a while-not just around the block-Let it heat up to be sure all the moisture is GONE. If oil turns MILKY WHITE(off color) CHANGE AGAIN.
    A SMALL amount of water will just burn off. Just a few drops will not hurt--but a half a cup (4 oz) may cause problems.
    AND DON"T FORGET to put the DAMN CAP ON!!!!
